When I purchased the car, the cd player did work, then all of a sudden after ejecting a cd, it won't read cd's any more - it just spits out the cd.
SOURCE: car cd changer not working!
HELLO I HAVE A JVC KD-S680 IT HAS BEEN WORKING FINE FOR THE PASSED 5 YEARS ALL OF SUDDEN ON WED...IT DECIDED THAT IT DIDN'T WANT TO PLAY OR READ ANY OF MY CD'S...I PUT IN A CD IT'LL SAY PLAY THEN IT JUST GOES RIGHT TO THE FM2 RADIO...I'M GOING TO TRY AND RESET AND SEE IF THAT WOULD WORK. I REALLY HOPE THAT IT DOES.
SOURCE: cd keeps ejecting
use a product called cd kleen it.you can find them on ebay.they take care of problems like this.
SOURCE: stuck disc in JVC CD player
It wasn't a car cd player, but a component for a stereo. I took off the case and shook the player until the disc dropped out. We plan to replace the player, so no further help is needed. Thank you for getting back to me so quickly.
SOURCE: JVC CD player won't turn on, but will eject CD and display time.
Make sure the red wire is still connected or make sure the red wire hasn't been severed. Also, check the fuses located in the engine compartment. The red wire connects accessory terminal in the fuse block. Also check the fuses in the cabin. This fuse box is typically located on the driver's side, at knee level, next to the door panel, and underneath the dashboard. As a last resort, the unit can be taken to an authorized or factory service center.
SOURCE: Have the JVC KD-PDR30 CD Player car stereo. Was
check owner's manual:
http://resources.jvc.com/Resources/00/00/91/GET0467-001A.pdf
