Question about Danby DKC646BLS Full Size / Pony Beer Keg Cooler
Kegerator temp all over the place (DKC645BLS)
The temperature was all over the place. I'm trying to find replacement circuit cards and replacement buttons from above the door. Meantime, I've unpluged the unit and then disconnected the ribbon tape from the circuit card to the control buttons on the front of the unit and the temperature is now stable. Sure, I can't adjust it, but it's no longer frezzing my kegs to 21 degrees. Cheap plactic & paper push buttons!
  • 99 Answers
SOURCE: Major leaking with kegerator (DKC645BLS)
Using a tray is not the answer. Your tapper is not propperly lineing up with your kegs inlet. Try replacing your tappers washer and o ring, if this does not work you need to replace the tapper itself. It is most likely bent and not propperly lineing up.
Posted on Jan 26, 2008
huuum
  • 750 Answers
SOURCE: Temperature - Is fan supposed to constantly run or is it controlled by thermostat
You said ,Top half of Danby DKC645BLS refrigerator 10 degrees warmer than bottom half. Bottom half cooling to approx. 34 degrees.
Is it running all the time without cycling off and on as it should be doing?
Sorry to have to tell you this news.
But this would mean a bad thermostat or insufficient freon in the cooling system.
The same issue with the fact that one compartment is warm and the other is cool!
Let me know that service tells you!
Thank You
Huuum
Please remember toleave a rating
Posted on Oct 19, 2008
SOURCE: need a parts list for
I can obtain part breakdowns and replacement parts on danby appliances , Erin @ Jeffreys appliance service (509) 928-7176
Posted on Mar 17, 2009
SOURCE: i have a danby kegerator that is spitting foam new
Turn off the co2 for now. Turn it on when you need it, but start at a much lower pressure like 2-4 psi. Adjust pressure as needed.
Posted on Apr 21, 2009
SOURCE: Where do I get replacement parts for a Danby
I have Danby keg cooler touch pads in stock, the touch pads are the most common failing part on the coolers, I also have access to many more parts as well as technical assistance, please ask for Erin (509) 928-7176
Posted on Mar 11, 2010
I have a danby kegerator and the code LE keeps flashing
Sounds like a faulty temperature probe or faulty temperature control circuit. Some modify their unit with an external temperature controller. It does require knowledge of wiring to perform the modification. There are detailed notes, images, etc provided by psychodad at
Thread Danby Kegerator Improvements Part II
Aug 27, 2014 | Danby DKC645BLS Compact Beverage Cooler
Temperature controller malfunction
the adjustment dial , they are usually dirty from accumulated dust . at any auto parts store you can purchase a can of electrasol , unplug unit , spray into the middle of the switch, as you turn the switch, rapidly all the way around in both directions , repete this .. 2--3 times . look if possible, at the connections on the back of switch are clean ,and have good contact ... let device dry completely before plugging it back in and turning unit on.. let me know , good luck StevenT...
Jan 04, 2014 | Danby DKC645BLS Compact Beverage Cooler
Kegerator is flashing "EE" and
I bought a new kegerator and the same thing happened right out of the box.
The display was not pluged in.take Take screws off top and check to see if it pluged in.
Nov 18, 2010 | Danby DKC645BLS Compact Beverage Cooler
Where do I get replacement parts for a Danby Kegerator Model DKC645BLS ?
Feb 04, 2010 | Danby DKC645BLS Compact Beverage Cooler
Thank You
Huuum
Oct 19, 2008 | Danby DKC645BLS Compact Beverage Cooler
Danby DKC645BLS Kegerator not keeping beer cold
insulate the tower with pipe insulation, there is a hole in the bottom of the tower. don't over insulate or it will freeze.
Aug 12, 2008 | Refrigerators
i had the same problem with mine. i fixed it by removing the guts from the faucet and reversing the seal on the closing part. the seal was on backwards, flipped it and no more leak.
Jun 14, 2008 | Danby DKC645BLS Compact Beverage Cooler
Temperature light control (kegerator DKC645BLS)
Not sure u have a problem.. all appliances dont HOLD a certain.. Temp.. They cycle.. come on for awhile reach a temp the shut down.. goes so low the comes back on... the middle of the cycle is the avarage temp... yours being 36 from what you posted
Sep 04, 2007 | Danby DKC645BLS Compact Beverage Cooler
Danby DKC646BLS Full Size / Pony Beer Keg Cooler Logo
42 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
