Question about Toro Lawn Mower With Toro Power Tools
NO REVERSE I HAVE A TORO 521 SNOW BLOWER, WORKS GREAT IN ALL GEARS BUT REVERSE WHAT WOULD CAUSE THIS?
3 Suggested Answers
#1 Taper
  • 1041 Answers
SOURCE: we have a used Toro 521 snow blower without a
The rubber gaskets may have dried out because there was no fuel in it. The next time you store it, use : http://www.goldeagle.com/brands/stabil/default.aspx
For some reason I wasn't able to give you a direct link to this site, so you will need to copy and paste into the search bar .
But before you purchase new carb. parts, try this:
Check the fuel lines for cracks/breaks. If they are o.k., then:
You willneed to disassemble the carburetor and spray with carb.cleaner. Makesure the small screen is free of debris. (Should be able to see daylightthrough it.) Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
Posted on Nov 30, 2009
SOURCE: My toro 1128 OE snow blower wont throw snow the
I have a toro 98 cc powerlite snowblower model 38182 it was running fine one day then bog down and died after that i cant get it to start it has a good fire on the plug plug isnt very wet it pops threw carb once in a while help
Posted on Dec 27, 2009
Does the shift rod that moves the snow blower through 1to 3rd gear and reverse have an adjustment? This is a.very old toro snow blower.
Many times the rod is 2 pieces that join together with a slot made onto one end. Normally about knee high under the handles. Adjustments can be made in those slots to effectively lengthen or shorten the overall length of the rod. Essentially it places the shifter on the dash of the handles in coordination with the gears on the gear box.
Feb 13, 2017 | Toro Garden
Does the shifting rod for the 3speed forward and reverse have an adjustment. This is a very old toro snow blower
The shifting rods have slotted ends that match up to each other. Moving the slots will index the lever on the dash to the gear case.
Trouble shifting gears
Replace all belts .
Dec 23, 2013 | Garden
I have a toro snow blower that wont throw snow
then you need to see if the belt is still in one piece... then inspect what else would cause this issue
Oct 10, 2013 | Toro Snow Blower Ccr 1000 Belt 715381...
Toro snowblower wont start. seems like the fuel isnt getting into carb.how and what can i do
Reference your toro snow blower. does it start and run for a few swconds then die. if so It may sound crazy but loosen the gas cap just a bit. I had the same issue with my snow blower and a friend gave me the solution. It works great now.
Oct 21, 2011 | Toro Lawn Mower With Toro Power Tools
Toro snowblower wont start.I have a toro ccr powerlite that dosnt seem to be getting fuel from the fuel line into the carb. I took the fuel line off and fuel is getting to the carb so then i removed carb...
Reference the Toro snow blower. It may sound crazy but loosen the gas cap just a bit. I had the same issue with my snow blower and a friend gave me the solution. It works great now. Hope this works for you.
My Toro lawn mower only self propels in reverse. How do I fix this problem?
My guess is that someone was working on the self-propell system recently ;)
The gears are marked with a L or R and if put on reversed will cause a pulling in reverse.
Check your model at a Master Dealer parts lookup site like www.arcolawn.com
Good luck
Jun 10, 2010 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
178 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
