The motor starts but will not rev up when the accelerator is pushed down
Leland,
Check the Cat Converter --- and the fuel pump pressure. If either or both are faulty the engine will run at idle but stave out when a load (gas pedal) is applied.
I think I answered this once before ---FixYa keeps sending the question.
Look for where the throttle cable connects at the throttle body. If you can move the throttle plate here and get the engine to respond, then the cable is either broken or disconnected at one end or the other. Any other situation doesn't seem likely.
SOURCE: engine stalls when acceleration
sounds like poss throttle pos sensor prob./ could also be problem w/fuel pump not pumping enough fuel at high speed. poss fuel filter clogging also. have someone check pump pressure.
SOURCE: 2000 GMC Jimmy won't start
i had the same problem and replaced the fuel pressure regulator. Cost about $45 at advance auto store or about $90 at napa auto stores. Once i replace that my truck started right yup and runs like a champ
SOURCE: Brake pedal still goes to floor 2000 GMC Jimmy
It's very possible to be the master cylinder, the o-rings on the piston could be worn, letting the fluid seep back through instead of getting full pressure through the lines. Could also be the brake booster.
Try changing the master cylinder first, which is cheaper and easier, and see if there is a difference, you'll need to bleed the brakes again.
To check the booster,
With the engine off, pump the brakes until the pedal is hard, then hold pressure on the brake pedal and listen for air escaping, or the pedal goes slowly to the floor, Do that after the master cylinder has been changed, at least that will be eliminated.
Testimonial: "Hadn't thought about the O-rings on the rod thanks for the idea. Great Idea Thanks!"
SOURCE: How to uninstall a blower motor on a 1999 GMC JIMMY
Yeah if you have to tap on it, then that means the brushes in the motor are worn out and you need to replace it. The blower motor is behind the PCM and Coolant Overflow bottle. If you remove these then it will give you better access to motor. You'll have to cut around housing. There should be a groove already there for you, just make sure you don't cut all the way around it. Once you open it and get the new one installed, you'll have to use caulk to seal where you cut it at.
