Question about Sanyo Televison & Video
Channels 2 - 22 all snowy. 2 and up are all fine.
Snowy picture
The remote doesn't effect the channels, I would say you have poor signal or interference from another device nearby.
Sep 12, 2008 | Orion1934 19" TV
Some channels are snowy, there are now two golf channels and some say no signal, this is on the Emerson. The two other tv's in the house are fine.
sound like you are having input problems at the back of the set. snow indicates a weak signal coming in.
Sep 20, 2009 | Televison & Video
I have 3 digital tv's one in the lounge/bedroom and kitchen for some reason last night, the tv's in the bedroom and kitchen lost all digital channels and the analogue channels were very poor to view snowy...
Loosing digital channels is equivlent to a snowy analog channel, check you cable connections, and splitters to the tv, since you have two of them out, it does not make sense that it is your tv. It is a conneciton in your cable line somewhere.
Sep 02, 2009 | Televison & Video
Snowy picture on VCR with only certain channels
In all likelyhood, you have a bad ground somewhere in the cable. Try other channels through the VCR. If the ground is the problem, there will be a cluster of channels that are snowy with the rest being clear. Check the cable itself and all of the connectors along it.
If the cable and connectors are good, the tuner or power supply of the VCR could be faulty and cause this as well.
Dan
Dec 24, 2008 | Sony SLV-N50 VHS VCR
I HAD TV ON. EVERYTHING WAS FINE. ALL OF A SUDDEN, IT BECAME SNOWY. LIKE THE CABLE WAS OUT. SO, I TRIED UNHOOKING DIGITAL CABLE BOX. AND HOOKING CABLE STRAIGHT TO THE TV. STILL, IT WOULD NOT GO ANY HIGHER...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} With the snowy problem; it does sound like aerial has disconnected. Try putting your finger over the aerial socket hole behind the TV while TV is on (using your self as an aerial). If snowy disappears then you have an aerial plug/wire disconnection problem.
Dec 06, 2008 | Televison & Video
Snowy picture
.u need to replace the tuner of ur tv set...its a technical work better call service technician
Jun 28, 2008 | Samsung HL-R4266W 42" HDTV-Ready...
Rear projection snow
Bad primary tuner==can be replaced,or==by-pass by using video inputs.
Aug 26, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
1996 RCA Color TV model G27720tn
If you are on cable, first run the cable wire from the wall directly to the TV, eliminating any cable box and/or VCR. If channel 2 is snowy but the rest (especially 3-6) are clear, it is most certainly a cable problem and not a TV problem. The TV uses the exact same circuits for channel 2 to 6 (VHF-LOW) so if the tuner was bad and 2 was snowy, 3, 4, 5 and 6 would be snowy too. Bring a second TV into that room, disconnect the cable wire from the RCA and connect it to the second TV. Is channel 2 on the second TV as snowy as it was on the RCA?
Aug 18, 2007 | RCA 24V511T 24" TV
Intermittent snowy pictures under Channel 51
Probably needs a new tuner or something associated with the tuner.
May 31, 2007 | RCA F36673ET 36" TV
Televison & Video Logo
16 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
