Changing to antenna
I just bought an antenna (since we don't have cable), and I need it to hook up properly. It's an indoor antenna. From what I think, I need to change the TV from thinking it's a cable source to an antenna source, but I do not know for sure how to do that, or if I need to.
The way I have it hooked up now I am not getting any signal basically.
Thanks!
  • blueextc3221
    blueextc3221 May 11, 2010
    do you have a HDTV converter box?
  • 458 Answers
Firstly, depending which reception area you are in, an indoor antenna may not give you a good signal across all your channels. If in you put the antenna into the aerial connector of the TV & if in your set up menu, there is an Auto tune option then enter this & it will tune in all the channels it can find. If not then select the Manual tune option & you will need to tune each channel as you find them. Follow the on screen instructions as a guide.
Posted on Jul 01, 2009
How do I hook up an indoor antenna to my Sanyo TV
There is a threaded connector marked cable/antenna. You use this connection to attach the antenna cable. Then you do a channel scan with the tuner set to antenna not cable.
Nov 21, 2016 | Sanyo Televison & Video
Esa tv digital to analog
Hi.I assume you can watch some channels, using your indoor digital antenna. As far as I know, you need an intermediate "box", or interface between the cable TV coming in, and the decoder. This has to be installed by the cable company. Between the decoder and the interface, there are two connections. One signal connection and one UTP wire connection for communication between both units.At least, that's how it works in Belgium and most other countries.
Jun 24, 2014 | ESA ET427E 27" TV
Need to know how to change and setup for use of antenna
Purchase your UHF/VHF antenna. The antenna can also be purchased at most electronic and retail stores. Consult your list from Step 1 and see how powerfulicon1.png the over-the-air signals are for your specific address. Purchase your antenna based on the broadcasting power you need to receive a clear picture on your TV. You might be able to get away with an indoor antenna if your signal strength is strong enough. If not, you'll need to purchase an outdoor antenna.
  • 4 Install your antenna (or have it done professionally) according to the building codes of your area. If you must use an outdoor antenna, it is a good ideaicon1.png to have the antenna professionally installed. This ensures that it is properly grounded on your roof, not too close to electrical wiring and stable during inclement weather.
  • 5 Hook the converter box up to your television using the cable that came with it (F Cable). Hook your antenna up to the converter Box. Turn on your TV and converter box. Tune your TV to channel 3 and press "Scan" on the digital convert box. Allow the box to scan for your available channels.
  • 6 View your picture and adjust your antenna accordingly for the clearest over-the-air feed. You should only need to make adjustments once. If you are having a difficult time getting a clear picture, use a signal strength indicator to see where you receive the most powerful signal.
  • Read more: How to Replace Cable TV or Dish TV With Antenna TV ' eHow.com http://www.ehow.com/how_5228282_replace-dish-tv-antenna-tv.html#ixzz2RrACTyTI
    Mar 29, 2013 | Sansui 19 in. LCD TV
    I just purchased an indoor antenna for to view local stations. Can i use an indoor antenna for my olevia 232-t11 lcd-hdtv? If I can, what steps do I need to follow?
    Yes you can use an indoor antenna. Just make sure it is an HD antenna to get the digital channels clearly. You will have to do a scan to pick up local channels. In the TV menu, it will ask you if you want to scan for "cable" channels or "antenna" channels. You want to choose antenna.
    Feb 11, 2013 | Olevia LT42HVi 42 in. LCD Television
    Advent tv indoor antenna hook up
    If the antenna has a cable like cable wire--hook it direct to the cable fitting on the set.
    If the antenna uses the flat type wire (called 300 ohm twin wire) use an adapter that will connect to the end and have screws for the flat wires and a cable slide on the other side to slide onto the cable fitting on the rear of the TV
    Mar 28, 2012 | Recoton Advent Advent DV1418A 14 in....
    Really? cool... so I have a Panasonic HDTV 720p... just moved, no cable, but I have a TV antenna. Amplified indoor antenna. GE brand model 24700. I powered and connected the coaxial cable between the tv...
    You need to go into on screen TV tuner/channel scanning setup page and change the signal source from CABLE to ANTENNA so it will scan again to pick up off the air signals. Please read the TV user manual for more details.
    What is the model number of the TV?
    May 15, 2011 | Televison & Video
    Don't have cable. Have the digital converter box and a indoor antenna...it's hooked up and TV is playing fine. After hours of changing every cable the VCR will not play. I get the sound of the movie but no...
    You can connect VCR, TV and converter box using coaxial cables OR you can connect using RCA cables. See this web page:
    http://columbiaisax.googlepages.com/diagram_dtv_tv_vcr.htm
    Using RCA cables, make sure you connect the yellow video cable. Select the proper input on the TV.
    Aug 12, 2010 | Televison & Video
    Indoor antenna problem with Magnavox LCD TV Model 15MF605T/17
    I have found most of these indoor antennae to be ineffective and a waste of money, however, I do not know anything about this particular antennae. I to have a Dish DTVpal, which I love! It's ugly and probably won't fit in your kitchen, but the best solution is to make your own "bow-tie" antennae, mount it indoors or on the roof and run a cable to the kitchen. Directions can be found on You-Tube. I live in SE Idaho (Pocatello) and can get 13 channels, most without having to adjust the antennae.
    May 27, 2009 | Philips Televison & Video
    IS MY TV DIGITAL?
    yes you will. either install an outside antenna or get a good amplified indoor antenna. try your old antenna first, but when your picture freezes or it says something like " weak signal " you will need that new antenna
    Jan 24, 2009 | Sony KLV-S32A10 32 in. HD-Ready LCD...
    Insignia digital tv converter/indoor antenna no signal
    Ok first I can save you some money. Take your "HDTV" antenna back. There is nothing different about the antennas needed receive analog and digital signals. If you got reception without your converter box, use the same antenna with your converter box.
    Next let's see if there is a problem with the box. Hook up a television with the antenna. How many stations do you get? Now hook up the same television & antenna, but this time put the converter box between the antenna & the TV. Do not turn on the box. Now how many stations do you get? If the number is different, the box is not allowing the antenna signal to pass through. That is bad. You want your signal to pass through the box so you can still pick up stations that don't broadcast digitally. Some areas of the country will not be covered by digital stations from all major broadcasters when the changeover happens in Feb.
    My suspicion is either you did not have the antenna hooked up to the converter box when you searched for channels OR you are in an area that is not yet broadcasting digitally.
    I hope this helps you solve your problem. Thank you for using FixYa and feel free to add more questions here by using comments.
    Jan 09, 2009 | Insignia Digital-to-Analog Converter for...
    Televison & Video Logo
    132 people viewed this question
    Top Televison & Video Experts
