Question about HP Compaq Business Notebook 6910p
When typing on my HP notebook (Compaq 6910p) I find the cursor jumping from place to place as I type.........Help. Doesn't seem to be any pattern to the issue.
  • HP Master
  • 4,806 Answers
The sensitivity of the touchpad maybe too high, this is a common problem and can be easily sorted.
Go into the control panel and select mouse, there you can set the sensitivity of the pad.
See if that helps any!!!
Good luck.
Posted on Jul 01, 2009
Is buying this Hp Compaq 6910p Battery a wise decision?
I have bought a couple of batteries from them before. They work just make sure that the voltage of the battery. (10.8v) matches the voltage on your battery. Also make sure that the mah 6600mah is greater or the same as the battery that you have. The mah is the mili ampers per hour (in other words the fuel) the bigger the mah the longer your battery will run. I also find ebay a great place to buy hp batterys from. Just make sure that they are oem hp and not a generic knock off and you will be fine and use the same rules from above. and also make sure they will fit your model number. I hope this helps
thanks
Steven.
Apr 24, 2010 | HP Pavilion dv6000z Notebook
Not getting sound
check your sound drivers,and the sound mixer
Apr 02, 2010 | HP Compaq 6910p Notebook PC PC Notebook
My girlfriend's hp is jacked up. whenever she
Hi, the problem is coming from the keyboard. you can test by plugging an external keyboard and try typing on the external. you can replace the laptop keyboard if necessary.
Jan 26, 2010 | HP Pavilion dv5tse Notebook
Cursor jumps all over the page
you are touching the touchpad portion of the latop while you are typing?
Jan 06, 2010 | HP Pavilion dv6t Notebook
Cursor jumps when typing
since you laptop mouse is touchpad. when you starts typing, your finger(hands) touches the touchpad which throw the cursor away. Make sure, while typing your hands does not touch the touchpad of the laptop.
Dec 02, 2009 | HP Compaq Presario V2000 Notebook
I am having a problem when I type and the cursor moving
This happens when your hands get to close to the palmrest and your wrists are actually causing the cursor to jump to another spot. Go to the control panel > mouse> settings > highlight the touchpad listed and select the settings button. Look through the entries and there is a setting for palmrest sensitivity. Turn down the sensitivity so your hands and wrists don't trigger a cursor movement. The hardware and drivers are fine, this is a setting adjustment.
Oct 10, 2009 | HP Pavilion DV6700T Notebook PC
Jumping cursor
You need to adjust the sensitivity of the touchpad
In the TouchPad Properties window you can access additional TouchPad preferences.
»To access the TouchPad Properties window, use the TouchPad to select Start > Control Panel > Printers and Other Hardware > Mouse > Device Settings, and then select the Settings button.
(If you follow this path using an optional external mouse, the TouchPad Properties window may be unavailable.)
Dec 10, 2008 | HP Compaq Presario V2000 Notebook
Run awat cursor
When that problem happens to me I turn off my pointer pad. I have a Compaq Presario and it has a button to shut off the mouse pad. When I simply shut it off it does not jump when I am typing. I don't know the originating cause but at least I can make the annoyance go away when it would bother me the most. Hope this helps.
Jul 13, 2008 | Acer Aspire 5315 Notebook
Cursor jumps around
Try this software:
http://code.google.com/p/touchfreeze/downloads/list
Touch Freeze will disable the touchpad when you start typing. I have not used it, but give it a try.
Also, your touchpad could be wearing out or a driver reinstall could be in order. My wifes Toshiba had a bad touchpad and the cursor would jump all over the place. I disabled it and she now uses an external mouse. No problems anymore.
May 15, 2008 | Acer Aspire 5610-4648 Notebook
HP Compaq Business Notebook 6910p Logo
234 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
