Question about Sta Rite Sta - Rite Mod Media 450 Sq Ft Cartridge Filter and 1.5 Hp Pump System
Missing filter ring
Need to know on sta-rite model t-200bp filter which way handle goes on backwash and rinse?
  • 83 Answers
First, let me inform you that if you contact Pentair, either through email or phone, and let them know that you can not read the valve label on your filter, they will send you one through the mail.
One thing that helped me remember the position of the valve handle was that the WASTE position is always located over the Waste Port on the filter. If you know where the FILTER position is, stand by the filter so that FILTER would be at the top, or the "12 o'clock" position. Now, going to the right, clockwise, the positions are as follows: FILTER, RINSE, RECIRCULATE, BACKWASH, CLOSED, WINTERIZED, WASTE.
To change the position of the handle, you will need to stop your pump, push down on the handle-lifting up the pointed end- spin the handle so that the pointed end will sit pointing toward the position you want.
If you do no have an Owner's Manual, you can find one online at the following link:
http://www.pentairpool.com/pdfs/Cristal-FloOM.pdf
Posted on Jul 08, 2009
Tip
Backwashing A Sand Filter with A Push/Pull Slide Valve or Multiport Valve
Lots of people are first time pool owners and pool professionals forget to teach these "newbies" about the simplest aspects of pool ownership.
One of the biggest questions we receive from new homeowners is "How do I go about backwashing my sand filter exactly?"
It doesn't matter if you have a Hayward, Pentair, Jandy, Sta-Rite or any other number of Sand Filters on the market they all utilize the same basic valves for backwashing; a push/pull slide valve or a multiport valve.
To backwash with a multiport valve:
1) Shut off pump motor.
2) Press down on valve handle, rotate valve from FILTER to BACKWASH position.
3) Roll out any backwash hose or open any waste line valves.
4) Open air bleeder assembly on filter, and turn pump on.
5) Watch pressure gauge for backpressure and hose for kinks. Be prepared to shut off pump quickly.
6) After hose fills with water, run for 3 - 5 minutes or until water runs clear.
7) Shut off pump motor and move multiport valve handle to RINSE position. Run on rinse for 15 - 25 seconds.
8) Shut off pump motor and move multiport valve handle to FILTER position.
9) Turn pump back on and note lower pressure.
10) Roll up backwash hose so the dogs use it as a chew toy.
To Backwash a sand filter with a slide valve:
1) Shut off pump motor, roll out backwash hose.
2) Twist to unlock plunger T-handle, push or pull(depending on manufaturer) the plunger 2" - 3".
3) Open air bleeder assembly on filter, and turn pump on.
4) Watch pressure gauge for backpressure and hose for kinks. Be prepared to shut off pump quickly.
5) After hose fills with water, run for 3 - 5 minutes or until water runs clear.
6) Shut off pump motor and push T-handle back down into locked position.
7) Turn pump back on and note lower pressure.
8) Roll up backwash hose.
Now you are a backwash Guru!
More tips and tricks are available form The Ugly Pool Guy, www.WeFixUglyPools.com
on Dec 14, 2010 | Pool & Spa
BHR170 backwash port
When backwash is done it dumps to waist, down the drain just like your toilet
Jun 01, 2014 | Sta Rite Sta - Rite 24" Sand Filter & 1 Hp...
We accidently left our Sta-rite pool pump on when we went out of town for 4 days. It ran dry during this time. Now when we turn the pump on, water shoots out of the top under the handle and makes sounds...
sounds like the heat from the pump melted the seals in your multiport replace multiport and pump you should be ok you will need to replace some of the pvc pipes they expand when heated you wont be able to put fittings on them
Sep 07, 2013 | Sta Rite Sta - Rite Dyna - Glas Pool Pump...
Sta-Rite leaks out of backwash pipe.
not a good idea to switch valve when pump is running. you could try rebuilding the valve wit a kit and some magic lube. mark the valve with a marker or a file so you can be sur to reasemble it right
May 13, 2013 | Sta Rite Pool & Spa
My sta-rite pump leaks out the backwash port looking for a rebuild kit
If you remove the bolts around the top the handle and lid assembly will pull out. Under that is a spider gasket that needs to be replaced. Clean out and dry the slots where the spokes of the gasket go, and replace with a new gasket using contact adhesive or vinyl adhesive to glue the gasket in. Do not put anything on the top of the gasket.
It's a good idea to replace the diverter o ring and bearing while you have it open. This requires removing the handle from the diverter. The o ring is on the diverter shaft, the bearing is the white plastic ring that goes between the lid and the handle. After that the backwash valve will work like new.
Mar 26, 2013 | Sta Rite Sta Rite Above Ground Sand...
How to clean out filter
Shut off power,
Move Filter Valve Handle to the backwash position
Turn on Filter
Let filter run until the water is clear.
Turn back off and move the handle back to the filter position.
TIP: Replace your sand every two years!
For more info, go to:
http://www.oskopoolnspa.com
Sep 16, 2012 | Sta Rite StaRite Aboveground Pool Sand...
How to backwash my PLM-100
no you take the filter out and wash it off, try to do it in the shade or on a cloudy day, the sun damages the filter material (DE type filters)
these DE type filters are a no nonsense affordable filter that don't have all the bells and whistles, but do a better job filtering than a paper cartridge type filter
May 24, 2012 | Sta Rite Pool & Spa
How do I rinse the filter and when is it necesary to backwash?
It seems these filters are for 1 time use only. You might as well through them out. You can try backwashing. The best thing is using filter cartridges you just replace them as you go. Good luck.
Jun 28, 2011 | Sta Rite 21 Sand Filter System with 3/4 Hp...
Sta Rite Sta - Rite Mod Media 450 Sq Ft Cartridge Filter and 1.5 Hp Pump System Logo
95 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
