Question about Campbell Hausfeld 20 - Gallon Air Compressor
I have a sears, twin cylinder tank air compressor that I have not run for over a year. I serviced it with oil, which was very low, and turned it on. Oil started spraying out of the filler cap. Is there a oil filter that could have clogged up inside of the crankcase?
  • 1 more comment
  • aldozier Jul 01, 2009
    Responce to all-guru,
    Thanks for confirming my suspicion, but I am afraid I am going to need more detailed help.
    I have gone over to the barn and taken several pictures of my compressor. One from all four sides. I have no idea where the oil filter is located or how to get to it. I asked my daughter to help me load those pictures onto my computer so that I can send them to you; but mainly so that i could follow your instructions when you replied. I hope this is OK to do.
    I have some mechancial skills but may not have the right names to call all of the different parts that you might call them. Also, is this going to be one of those jobs that is going to involve taking the crankcase, pistons, etc all apart? If so, I may be in over my head to try and do that. Not that I couldn't take everything apart, but puting everything back together and not having leftover parts might be a posibility .
    I sent the pictures from my personal e-mail, I was not able to attach them to this response for some reason.
    Thanks, Art
    RE: problems with a Campbell Hausfeld air compressor,
    All-guru,
    I sent an earlier e-mail and followed it up with a separate e-mail containing four pictures of the compressor I am having problems with today. I cannot find where you have responded to either of those two e-mails. I would like to know where we stand. What are my options from this point? Could you please respond?
    Thank you, Art
  • aldozier Jul 04, 2009
    All-guru,
    Thanks for the reply. Over the weekend, I'll drain it and retry as you suggested. At first, I thought it might be a simple problem, but now I'm beginning to think it is not as simple as I thought.
    Thanks, again,
    Art
  • 436 Answers
Yes the oil filter may be clogged up in the crankcase which may have blocked the air intake.Remove it as soon as possible or it can get stuck inside it..
Posted on Jul 04, 2009
  • 2,418 Answers
Most likely is that you put in too much oil. Drain all and refill, make a dip stick out of a coat hanger.
Just eye the side of the comp. make your mark about 1 inch above the oil pan gasket, fill to that mark, try again.
Posted on Jul 02, 2009
  • John Fourteen Six Jul 02, 2009
    Most home style (less than 15 horse) air compressors do not have oil filters. The next thing is your cap may not fit as proper as it should, do to the way a compressor works it will bypass air into the crank case and cause some oil splash if the cap is a loose fit it may pop out or leak. I have made a vent for mine out of some old brass. Now air compressors do not use oil and what I mean by that is they do not burn it or consume it. (Yes they use it but not Consume it) So it may not have been as low as you think. Drain some and try again.
  • 3,230 Answers
Yes, Problem seems in the oil filter may be clogged. try cleaning it.
if does not work than replace it with a new filter.
Good Luck!!
Thanks
Posted on Jul 01, 2009
My twin tank 2hp comp will run but pressure wont build up pass 20 lbs.
If the motor is working OK but pressure won't go over 20psi you may have an air leak but most probably have damaged piston rings or cylinder or the valve plate is damaged. Check to make sure the tank drain valve isn't open or that you don't have leaks in any of the air lines. If that's OK, you will have to remove the head from the cylinder to check the valve plate and piston/cylinder assembly. The reeds on the valve plate should be flat and not overly discolored (black or blued) from heat. If they are they can warp or get brittle and break. Since your compressor is oil lubricated it is rare for the piston/rings/cylinder to get damaged unless it's run with no oil so check those areas for scoring or damage like broken rings. Replace whatever is damaged and keep the oil full.
Sep 18, 2012 | Dewalt D55151 2HP 4G TWIN COMPRESSOR
I have an older Sears Craftsman air compressor 1hp, 100 psi twin cyl Model 106.154541. on the cyl base there is an oil fill directly across from this on the opposite side of the cyl base there is another...
