Question about Poulan "Poulan" Push Mower
My Poulan runs for a few minutes then idles down shuts off. Get it running again does same thing
I have a mower that is not starting and when it dose is dies within seconds.. what could be the problem
Posted on Apr 11, 2012
  • 77 Answers
Check the governor spring to see if it is streched out or the bracket it attaches to is bent,this can cause the problem. Also the carb may need cleaned and rebuilt,if it contains a diaphram gasket it could be bad causing it to die.
Posted on Aug 09, 2009
IT WILL STaRT , RUN FOR 1 MINute AND SHUT OFF BUT WAS rUNNING WITH COVER OFF BUT NOW HAS STOPPED THAT IT WILL RUN FOR 20 SEcONDS AND SHUT OFF
What would cause 1995 Chevy blazer to run for 20 minutes ...
answers.angieslist.com > Auto > Auto Repair & Service
Mar 30, 2014 - For example, can you start the car cold, it will warm for 20 minutes, and shut ... While not a car, my Motorcycle (also fuel injected) would run for a little bit and shut off. The issue ... Answered 1 year ago by WoWHomeSolutions.
Car starts and it shuts off/loses power - CarGurus
www.cargurus.com > Questions > Audi > A4
CarGurusJun 20, 2013 - Car starts and it shuts off/loses power - I have a 2003 Audi A4 Turbo.93K on it. ... \n check out these few options 1. loose or faulty electrical connections at, .... After drying it for a few minutes and cleaning with a dry cotton cloth, I have ... you can't fill your car while its running the gas tank is a vacum while its ...
Car starts then dies in a few seconds - CarGurus
www.cargurus.com > Questions > Ford > Crown Victoria
CarGurusFeb 3, 2014 - Car was running fine, and then engine stops. ... 1 out of 1 people think this is helpful. ... my car will start run for a second an shut off . ... under load, dies,starts 15 minutes later, runs fine then stumbles and dies again 3 answers.
Chevrolet Silverado 1500 Questions - Engine Shutting off ...
www.cargurus.com > Questions > Chevrolet > Silverado 1500
CarGurusMay 20, 2015 - Engine Shutting off after about 10-20 seconds on 2004 Silverado ...When the engine is hot, two things occur: (1) thermal effect on .... my 2000 chevy silverado just randomly die then it will start back up idle .... It will run fine for 15minutes. ... run down behind or beside the powersteering pump, that the car will ...
Jan 06, 2016 | Cars & Trucks
Will not stay running
Clean carburetor-verify fuel line blockage-clean filters-make sure your gas/oil mix is correct-use fresh gas. They shut down frequently when setting them down-Increase RPM at Idle.
Jul 27, 2014 | Poulan P3416 16Inch 34cc 2Cycle Gas...
Car loses power for short time after normal running and cooling down for ten minutes
sounds to be symptomatic of a CTS (coolant temperature sensor). there are two, one is for the interior temp gauge, the other is for the ECU/PCM while both are basicalty the same part, often even the same P/N, they both do extremely different things.
Feb 24, 2014 | Ford Ka Cars & Trucks
Poulan 18" wildthing chainsaw (model
This could be a couple of things, if the fuel tank brather is blocke the tank will vacume, to test this try slackening off the fuel cap when the saw starts to die, if it picks up again it is a fuel tank braether issue, the other possibility is a bad ignition unit breaking down, the only test for this is to replace the unit and try again.
Sep 19, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Mower start fine. Runs for 20 min or so and then runs ruff and shuts down. Restarts fine and shuts down appr. 5 mins later. Has new spark plug,air filter, fuel filter and more than enough gas.
It's one of two things. My first thought is that you have a clogged gas cap. Try loosening it when the mower starts to run ruff. If it smooths out again and runs fine, then you know that the carburetor is not venting properly. Either buy a new gas cap or clear the breathing holes in the cap, if possible.
The only other thing it can be is that your Ignition Coil is going bad. A bad Coil, once it gets hot, will shut down. But it usually takes longer than 5 minutes for them to cool down well enough to start back up.
My Vote is the cap!
Good Luck!
Jim
Aug 18, 2011 | Poulan Garden
My car while running down the road will shut down lose all power. After the car site for about 15 minutes it will start up again and run for a few days and this will happen again. Before it shuts down the...
Sounds like an EGR valve sticking. Start the engine cold and let it warm up. As soon as it starts to hesitate/stumble, pull the vacuum hose off the EGR and if the engine maintains a steady idle, replace the EGR valve. The EGR is sticking intermittently but it won't be long before it sticks all the time and you won't be able to keep the car running when it gets warm. This is an easy diagnosis, removal and replacement for the do it yourself car owners. Please rate me on my answer.
Jun 30, 2010 | 1995 Jeep Grand Cherokee
Readyheater portable forced air 170,000btu/hr
reset switch my heater did the same thing after 5 sec of running
Dec 20, 2007 | Reddy Heater-170,000 BTU Kerosene Deluxe
Poulan "Poulan" Push Mower Logo
448 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
