Question about Canon PIXMA iP1600 Printer
Continue printing greyed out
My last lexmark printer allowed me to CONTINUE printing even after low ink warnings. I managed to print several good copies even after this warning, and i could ultimately decide when i thought the quality of printing was bad enough to change the cartridge. My new lexmark printer's Continue button is greyed out after the first warning. My question is:
Is there a string I can change in the printers software that will activate the continue button after this warning. Ink is not cheap and i hate wasting.
thanks.
  • 4,041 Answers
Hi there
You can try this it some times works.
Super Canon User's method of resetting IP1600
1.Press Resume button hold for 1 - 2 minutes (count to 1 to 15-16)
2.Open the cover right away
3.Release Both cartridges out and then put cartridges them back again
4.Close The Cover
5.Turn Off Then Turn On again.
You can download the Resetter tools program from my website.
Click Link = http://www.4all2sell.com/reset-tools/ip1600st-RESETTER-TOOLS.zip
1. Download software for Canon iP1200, iP1600, 2200 Printers.
2. Unzip downloaded file by etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Free WinZip http://www.winzip.com/downwz.htm
Please call back to vote
All the best: Pineworks
Posted on Feb 27, 2010
How to override lexmark s415 low ink
There's no way to override the low ink warning. If one of the cartridges is out of ink, you won't be able to continue printing.
Refilled cartridges will not report or reset the ink levels.
Jan 09, 2013 | Lexmark S415 - multifunction fax / copier...
Missing Yellow cartridge in printer can I still print?
If you are using one of Lexmark printers that has the new ink system based upon individual tanks (like the following models: S300, S400, S500, S600, Pro200, Pro700, Pro800 & Pro900 Series), these models require all cartridges to have ink them to continue printing.
However, there are some previous Lexmark models that are able to continue printing even if one cartridge is empty.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this answer your concern, your rating will be greatly appreciated.
Oct 21, 2011 | Lexmark X5150 All-In-One InkJet Printer
My color inks are out of ink but still in the printer...i just replaced the black ink. when i try to print, it will not allow me and says to replace the color inks first. i followed the instructions to...
The Lexmark Impact S305 printer requires all the cartridges to have ink in them to continue printing - even if you're printing using black ink only. To print true black, you actually use some of the color ink.
Note: Leaving the color cartridge empty or dry isn't good for the printer. It can lead to poor print quality if you want to print color in the future.
Sep 23, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
Im trying to print a black and white document but it wont let me print because my color cartridge is missing
The Lexmark X2600 requires both cartridges to have ink in them to continue printing, even if your printing in "black and white". To print true black, you actually use some of the color ink. , Leaving the color cartridge empty or dry isn't good for the printer. It can lead to poor print quality issues.
Sep 22, 2011 | Lexmark X2600 InkJet Printer
When i gave print from doucment machine takes paper and give it as it as blank, solve my problem,
Solution one: Check the ink levels To allow for full use of the cartridges, some printers continue to print even after the cartridges are completely out of ink. Follow these steps to check the ink levels in the Toolbox . The Toolbox is part of the standard printer software. Depending on the version of Toolbox on your computer, the appearance of the Toolbox features might vary. NOTE: Ink level warnings and indicators provide estimates for planning purposes only. When an indicator shows low ink levels, consider having a replacement cartridge available to avoid possible printing delays. Print quality deteriorates as cartridges run out of ink.
  1. Click Start .
  2. Click Printers and Faxes .
  3. Right-click the icon for your printer (c01532298.gif ), and then click Printing Preferences .
  4. Click the Features tab.
  5. Click the Printer Services button. The Toolbox window opens.
  6. Click the Estimated Ink Levels tab. A window opens that indicates the estimated ink level of each cartridge. NOTE: Depending on the printer, the estimated ink level indicators can vary in appearance. Examples of estimated ink level indicators c01867289.gif c01867290.gif
  7. If the ink level indicators show that a cartridge is low or empty, replace the cartridge.
  8. Try printing again.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
Solution two: Restart the printer Restarting the printer might clear the issues and allow the printer to function correctly again.
  1. Press the Power button (c01602202.gif ) to turn off the printer. NOTE: Pressing the Power button might not turn off the printer. This might happen if the printer is in an error state. Continue with these steps regardless.
