Question about Frigidaire 24 in. FDB1250RE Built-in Dishwasher
Flashig lights, ticking sound, unfinished cycle
Just moved in a new house, new dishwasher in it. After using a few times it started to act up. After selecting a cycle and pushing the start button it starts, fills up with water and after some time, 2-5 minutes later it stops. All four of the lights (washing, drying, clean, sanitized) start flashing and or a ticking sound is heard from the door (around the selector area). Sometimes both the same time, sometimes either ticking or flashing.
Only been used a dozen times since brand new. I have no bill or invoice for the machine so I doubt warranty applies.
What can be wrong, timer broken?
Thanks for the help
  • Frank Gilice Nov 09, 2007
    The complete model number is FDB1250REC2, the serial number is TH70755712
  • 290 Answers
It sounds like it may be a heater problem or motor start problem. If you will post the complete model number from the decal, I may be able to look up something on it.
You should be able to get warranty service even without the proof of purchase as long as the manufacturing date proves it is within the warranty period. The date code is in the serial number.
If you will post it also I can look it up and tell you when it was built.
Posted on Nov 09, 2007
  • Michael  Lindley
    Michael Lindley Nov 09, 2007
    Thanks for the model and serial numbers.
    The only reason given in the manual for the cycle status lights to blink is if the door is open or dooor switch fails. However since all of them are blinking at the same time I expect there is a control board problem.
    The good news is you should be able to get it repaired in warranty. It was built in February of 2007 and should be covered by one full year warranty on complete machine. I recommend you contact Fridgidaire and get a service call set up.
    Post back if you have any more questions.
Our Whirlpool dishwasher model WDT720PADM1 stops in the middle of cycles or won't start the cycle after water has been pumped in.
All of the things that you are describing are controlled by transistor circuits, and relays, and solenoids. The next time it fails would be the time to call a service repairman with the test equipment and training to locate the failing circuit card or component and replace it. The ticking sound could be a bad relay chattering or a defective solenoid opening and closing. There is no way to diagnose the problem remotely. Even if there were it would require special training to locate and replace the part. Hope that is helpful.
Nov 02, 2017 | Whirlpool Dishwashers
KitchenAid KUDS30FXSS Dishwasher won't complete cycle
Press the Cancel/ Drain cycle for a few seconds. The dishwasher should reset itself. See if this makes any difference. Also first turn the mains power to dishwasher off and back on.
Apr 13, 2014 | KitchenAid KUDS30FXSS Builtin Dishwasher
. Hi.Have a Zanussi DI720
This is a guess but try gently moving it through the cycles by hand a few times, it may just be that the timer mechanism is stuck a bit from age and or disuse. Turning it may help to loosen it up.Be gentle though.
Jun 05, 2011 | Dishwashers
Hi, our Indesit IDL500 dishwasher has stopped working. The fault light 2 is flashing. The manual doesn't mention what fault this indicates. Any ideas. Cheers, Neil
Hi Niel, If you were to start the cycle from the beginning, where in the cycle does this occur? . So many code numbers for so many units, hard to keep up .Just note if heating is taking place and if drainage is correct. Hear from you soon.
Sep 26, 2009 | Indesit 24 in. IDL500 Built-In Dishwasher
Hotpoint Auqarius dishwasher. I have resentley moved house and reconnected the machine. it works through programme fine but is sometimes leaving dishes gritty and not quite clean. I have cleaned filters,...
It sounds like there could be a gritty deposit in the bottom of the system. At the start of the cycle the unit takes in a set amount of water and recycles it around to the drying phase.
Try and run the diswasher a few times with no items in it - this will may help to flush it out.
If the gritty deposit coloured white this could be that your new home has more limescale in its supply. Try getting dishwasher tablets with limescale protection to see if that helps.
Finally, please ensure the spray arms free to rotate on each cycle. Failure to do this leaves grit on certain items and not others.
Please dont forget to rate.
Jul 07, 2008 | Dishwashers
Kenmore Quiet Guard 2 keypad
Sounds like the electronic controls (smart card) are acting up. Try shutting off the power at your fuse box or shut off the circuit breaker for 1 minute them turn the power on again. This fix quite often works on electronic appliances.
Apr 08, 2007 | Kenmore 17342 / 17349 Built-in Dishwasher
Dishwashers Logo
162 people viewed this question
Top Frigidaire Dishwashers Experts
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
