Question about InFocus 1:2 Distribution Amplifier (HW-VGA2OUT) 2-port KVM Switch
I have rotel amplifiers when i connect my speakers the amplifier stop working
    President:
  • 1,285 Answers
Check the ohms on the amp output and the amount of ohms on the back of your speakers they should be the same (or at least the amp should be more) ....your speakers may be overpowering your amp
Posted on Jul 09, 2009
HALLO I HAVE A ROTEL RA 9858X AND AGTER PLAYING FOR A FEW MINUTES I LOSE THE RIGHT SPEAKER CHANEL
Try interchanging the speakers. If the right channel works, you have a problem with your speaker.
Jun 14, 2014 | Rotel Audio Players & Recorders
Integrated amplifier for Mordaunt-Short Avant 908i
Use an amplifier with NO MORE than 150 Watts per channel or you be buying new speakers. At this power level don't expect booming bass boost without damaging the speakers. The Rotel generates 130 per side which is very near the safe maximum for those speakers... and the specs look good. If you are not satified with the sound, the speakers are LIKELY the problem. Look at getting good commercial speaakers instead of CONSUMER grade speakers. Go to a music store dealing with bands and musicians and view the products they have to offer. Consumer speakers often fail when people turn up too much bass. At high listening levels hearing damage can result.
Aug 02, 2012 | Audio Players & Recorders
No sound to remote speakers in dining & deck areas.
Incoming from WHAT? Ampifiers accept inputs via RCA connections and send amplified audio to the speakers via the + and - OUTPUT terminals.
I'm guessing your colored wires are from your speakers and that there is a piece of this puzzle we do not see - how the speakers on the deck and in the dining area are wired.
You say, "was working ok previously"... previous to WHAT? Something changed.
You can probably troubleshoot and resolve this yourself.
Set the amp to a medium output level.
If the wires are simply leading to either or both pairs of speakers you could select any two of them and connect them to one side of the amp. Only a pair going to the same speaker(s) will produce sound. Once you identify one pair, the other pair probably goes to the other speakers. Connect them to the other channel output.
The last piece would be to establish correct phasing between the speakers. Bass response will suffer if they're not IN-phase. Play something with substantial bass. Listen closely, then reverse the wires on one side only. Test again. If it IMPROVES you have it right. If it losses bass, put the wires back the way they were.
Apr 27, 2010 | Rotel RMB-1095 Power Amplifier
Rotel processor bypass for Audio Research SP10
If I understand you, the 'sound' of the AR preamp is what you're trying to preserve. Presumably you're just running a phono through it as nothing else needs a preamp these days.
The multichannel inputs bypass all of the Rotel's processing except the volume. Use the Front L and R.
Mar 12, 2010 | Audio Players & Recorders
Rotel power amp
some amps have a switch to bridge them rather than wiring a bridge meaning output is mono check to see if yours has this switch if you do simply put back to stereo
May 20, 2009 | Rotel RMB-1095 Power Amplifier
Right speaker jack not working
Why would it die from being in storage? Oxide or corrosion on contacts, volume potentiometer, Tape Monitor or other switch contacts.
Try manipulating all controls and switches throughout their ranges many times and see what happens.
Check the heaphone jack. If it works so does the right amplifier. While you're at it, insert the headphone jack multiple times to cycle its contacts, too.
May 18, 2009 | Rotel RMB-1095 Power Amplifier
Help with my power amplifier
This sounds like there is a problem with the final output stage. Is this a new amp? Is it under warranty?
Dan
Oct 08, 2008 | Rotel RMB-1095 Power Amplifier
Rotel RMB-1095 Power Amplifier Problem
Sounds like wiring problems. Unhook everything, then get owners manual for proper instruction
Apr 13, 2008 | Rotel RMB-1095 Power Amplifier
Rotel Amp center channel out
if you say you checked the wireing ,did you check the speaker. disconnect on of the other speakers and connect up the center to see if you get sound. still no sound speakers bad. Got sound try unpluging unit for a couple of hours then try it again. still no center . Time for the repair shop. Good Luck
May 26, 2006 | Rotel RMB-1095 Power Amplifier
InFocus 1:2 Distribution Amplifier (HW-VGA2OUT) 2-port KVM Switch Logo
Top InFocus Computers & Internet Experts
Marko Kmeti?
Marko Kmeti?
Level 1 Expert
jasbo
jasbo
matt
matt
Are you an InFocus Computer and Internet Expert? Answer questions, earn points and help others
