Question about Black & Decker Tools & Hardware - Others
I have a rechargeable 18V B&D nail gun I bought for crown moulding. Now I want to change the size (length) of the 18ga nails but I can't figure it out and the manual gives no clues. It is currently loaded with 2" and I want to go shorter. Can you help?
    Sergeant:
  • 384 Answers
Take the long nail strip out and replace them with the shorter length nails.
Posted on Jul 01, 2009
Air gun "clicks"
Sound like o rings are bad. If you don't know how to rebuild it then have a tool repair shop rebuild it.
Jul 27, 2013 | Campbell Hausfeld 2" 18GA Brad Nailer
The nail gun will not shoot
I don't have that same model but my gun started doing something similar a while back. I was able to disassemble the head of the gun and found that the hammer or piston that drives the nail had rounded itself off and wasn't able to make good contact with the nail head. Instead it pushed itself on top of the nail and got wedged. It's nearly impossible to see the stuck nail or dulled piston head without taking it apart. Hopefully this will help.
Oct 18, 2012 | Arrow ET200 Electric Brad Nail Gun
I bought a used Bostitch nail gun. Model/serial # N6408406208021. What parts do I change to go from a 1 1/2 inch nail (approx. #6) to a 3 inch nail (approx. #16)? Where do I get the parts?
I do not think that the n64 will take a 3" nail. N64 will most likely fit a 2 or 2 1/2 inch. To verify the length of nail open latch door and measure the width of the slot into the barrel. Take a look at the bostitch n80 series of nailers for more power and longer nail.
Dec 18, 2010 | Stanley Bostitch Coil Framing Nailer
Nailer has very little power.there are no nails jammed
What about the compressor,? Is it up to 120 lbs? Does it have a reg on it? Most nail guns run at full steam, no need for the reg at the comp. If the gun isn't leaking air, It should be working. Check it out.
May 23, 2010 | Campbell Hausfeld 2" 18GA Brad Nailer
Need help loading staples in my Stanley electric staple/nail gun
there should be a button / lever at the rear press it and it should open so as to insert the staples
Apr 05, 2010 | Stanley Staple/Nail Gun Elec
Putting the nails inside the gun
Here is the manual http://www.arrowfastener.com/upload/manuals/79055020257_manual.pdf
Eric
Jan 24, 2010 | Staples Arrow T2025 Staple Gun For Flat &...
How do you secure an outside corder of crown moulding on top of kitchen cabinets
The base of the outside corner where it meets the cabinet is nailed to the cabinet, the top section that stands out can be secured to the other corner part with a nail across the joint.
If the crown is set to meet the ceiling, then it should be secured there, if the crown is below the ceiling, a brace block can be mounted to the cabinet behind the crown. The outer edge of the brace is cut with a bevel at the same angle as the crown, and the crown is nailed to it.
Oct 23, 2009 | Amana Crown Moulding Bit Type #1
Cambell-hausfeld framer
its double firing, after firing gun pull back, what is happening is when you fire a nail your pushing the gun back onto the wood and its putting another nail in
May 08, 2009 | Campbell Hausfeld 2" 18GA Brad Nailer
Nail Gun cost
A good-quality starter set, including both a compressor and a small nail gun, can be bought for around 200 US dollars (USD). More sophisticated models can reach 1000 USD or more. Optional features such as a hard-shell case, safety trigger, and depth adjustment can drive the price even higher. For one-time jobs, a nail gun can also be rented at hardware stores and home repair centers.
Aug 27, 2008 | Bosch 18V Cordless Planer 53518
Tools & Hardware - Others Logo
116 people viewed this question
Top Black & Decker Tools & Hardware - Others Experts
Jim Goldsmith
Jim Goldsmith
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
