Question about Mitsubishi Televison & Video
I have a VS 70709 not getting any picture
No picture but I do have sound
I have a VS 70709 when I ran the diagnostics I am getting 2 flashes then 3 flashes
    President:
  • Mitsubishi Master
  • 1,779 Answers
Code 2_3 is Horizontal Deflection Problem
Posted on Jul 01, 2009
Reset passcode for vs60609 Mitsubishi tv
check the english service manual
http://www.manualsdir.com/manuals/118985/mitsubishi-electronics-vs-60609-vs-70709-vs-60719-vs-45609-vs-55609-vs-50609.html?hl=ru
Mar 16, 2015 | Mitsubishi Televison & Video
Tv turns on for 20 secondsthen shuts off
There is short circuited component/s at its circuit board. If you're sound in electronics, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Flip card, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window. google.com/+GopakumarGopalan
Nov 02, 2013 | Mitsubishi VS-70709 TV
Screen was ok and suddenly make a noise as a short circuit and te screen went out
oops-This is dangerous for peple not trained in service 1-Possibly high voltage makes arc to ground.2-check horizontal output for bad contacts.
Oct 02, 2013 | Mitsubishi VS-70709 TV
Convergence adjust or repair
If you go into the convergence adjustment in the menu normally you can adjust up down side to side. If the convergence ic's have failed you wont be able to adjust at all or in every direction. There will be from 1-3 convergence IC's. All would need to be replaced. They are roughly 3 inchs long and 2 inches tall and begins with STK392-xxx. A repair center charges will vary from state to state and urban areas to rural areas. Roughly 220.00 - 260.00 would be a decent average.
Oct 17, 2010 | Mitsubishi VS-70709 TV
I NEED TO MOVE MY MITSUBISH VS 70709 UPSTAIRS AND I NEED TO KNOW HOW TO TAKE THE BASE OFF FROM THE SCREEN
This may be one of the models that comes apart--if it is on either side you will see two plastic caps--beneath are either regular bolts or L shaped ones you turn.
Most of the sets that had the feature needed the front screen removed first to do this.
If you do not see the black plastic caps (two on either side) it does not have that feature.
SD TECH
Sep 28, 2010 | Mitsubishi VS-70709 TV
Something buning back of tv red lines going off
Ur tv have convergence problems,it dead.Ur 2 STK convergence ICS are defective,and all or some of it supporting resistors.The shop will cost u $300-350 for parts and labors.
May 08, 2010 | Mitsubishi VS-70709 TV
My VS-70709 willclick when the power button is pushed, but will imeditaly turn right back off. Any ideas?
HI, you have a weak ballast. this is the power regulator for the lamp in your set. replacing the ballast will fix this issue.
Jul 23, 2009 | Mitsubishi VS-70709 TV
Tv is dim
Ned more info as do all things including the on screen display look darker then normal???how old is set??
Mar 31, 2006 | Mitsubishi VS-70709 TV
Televison & Video Logo
27 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
