Question about GE Ovens
Trouble replacing my old ge oven part. I am
Trouble replacing my old ge oven part. I am replacing wb27k5273 with wb27t10265, and the wiring is different.
  • bovi2222 Jul 01, 2009
    NO IDEA WHAT YOU SAYING. YOU SOUND AS A FOREIGNER, AND NOT MAKING SENSE DIRECTIONS OF ME REPLACEMENT PART
  • bovi2222 Jul 02, 2009
    sorry, you just did not make sense.
    President:
  • 392 Answers
Your (wb27k5273)original have the following wires: Bake - Yellow Broil – Violet L1B - Black AUX2 - Black (Different than L1B) AUX 1 – Grey OVL2 - White OVL1 - Brown L1A - Black (connected to L1B) N - White (connected to OVL2) GND - Green
new board (wb27t10265) connections mentioned below...
BAKE - First module has YELLOW and a second terminal. Yellow | __ Nothing plugged in. BROIL – Second module has VIOLET and two additional terminals. Down beside the module on the board is marked L1B there is not a terminal on the board. connect the L1B to the module. Violet __ | L1B marked on board not on module
Posted on Jul 01, 2009
Touch pad all lit up on GE 30 " slide in range
locate service manul / wiring diagram comees with all usually convenietly located taped to back inside pannel. shut off breaker , or slide out an unplug, read, manul if present plug back in fallow the set up steps,an trouble shoting. press,bake, set temp,and press start press timer,set timer ,and,press start again.should do it,.if not check for loose wire on oven senser.possible touch pad replacement. worst case. good luck
Feb 22, 2013 | GE Ovens
I have just installed a new electronic control in my JTP45 Electric double oven. (part WB27K5273). I have a schematic, but so far have not figured out why that when I open the door the unit turns off and...
It does sound like a wiring mistake. Check all the connections and the wire colors against the colors on the Tech Sheet wiring diagram (which is normally taped on inside the control panel). Particularly look closely at how the door switch and lock connector is plugged in. You may have reversed the plug.
Best Regards,
Bruce
www.fixyourboard.com
Jun 18, 2010 | GE JTP45 Electric Double Oven
Receiving F3 Code
HI, no need to replace the unit at this time. this is a Open or shorted oven temperature sensor (RTD).
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Jul 16, 2009 | GE JRS04 Electric Single Oven
I need the squematic wiring GE 24" Built-In Gas Oven
I have the same problem -- did you ever get this question answered?
Feb 28, 2009 | GE 24" Built-In Single Gas Wall Oven
GE P7 Wall oven had bad thermostat????
IF YOUR HEATING ELEMENT IS GETTING ORANGE HOT, AND CYCLING, I WOULD SUSPECT THE THERMOSTAT TO BE THE SOURCE OF THE PROBLEM. YOU MAY FIND IT HARD TO FIND ONE THOUGH DUE TO ITS AGE.
Jan 28, 2009 | GE JKP50SH Electric Double Oven
Ge oven install
go ahead and wire the blk to blk and the red to the white as long as the data plat on the old oven say's 220 you should be ok
Dec 26, 2008 | GE Profile JTP56 Electric Double Oven
Ge extra large self cleaning oven xl44 mode jgbp28ded1wh
Check to see if the ignitor glows in the oven. If it does not come on or comes on very dim, you have a bad ignitor. It is usually a bad ignitor. They are very simple to replace. Just unplug the oven first. Then take off the bottom of the oven floor inside the oven to access the ignitor. the ignitor has 2 wires going to a plug, just unplug the plug and remove the mounting screws. Take your ignitor to a local appliance store to get a replacement. There are 2 models of ignitors so bring the old one with you to make sure you get the right one. Good luck..
Oct 07, 2008 | GE JGRP20 Gas Single Oven
Ge oven problem
door lock is not work check wires motor and switchs.. you may have to replace the door lock
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
Ovens Logo
186 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
