Question about Mitsubishi WD62327 TV
Mitsubishi wd62327 where is lamp housing located and how is it replaced
  • 3 Answers
On the WD-62327, you pull of the horizontal panel in the front that is just below the screen (this panel covers the speakers too).
Then, just to the left of center there is a panel with a few screws. Under that is the lamp housing that has 3 silver screws that are part of the housing and just unscrew, they do not come out.
Once those are off, you left the handle and slide it out.
Reverse to put in a new bulb.
Also, you should clean out the filter when you change the bulb. The filter is on the left side (looking @ from the front) and only has a few screws. Take off the panel and clean the foam(ish) filter and put it back on.
Probably wouldn't hurt to vacuum out any of the dust that is built up on the power supply fan in the back.
Posted on Apr 19, 2009
  • Amy Mutispaugh Oct 23, 2011
    If you go to Google search and type in "Mitsubishi WD-62327 Owners Manual download" you will find a website that lets you download it for free. In that manual you will see the pictures and steps to change the lamp yourself. It's not hard to do at all. Saves you lots of money for a service call too!
Where is the lamp housing located?
Posted on Nov 22, 2008
Recently the red light is flashing in stand by, is there a common issue with this ? WD62327
This is a common issue for DLP TV's the bulbs they have are made to last 2000-4000 life hours for Osram lamps this is the lamp the Mitsubishi usually uses so depending how old the lamp is this could be your problem I found the lamp you need for a good price
http://cgi.ebay.com/MITSUBISHI-915P020010-LAMP-PHILIPS-WD-52525-WD52525-/330465131739?pt=LH_DefaultDomain_0&hash=item4cf141bcdb
Sep 20, 2010 | Mitsubishi WD-62525 62" Rear Projection...
I have the Mitsubishi WD62327 62". I just changed the bulb which I did last year on my own too. My problem is not replacing the bulb but now the tv does not want to turn on. This did not happen to me last...
You need to reset the timer lamp. On mine it is getting the display to lamp then hold the left and menu button for five seconds.
If that doesn't work go to the mitsubishi site and DL the PDF of your model and it should be in there unless you have the paper manual still around.
Aug 11, 2010 | Mitsubishi WD-62327 62" Rear Projection...
Tv power light comes on but screen is black. Do I need to replace the bulb. It's model Mitsubishi WD62327
is there sound. first check the secondary filter capacitor and then check for dry join. don't forget to check the HOT transistor.
Sep 30, 2009 | Mitsubishi WD62327 TV
Need to replace lamp
On this model the lamp is behind the front grill, pull the grill off and you will find the lamp door in the middle it has two phillips head screws in it taske those out and you can look inside and see the lamp it has two flat head screws in it, loosen these all the way off, they do not come out of the housing, grab the handle and pull the lamp out, after you replace the lamp and before you try to turn the set on make sure the door is back in place and screwed down because it will not come back on if the door is not on.
Sep 04, 2009 | Mitsubishi WD-62327 62" Rear Projection...
Flashing red status light wd62327
Your lamp is getting ready to go!!! Better order a new on, it is approx. $236.00. I put a new lamp in mine (July 2007) just ordered another one this week. The first one that went gove me the warning of the flashing light, this time it just blew. I called 2 places and they said it is the lamp.You can order them online from Mitsubishi.
Feb 18, 2009 | Mitsubishi WD-62327 62" Rear Projection...
Lamp Cartridge
Well I bought my about three years ago and that warning was poping on for about a year. The lamp finally went out, I should have got a replacement sooner. But I ran it longer than it should have gone, I think I read the lamp should last about 2 years, I got an extra year out of it. Oh well time for a new one...
May 20, 2008 | Mitsubishi WD62327 TV
WD-62327 Lamp
OSRAM VS. PHILLIPS
This is about buying replacement bulbs for the WD62327 TVs.I dont know about the other models but I purchased a PHILLIPS replacement bulb and it worked for about a week and then those dumb flashing lights and no TV. I did some research and others were saying that you had to replace some condensers. Shop would do it for 600 dollars..Well i sent the bulb back and bought an OSRAM replaement bulb. The TV is now working perfect.
Sep 17, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Televison & Video Logo
444 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
