Question about Samsung TX-P3264 32" TV
Samsung TX-P3264W emits high-pitched whine and blank screen
TV does not power on. Red light on power button blinks but screen remains blank. Also, TV emits high-pitched whine. I suspect the flyback transformer is causing the problem. However, someone told me to also replace the horizontal transistor. I don't know where to find this component inside the TV. Is it near the flyback? If anyone could please confirm my problem and tell me where the transistor is located that would be awesome. If anyone has a schematic or service manual of any kind that would be great too.
5 Suggested Answers
SOURCE: high pitch sound comming from tv!
The horizontal transistor and the flyback are damaged
Posted on Apr 24, 2008
ladywinn
  • 5138 Answers
SOURCE: Replaced Flyback Transformer and Horizontal Output Transistor
I am proud to see you got your set working Good job!
Posted on Aug 26, 2008
SOURCE: 36" RCA- loud whine/squeal when it is plugged in, otherwise no power.
The HOT Hortz output transistor has gone home, 99% of the time from a faulty IVHT (Flyback Transformer), very common on the ctc187cl* chassis. The factory Flyback is no longer available, I have had problems finding an aftermarket one to replace it with.
The HOT is a BUH517, but you can also use a 2SD5129. It is the transistor mounted on the siler heat sink with a metal clip rather than a screw, just in front of the flyback.....
If you replace just the HOT, most of the time you will get a rapid arc (27,000volts - BE CAREFUL!!!) from the lower (yoke) post on the flyback. If the flyback is shorted, It may also just burn out the HOT and go right back to "squealing"....
Good luck finding the flyback!!!
Posted on Feb 24, 2009
gsalmen
  • 77 Answers
SOURCE: My TV won't power up but is emitting a sharp,
the flyback transformer has failed.
Posted on Jul 09, 2009
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
Dec 16, 2015 | LG 55LE5400 TV
Samsung TX-R2765 not turning on.
I have the exact same problem!! Did you ever get a solution for your problem dkwb71?
Jul 18, 2010 | Samsung Televison & Video
I have a samsung neo 32 inch picture tube tv. When I turn it on there is no picture or sound, but there is a light high pitched noise.
That high pitched sound is likely the Horizontal Output section trying to work. It operates at 15,750 Hz or at the upper end of normal human ears.
It will sound like a high pitched whine.
This is a section or your television that you don't want to fool with unless you are quite familiar with servicing your set. There are very high voltages involved and only a qualified technician should tend to this defect. It maybe easy to fix or it may be quite involved. Get an estimate first then decide to go further or not. There is a potential fire hazard here so don't operate your set until this is resolved.
Zashiban
Jun 23, 2010 | Samsung DynaFlat TX-P2764 27" TV
Hitachi Ultravision won't turn on
it is the power board in the tv hase some bad capasators in it but can cost some money to fix if unsher how to do it on your own if you live in central new york i do have my own shop and im cheep but i can not warenty any thing but i can help 315-280-0508 storm electronics ask for corey
Aug 04, 2009 | Hitachi UltraVision 42HDS52 42 in....
Samsung projection 42 in. floor model, powers on
tv is in shutdown, drawing to much current. usually focus or high voltage divider (sometimes they are one). not usually the power supply.
Jul 05, 2009 | Samsung Televison & Video
Hln43w. Screen went dark. 3 lights on front flashed, and TC emitted a high pitch whine. Replaced lamp. 3 lights no longer flash, but whine is still present and screen is still dark.
if there anything like commercial flourescent cieling lights, there is a unit called a ballast which may be responsible for the symptoms you are observing.
May 29, 2008 | Samsung Televison & Video
High pitch sound comming from tv!
Apr 24, 2008 | Samsung TX-P3264 32" TV
High pitched squeal from TV
Get a small wood/plastic stick and touch the different coils/transformers to see which one is the cause. Replace part or if the part doesn't run hot, use a small amount of hot melt to quiet. Don't completely encapsulate in glue, don't want to create any hazards.
Oct 29, 2007 | Samsung TX-R2779H 27" TV
Samsung TX-P3264 32" TV Logo
512 people viewed this question
Henry  Thomas
Henry Thomas
