Jane powertrack 360, just bought one and washed all seating and hood put it back together again but dosnt look right, is the hood supposed to be over the side flaps or under?? them .........please help
Approximately 20kg is said to be the upper weight limit or four years old depending on how comfortably they fit in the chair.
This answer is for the Jane Powertrack 360.
Now this is a tricky one to explain via a message. Have you managed to sort this out yet as I have a user manual on aa pdf format that I could email to you?
To fit the Jane Capazo Carrycot succesfully, this depends on your car. It needs to use two 3 point seat belts. 2 point seat belts don't work. Plug in both seat belts, and pull the lap belt part through the red catch on both side. Pull as tight as you can. To make car seat fitting more secure, try placing a slip mat like the Sunshine Kids Grip It or Super Mat underneath to hold it in place. These are all crash tested and safe.
there is a small metal handle behind each seat, pull it up while you move the seat into the recline position you want - rear seat has four positions, front seat has two. :) Jan.
There should be two black triangular attachments with little red handles that go on to the sides of the buggy. You use the grey handles at the end of the side arm of the buggy to pull the rear locking pins backwards and then slot the attachments on to the front pin with the red handle pointing forwards. Release the grey handle and it will lock into place. When both sides are in place, simply drop the car seat on to top of the two attachments. Removal of the car seat is by using the red handles.
HTH..
