Question about Philips 50P8341 50" Rear Projection Television
Philips 50p8341a - the red converges, the blue does no move. the screen is all reddish with orange lines in it. the sound is ok. took the back off and the red and blue big lights are on, but the other big light does not light up. Is there a way to return the tv to the factory presets? Is the tv worth spending money on to fix?
    Scholar:
  • 150 Answers
Hi, convergence IC`s have failed, set is usually a good one, call your local tv shops and get a price to replace the "convergence IC`s ", good luck, video-tek
Posted on Jul 01, 2009
Philips model #50P8341A Picture is clear but orange.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 12, 2011 | Philips 50P8341 50" Rear Projection...
Philips projection tv model #50P8341A faded video with all the picture setting balanced
Please do us a favor and rate this solution after reading.
  • Screen looks 3D
69189a5.pngSOLUTION
Feb 16, 2011 | Philips Magnavox 51MP392H Rear Projection...
Yes my 60 in phillips rear projection tv model # 60p8341a the screen is a reddish orange color and wanted to know how to fix it
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
Dec 19, 2010 | Philips 60P8341 60" Rear Projection...
My Philips model 50p8341a 50" rear projection tv turns on, has sound but has no picture. Any ideas? Heard something about a convergence chip? Please advise.
you need ssb board is bad and you can,t git that part you can send to pts to have it rebuld. yes the stk 392-120 can drag the pix down but if you open it up you see a fouc blook go to the screen red or green or blue
turn it up just a litte the pix will come back. this is a know fact about this with this set i see a lot in my days of sevice ,at quaker tv
Dec 07, 2009 | Philips 50P8341 50" Rear Projection...
I've got a Philips 50P8341A Projection 50'' TV. My problem started with the screen only showing an orange image. The picture was clear and sharp, but there was no color other than orange. So I tried to fix...
Turn the top left knob down till the pic comes back and the reason your color is off is the fluids in the green and blue chambers needs to be changed.
Nov 12, 2009 | Philips Televison & Video
43 philips problem with green
Your TV most likely has one or more possible problems.
  • Screen looks 3D
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Jan 24, 2009 | Philips 43PP9202 43" Rear Projection...
Blue Multipoint converge failure Philips 55PP9753
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 12, 2008 | Philips 55PP9753 55" Rear Projection...
PHILIPS 50P8341A COLOR PROBLEM
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 15, 2007 | Philips 50P8341 50" Rear Projection...
Philips model 50p8341a projection
color is off. Faces are orange sometimes, all orange, or red? Tried the remote to fix however did not work.
Nov 22, 2007 | Philips 60P8341 60" Rear Projection...
Philips 50P8341 50" Rear Projection Television Logo
231 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
