Question about Oasis Hunter 54' Ceiling Fan
Wire colors for fan switch i have grey black brown purple
Tried L black 1 grey 2 purple 3 brown have 5 wires from fan purple silver or grey lite tan another grey and black most wires go with each color but fan still no dice what am i doing wrong
3 Suggested Answers
  • 57 Answers
SOURCE: I'm looking to replace the fan switch for a
This is fairly simple.
Assuming you have a black brick capacitor, and assuming you have the correct switch, for capacitor speed control.... (if you don't you will not blow anything up)
On your capacitor, there should be a set of two wires which are the same color. Black goes to L The two wires which are the same color, one will go to position 1. The other two wires, will go to 2 and 3. On the capacitor it should have some numbers and crude diagram with the color of wire on it. The wire with the highest value (say it's 6) will go to position 2 and the lower value will go to position three.
If you only have one small capacitor in the switch housing, (usually a red and white wire one) then you have a winding taps speed control. If you have a capacitor type switch, you can burn out your motor, as on the second position of that switch it activates both 2 and 3 (or medium and low) Be sure you have a switch which operates as such L+1 L+2 L+3. If you have the proper switch, then all you need to do is connect the black wire to L and then randomly place the other three wires into the switch and test it. Most likely the speeds won't be right (it might go medium, low, high) if it does, then just move the wires around until it goes high medium low.
Posted on Apr 01, 2010
  • 910 Answers
SOURCE: I have a hampton bay
One Grey is for Speed 1 and the other Grey is for Reverse.
I don't think it matters which way they're connected but if it does, all it means it when you start the Fan it will run in reverse instead of forwards at Speed 1 so you'll just have to swap them over.
Generally as Diagram Below (Not mine but gives you the idea).
Posted on May 05, 2011
How do I connect the purple,brown,grey and black wires to a harbor breeze fan?
Try this; Purple - 3
Brown - 2
Gray - 1
Black - L
If this doesn't work you probably have the wrong switch. Just because they look the same on the outside doesn't mean they're the same on the inside!
Jun 09, 2015 | Dryers
Westinghouse 3speed fan switch 77288
It's the westinghouse switch. Many results on search. I just wasted 2 hours playing switching wires all combos. Others suggested the switch from Lowe's. Harbor breeze #0033905 . Plug wires back in as you listed Black L, Grey 1, Brown 2, Purple 3. Works perfectly for $3.98 plus tax.
Others said you can call Hampton Bay and get the replacement also.
Sep 24, 2013 | Hampton Bay Dryers
Fan switch are LJY-280A and E198635
I have a Hampton Bay indoor/outdoor ceiling fan with 3 speed fan switch WU Pin LJY280A, E198635. It is a L-3-1-2 (ccw) switch with purple, grey, black and brown wires. The wiring is different than most on web. The L is not black, 2 is black. My wiring for the switch is L-Purple, 3-Grey, 1-Brown, 2-Black.
Found schematic on web that I think is correct:
Off-none,
Hi-L,1 4uF,
Med.-L,2,3 10uF & 4uF,
Low-L,3 5uF & 4uF.
I hope this helps someone.
Feb 21, 2012 | Hampton Bay Dryers
How to hook up without connectors
car colors
yellow 12v switched
orange 12v con
green rf-
lite green rf+
grey lf- paired with tan
tan lf+
blue rr+
lite blue rr-
yellow lr- Paired with brown
brown lr+
pink pwr antenna
brown alone illumination
grey alone illumination dimmer
black ground
radio wires
purples rr
green lr
grey rf
white lf
red switched
yellow 12 con
bluewhite stripe ..amp turn on
blue power ant
black ground
hope it helps
Jun 07, 2010 | JVC AM FM CD DET FACE CAR STEREO
I have a 3 speed fan switch that i am replacing, b...
Hello. I really hope the 2nd grey is simply a faded purple or green. The most common configurations would be: L - Black, 1 - Grey, 2 - Brown, 3 - Purple or green. Here's a link to some troubleshooting advice: http://www.ceiling-fans-n-more.com/ceiling-fan-pullchain-replacement-and-repair.php and a link to diagrams: http://www.hurontel.on.ca/~taitg/pages/cfan.html
Hope these help clear up that nasty faded color for you, and don
May 21, 2010 | Speed Ceiling Fan 3-speed Switch By...
I have a fairly old panasonic car stereo/cd changer. i just need the wiring diagram for it. what color equals what? i typed in the model number but nothing turns up. . . i had to replace the old system,...
Here is the Colors of the Cars factory harness
Constant 12V+ Red Switched 12V+ Red/White Ground Black Illumination n/a Dimmer Orange/White Antenna Trigger Yellow Antenna Right Front Front Speakers 3 1/2" Dash Left Front (+) Green Left Front (-) Green/Yellow Right Front (+) Purple Right Front (-) Purple/Yellow Rear Speakers 6" x 9" Rear Deck Left Rear (+) Brown Left Rear (-) Brown/Yellow Right Rear (+) Blue/Red Right Rear (-) Blue/White
And Here is the Chart for the radios wiring
Red 12V+ Switched power
Grey Right front speaker +
Grey with black stripe right front-
White left front +
white with black stripe l/f -
Purple R/R +
Purple with black stripe R/R -
Green l/r +
green with stripe l/r -
Black ground
orange illumination
yellow constant power
Apr 07, 2010 | Car Audio & Video
I have a 3 speed hampton by fan. i'm trying to change the fan switch. i bought a westing house switch and have trouble wireing it. the fan has 4 wires blk purple brown and white.
The black wire should go to one side of the switch, and either the purple or brown wire would go to the other side. The fan is run by either purple or brown, and the light by the other color. If you have no light, then the wire that would go to the light should look unused. Try one, then the other if you guess wrong.
Turn off the power before connecting the wires.
Good luck.
Jan 06, 2010 | Westinghouse Electric Westinghouse...
For the Clarion DXZ945MP CD Player for car audio, I do not know the the wire harness color wire diagram? The wiring harness on my Monte Carlo 2000 reads what color wire goes to what, on the side of the...
3amp yellow battery for deck
15 amp yellow is another battery wire
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
red accessory
hope this helps
pls rate cause people arnt rating
Nov 05, 2009 | Clarion DXZ945MP CD Player
Hunter cieling fan switch replacement
My switch broke, so I'm in the process of replacing it.
Before taking it apart, I made note of the wire colors:
L=Black
1=Grey
2=Brown
3=Lt Blue
Jul 18, 2008 | Hunter 20761 52'' The Stratford II Brushed...
Oasis Hunter 54' Ceiling Fan Logo
2,689 people viewed this question
Top Oasis Dryers Experts
Are you an Oasis Dryer Expert? Answer questions, earn points and help others
