Question about Kitchen Ranges
Older model cook top has five wires 4 hot one ground, Wire from pannel is 2 hot 1 common 1 ground. Have power but no heat
    Problem Solver:
  • 6 Answers
Posibility is that loop each of the 2 hot wires from the panel to connect 4 hot wires to cooker
Posted on Jul 02, 2009
Should common wire and ground wire be connected together in breaker box in house
IN A BREAKER PANNEL U HAVE TWO HOT LEGS AND A NEUTRAL COMMING (PLUS GROUND). THERE SHOULD NEVER B ANY SPIiCES IN YOUR PANNEL JUST STRAIGHT CONNECTIONS. COMMON REFERS TO A TERMINAL WHERE U WOULD CONNECT A HOT WIRE. NEVER CONNECT GROUND TO A COMMON TERMINAL. ONE HOT GOES TO ONE LEG AND THE OTHER HOT GOES TO THE OTHER. THE NEUTRAL TIES TO THE NEUTRAL BAR WHICH IN TURN SHOULD BE BONDED TO THE GROUND BAR. JUDGING BY the way u asked your question u should reconsider doing this project yourself
Mar 12, 2014 | Health & Beauty
I am trying to wire this unit to a honeywell t stat model T87N1026
Wiring a new sub-panel to an isolation transformer is one method of wiring for balanced power. With a balanced power system, the power sent to each "hot" bus of the power panel is 50 percent per bus. This means that the total power of the system is split evenly between each side of the panel. Balanced power systems have the advantage of reduced noise generation. This characteristic makes this type of system great for audio.
1.Shut off the power feeding the isolation mains transformer at the main power panel. Use the documentation supplied with the isolation transformer to locate the center-tap wire on the secondary side of the transformer. Connect that wire to the sub-panel's ground bus bar.
2.Route the remaining two wires from the secondary side of the isolation transformer into the sub-panel. Loosen the two "hot" wire main bus screws in the top center section of the sub-panel. Strip 1/2-inch of insulation off of the two wires.
3.Insert each wire separately into each of the wire screw terminals.Tighten the screws to hold the wire in place. Do not over-tighten these screws. If there is a neutral wire, connect it to the neutral common bar. Once these screws are tight, close the sub-panel.8_8_2012_9_21_38_am.jpg
Jan 18, 2011 | Heating & Cooling
Hello I just bought a Kenmore Electric Range and I am now installing it in my kitchen. I am attempting to connect the power to the range. I have a large romex looking wire coming from the house wall....
Are you trying to connect your range to a 3-wire source, using a 4-wire cord? I'm a little confused on your symptoms. Normally you have a 2 HOT leads and a NEUTRAL/GROUND (3-wire) in older homes. In newer homes you have 2 HOT leads, a separate NEUTRAL and a separate GROUND (4-wire).
The following link explains the difference between the two configurations and how they should be correctly wired:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
New construction homes built after the year 2000 REQUIRE the use of a 4-wire plug and are usually readily wired at the receptacle to accommodate. If your existing receptacle already has a 3-wire configuration you do not need to re-wire it, however. The easiest solution would be to purchase a 3-wire power cord that matches the receptacle you have.
Read through the link provided and post back and let me know if you have any questions. I hope this helps you solve your problem.
May 22, 2010 | Microwave Ovens
The dryer has a four prong male plug and the outlet is a three prong female - which do I change? the dryer cord is the easiest, but how do I connect the leads?
4 PRONG PLUG WIRING: 2 HOTS(RED&BLACK) 1 NEUTRAL(WHITE) 1 GROUND(GREEN). 3 PRONG PLUG WIRING: 2 HOTS&1 NEUTRAL. YOU MUST USE 2 HOTS & 1 NEUTRAL ON A 3 WIRE PLUG. THE GROUND WIRE(GREEN) WHICH IS HOOKED TO FRAME OF THE DRYER IS NOT USED ON OLDER 3 WIRE PLUGS. IT IS AN ADDITIONAL SAFTEY GROUND ON NEWER MODEL 4 WIRE PLUGS.