  2. Disconnect the power cord from the back of the printer. Figure 1: Disconnect the power cordc01869581.gif
  3. Disconnect the USB cable from the back of the printer. Figure 2: Disconnect the USB cablec01850063.gif
  4. Wait 30 seconds.
  5. Reconnect the USB cable to the printer. Figure 3: Reconnect the USB cablec01868577.gif
  6. Reconnect the power cord to the printer. Figure 4: Reconnect the power cordc01869582.gif
  7. Press the Power button (c01602202.gif ) to turn on the printer.
for more information see this page
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01892627&lc=en&dlc=hu&cc=hu&product=1138373#N46
i hoprt his helpful
thank you for using fixya
Feb 15, 2011 | HP Officejet 4355 All-In-One InkJet...
I HAVE JUST REFILLED MY LEXMARK X2550 PRINTER COLOR CARTRIDGE NUMBER 35, BUT A MASSEGE ON MY PC SAYS: "Invalid Cartridge". How do l get it to be recognised so that l can use it?
hello
35 is color ink cartridge .. high yield,
A new color print cartridge needs to be installed.
If available, click the Continue button on your computer screen to print using the
black (or photo) print cartridge. (The Continue button is available only at the
beginning of a print job.)
Note: A variable amount of ink remains in the color print cartridge.
Follow these steps to replace the color print cartridge in your printer:
1 Cancel the print job if not already canceled.
2 Replace the color print cartridge with a new cartridge. For more information,
see "Removing a used print cartridge" on page 35 and "Installing print
cartridges" on page 35.
3 Print again.
To order supplies, click Order Ink on your computer screen. You can also see
"Ordering paper and other supplies" on page 40 in this guide.
Troubleshooting 54
manual = http://www.lexmark.com/publications/pdfs/2007/2500/v3708617_en.pdf
Installing print cartridges
1 If you are installing new print cartridges, remove the sticker and tape from the back and bottom of the cartridges.
1 2
Warning-Potential Damage: Do not touch the gold contact area on the back or the metal nozzles on the
Maintaining the printer
35
list of ink cartridge part numbers
http://www.lexmark.ca/lexmark/product/home/455/0,6970,204812589_653399443_1037657543_en,00.html?tabId=7
Dec 23, 2010 | Office Equipment & Supplies
I need to reset my ink levels on my lexmark s305 after refilling cartridges
I managed to successfully refill the black cartridge for the S305; I did it when the printer warned of 'very low black ink' (although it didn't print very well - i.e. grey - until the following day). It kept displaying 'low ink' but printed fine for a few months.
I think if you can catch it before the printer decides it needs an 'official' refill or replacement then it works (although when exactly this is is a mystery, as it always displays 'low' for black ink).
Yesterday, the printer decided it wouldn't print until the cartridge was changed.
Refilled; waited for half a day;replaced several times; turned the printer on and off 5 times with no cartridge in (to see if it would wipe the printer's memory of the cartridge); and spent about 4 hours online trying to find a solution.
If it starts working tomorrow, I'll let you know. I don't want to mess about with software that may reset the ink levels. (If anyone finds some that works, please post!)
It looks like Lexmark have ensured they can pile in the cash with their original cartridges.
I've heard about generic cartridges that are chipped to avoid the above problem - I'll visit my local refill store soon.
There must be a way round this!
Cheers, Fronter
Mar 08, 2010 | Lexmark X3550 All-In-One Printer
Lexmark x2550 printer
To get your printer to recognize the new cartridge; go to start - printer and faxes -right click on printer - preferences (printing preferences) -settings -load factory settings. Print test page Ctrl+P
Apr 05, 2008 | Lexmark X2550 All-In-One Printer
Low ink level after ink refill prohitting print function
Click on your lexmark maintenance tools and click on install new cartridge. This should fix your problem.
Mar 29, 2008 | Computers & Internet
Reconfigure ink to print setup?
Actually, epson printers needs all the inks for it to print. The print heads on epson are fixed thath is the reason why they need to be primed with inks when printing to prevent print head damage.
Feb 12, 2008 | Epson Stylus Photo R340 InkJet Printer
Canon PIXMA iP1600 Printer Logo
62 people viewed this question
old marine
old marine
