I synched an album from windows media player -- the songs show up in the synch pane in correct order, but they are out of order when they get to my MP#
SOURCE: Synching songs to Sansa m240
YOU MIGHT NOT HAVE SYNCED RIGHT....YOU MIGHT NEED TO DRAG AND DROP YOUR FILES OR CONSIDER GETTING A SANDISK E200 OR A CX00 VERSION MP3 THEY ARE MUCH EASIER TO WORK WITH
SOURCE: synching to mp3
I use media player to sync mine, but if you do not install the software, sometimes the computer will not recognize the device and will not sync.. the players should show signs of movement when it is syncing..
Hope this helps
SOURCE: How do i add album art to iriver x20?
if your using wmp11 you should just be able to drag and drop.
if not right click the song/album and go to advanced tag editor, pictures and then add manually.
half the time it just wont come up because the tag doesn't read properly and the other half the album art that wmp11 downloads and applys automatically will come up!
its kind of up to chance! if you're lucky it works if not live with it its the X20!
ps the iriver plus 3 and itunes also can apply album art
SOURCE: coby mpmp3 player won't play all my songs
This unit only accept MP3 or Unprotected WMA files. The audio file your trying to play is probably protected, make sure what your adding is MP3 is the safest way to go, as those cannot be copyrighted.
SOURCE: Suddenly the sansa will not synch with Windows Media Player.
When you attach your Connect via USB to your computer, verify that the Connect is displayed as a "portable media player" under "My Computer" in Windows Explorer.
If it isn't ... try a different USB port. The Connect requires a high-power USB port, which is typically found on the back panel of your computer.
If this doesn't work, try the Connect on another computer (just verify that it shows up under "My Computer", as I mentioned). If it does, you may have a problem with the installation of WMP on your computer ... try re-installing WMP, and make sure you install the latest version of WMP. If the Connect isn't recognized on the other computer, it's possible that there is a problem with the USB cable - get a replacement.