Dec 25, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer outlet does not have common wire.
You can replace the 4 prong with a three prog cord found at Lowes etc.
First, disconnect the black wire, one of the "hot" connections, from the left side post by removing the terminal screw. This is one-half of the 240-volt connection.
Next, disconnect the red wire, another of the "hot" connections, from the right side post by removing the terminal screw. This is the other half of the 240-volt connection.
Then, disconnect the white wire from the center connection. It is used for the neutral connection.
Now, disconnect the green wire from the machine case by unscrewing the green screw.
The next step is critical to return your electrical connection to factory condition before installng the 3-prong cord! Locate the white machine wire that is now connected to the neutral (center) screw terminal. Disconnect it from there and install it under the green ground screw.Connect the outer two wires (hot wires) to the outer two screws, obviously, one on each screw.
Now connect the center wire (neutral) to the center post. You'll notice the white machine wire is now the case ground connection, unlike the 4-prong cord connection in which the green wire from the cord makes the ground connection.
Sep 10, 2009 | Dryers
Ground rod placement
If this is a Sub pannel that is fed from a main pannel then you don't need a ground rod for it, but you do need to run a ground wire in the cable that feeds it. So if it is fed by a 220 volt breaker in the main pannel it needs both hot wires, a neutral, and a ground wire in the cable.
Also when you get to the pannel do not attach the ground bonding jumper to the neutral bus in the sub pannel. each of the 4 wires will be seperated at the sub pannel.
Presto.
Aug 24, 2009 | Electrical Supplies
Whirlpool Electric Cooktop Wiring
sound like you have a three wire setup on you house most commonly the black wire is the L1 wire or one of the hot wires and the red is the L2 wire and is also one of the hot wire in this instance your white wire would be your neutral/ground wire this would connect to the copper wire on your cook top depending on the model it would have a red wire a black wire and the copper wire but some may also have a white wire also if this is the case on a three wire setup you would attach the copper and white wires together also if needed you can goto the maufactures website and download an instalation guide.
Mar 25, 2009 | Whirlpool GJC3034 Electric Cooktop
3 wire cook top to a 4 wire outlet
Older 3 wire connectors where Wht=Neutral Ground Return, Red=One Phase Hot, Blk=Second Phase Hot, of 220VAC stove connections.
Newer Electrical code standard has a forth wire that is bare copper for a separate safety ground return.
I suggest you but a 4 wire pig tail cable for your stove top, available at Depot or Lowes, and connect 3 wires of this 4 wire cable just like the 3 wires are now connected. The 4th bare copper safety is attached to any metal part of the stove. Find a screw you can loosen to wrap it around and tighten.
Mar 02, 2009 | Jenn-Air JED8230 Electric Cooktop
Wiring 4 wire cook top to 3 wire outlet
What you have is a 220v and a 110v circuit within the cook top. It needs a 4 wire feed to supply 2 hots, 1ground, and 1 neutral. The 3 wire outlet only has 2hots and a ground no neutral, which will probably not allow your control circuit to operate. You nee to run a neutral wire to obtain a 110v circuit. DO NOT try to run neutral off the ground or you will energize your cook top cabinet and it will shock you. Your solution is to run a neutarl wire from the closest circuit that you can find.
If you need further asst.
Eboukater@gmail.com
Sep 24, 2008 | Jenn-Air JJW8530C Expressions Collection...
Wiring diagram
This model of cook top needs the 4 wire install because it has both 220v and 110v circuits. The forth wire is a neutral that operates the 110v circuit. You can move the ground of the 3 wire outlet to neutral, but ONLY! if the ground wire is insulated. What this will do is give you both your 220v and 110v circuits. The problem with that is your cook top will not be grounded. The best solution is to locate a neutral wire and tap into it, this will give you your 4 wire circuit. Your missing a neutral in a 3 wire outlet.
More Asst.
eboukater@gmail.com
Kitchen Ranges Logo
95 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
