Question about Motorola Mobility Bluetooth Hands-Free Speaker T305 Wireless Headset
T605 mic will not work. had the kit for a while box got wet. it will pair with blackberry storm it will receive calls, you can hear the other person talk but they can't hear you. i ohmed the mic no broke wires and not muted.
I have blackberry storm and when i make a call or receive a call the other side cannot hear me. I can hear them clearly
Please put handsfree in the phone and then remove it from the port. There is a glitch that the unit occasionally thinks you still have headphones attached and will not activate the speakerphone, mic, or speaker.
Thanks
Ali
May 05, 2011 | RIM BlackBerry Storm 9530 Smartphone
Installed Pioneer DEH P6200BT. Experiencing BT problem. Everything seems to work correctly, locating, pairing, receiving calls, dowloading address books, all of that works correctly. The problem I have is...
Hi! I just figured this out myself. The radio only sends the phone call audio to the front speakers. My car only has wires for one set of speakers, so I chose the rear channels. I just rewired to the front channels instead. Solved! Bad on Pioneer, there is absolutely no mention of this in the installation or operation manual.
Dec 07, 2010 | Pioneer Car Audio & Video
People cant hear me talk on my balckberry strom
you must have a bad mic you will need to replace it in order for the other person to hear you
Jun 11, 2010 | RIM BlackBerry Storm 9530 Smartphone
I cannot send pictures from my blackberry storm,
You receive a Failed to Find Service message when you attempt to transfer a media file between two BlackBerry Pearl smartphones.
The BlackBerry Pearl smartphone receiving the media file is not properly configured.
To send and receive files between two BlackBerry smartphones using Bluetooth® wireless technology, complete the following steps:
  1. Enable Bluetooth technology on the BlackBerry smartphones. For instructions, see the Turn on Bluetooth technology section of the BlackBerry User Guide.
  2. Make the BlackBerry smartphones discoverable. For instructions, see the Make your BlackBerry device discoverable section of the BlackBerry User Guide.
  3. Pair the BlackBerry smartphones. For instructions, see the Pair with a Bluetooth enabled device section of the BlackBerry User Guide.
  4. Set the Trusted field to Yes on both BlackBerry smartphones by completing the following steps:
    1. In the Bluetooth application, highlight the BlackBerry smartphone and press the Menu button.
    2. Select Device Properties.
    3. Set the Trusted field to Yes.
    4. Press the Menu button and select Save.
  5. Send and receive the transfered file.
On the recipient's BlackBerry smartphone
  1. On the Home screen of the BlackBerry smartphone, select Media.
  2. Select a media type (Music, Video, Ring Tones, Pictures).
  3. Press the Menu button and select Receive using Bluetooth. The File Transfer dialog box appears, followed by a prompt to Save or Cancel the file.
  4. Select Save to save the file to the current location, or select the folder icon to save the file in a different location.
On the sender's BlackBerry smartphone
  2. Select the same media type selected on the recipient's BlackBerry smartphone.
  3. Press the Menu button and select Send Using Bluetooth.
  4. When prompted to select a BlackBerry smartphone, select the recipient's BlackBerry smartphone.
Nov 02, 2009 | RIM BlackBerry Storm 9530 Smartphone
Callers can only hear me on speakerphone
first try to formate the set ...and problem is still there then its hardware problem ....you hv to change your phone's Mic
Jul 17, 2009 | RIM BlackBerry Pearl 8100
Can not pair with my new Blackberry storm - Help???
Make sure the BlueAnt Supertooth 3 is turned OFF.
  1. Press+Hold the Volume Up button and then also press the green button to reset the unit.
  2. After completing the above reset, turn the ST3 OFF again and wait at least 10 seconds.
  3. Turn unit back ON and select language when prompted.
  4. Follow the voice prompts and pair the ST3 with your blackberry as normal.
  5. After pairing has completed you will hear the ST3 announce “loading phonebook – please wait”.
When your blackberry ask your permission to allow bluetooth to connect and donload phonebook allow it permanently.
May 04, 2009 | Blueant Supertooth Light Bluetooth Speaker...
Email messages do not appear in inbox on Blackberry Storm
Dear Vbcarroll,
on your blackberry go in main menu- options- advance options- default services. if you have enterprise mail account setup with personal mail account, it can be the case that at the moment it is showing as desktop services but when you are in there click on main menu and change options to other mailbox which is in your case personal mail account.
that way in inbox you will receive both emails and you can see all together.
but as far as i know, I haven't setup personal account on my blackberry but i believe within main menu you get created another icon like mobile mailbox and where your personal mailbox emails are coming in. if option one doesn't work then please try to look for this new created icon within main menu.
update me if none of them are working or any other problem.
Thanks.
Regards,
AJoshi
Mar 26, 2009 | RIM BlackBerry Storm 9530 Smartphone
Too many phones paired to my T605
To remove all paired devices from the car kit's history:
Press and hold red (END) button for 6 seconds or longer while not in a call.
Once a device is removed from history, it must be re-paired again before it can be used.
Sep 17, 2008 | Motorola Mobility Bluetooth Hands-Free...
Motorola Mobility Bluetooth Hands-Free Speaker T305 Wireless Headset Logo
57 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