The pump used on your compressor was incorporated into different designs thus needed access to oil fill from one side or the other. Part number for oil plug was std-220 or 27642, but you can use just regular standard pipe thread plug with square head. If the oil plug fits the other hole. Buy plumbing parts at Lowes. Good Luck
Mar 25, 2011 | Craftsman Air Tools & Compressors
I have an upright craftsman compressor which is VERY slow at building pressure. The shut off is 150psi. When I use the unit, and it turns on, it runs forever to build back up, even when im not using it....
Your unit should fill within 5 min. Compressor may have worn cylinder (assuming oil-less) , worn valves or just leaking. Easy test. Spray soapy water on all connections/fittings including drain valve and regulator while compressor is running. Repair as needed. If no leaks, remove plug from outlet, remove cover and examine cylinder. Turn crank by hand till piston is all the way up into cylinder. Examine carefully the condition of the cylinder close to top. If the cylinder is scratched or worn then pressure is leaking between piston/cylinder and will not fill tank properly. Replacement cylinder kit available at Sears, cost under $50. If no leaks and the cylinder looks good, then valve plate may have broken gasket or reed valves. Replace as needed. Good luck with your project.
Aug 25, 2010 | Craftsman Air Tools & Compressors
I just bought a used Craftsman air compressor at a garage sale...100PSI, twin cylinder, 1HP motor. Model # 106.154440. Runs fine, but wondered how to check the oil level in the compressor case and if it...
I have a Sears 106.154581 most likely like yours. You will find a small plug (fill hole) and slightly larger plug on side of pump close to bottom (drain hole). Fill compressor with compressor oil to top thread of fill hole. Oil should look rather clear with very little odor. Compressor oil is available at Lowes for about $3. Good luck
Aug 16, 2010 | Craftsman Air Tools & Compressors
What type of oil does this unit take?
Air compressor oil. I prefer synthetic, but you can use regular compressor oil also.
Jun 26, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I have a 919.167780 2 Stage Twin V Portable
two different problems here! first when it trips the breaker and you try to reset the breaker and not turn off the compressor on its pressure switch it does not unload the air off the head of the pump when you try to start it again,,, ( when it shuts off normally you hear the air drain near the switch,, this unloads the pump to restart)
The most likely reason it is tripping the breaker is that the second stage (smaller cylinder) is not doing the work it needs to do and the first stage (bigger cylinder) is pumping more now!,,,, higher pressure on this side makes the motor work harder.
I would advise rebuilding both sides to get the pump back up to correct running levels it had new.
Feb 25, 2010 | Craftsman Air Tools & Compressors
I have a small Hitachi 2HP compressor,oil lube w/twin green tanks
the air pressure switch is gone, get a professonal 2 fix it just incase anything should go wrong
Nov 08, 2009 | Air Tools & Compressors
I have a Sears 3 H.P. electric 30 gal air compressor
This link will take you to sears web site, where parts are available. I have linked you to the parts list. If this does not take you there, go to www.sears.com and click on the parts direct tab and enter your model number.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=106.154880&productCategoryId=0703000&brandId=0247&modelName=CRAFTSMAN-TWIN-CYLINDER-TANK-TYPE-PAINT-SPRAYER&diagramPageId=00001&documentId=00001361&pop=flush
Oct 30, 2009 | Air Tools & Compressors
I have a 2 stage twin v. the motor runs and it is pumping air but it will not build any pressure.
The compressor should pump into a final check valve where the pressure switch is located. Check the condition of that valve. If the compressor itself is not pumping, the cylinder heads need to be removed and the valves in each head checked. Check the condition of the cylinder walls which should be smooth without any lengthwise grooves. Is the tank rusted through? Any leaking safety valves? Make sure you have proper oil level in the crankcase. Make sure the intake filter is clean. Check the tubes between the cylinders and the tank for leakage (splits or rust throughs). Just work from intake to tank in a progression, checking output at each point.
Oct 29, 2009 | Air Tools & Compressors
My Sears 1 HP compressor motor starts to slow down to almost zero RPM as pressure approaches 60 psi. Up until recently it produced 100 psi. Compressor rotates freely at shut down (no binding, etc). Is this...
IF IT HAS BELTS THE BELTS COULD HAVE BEEN LOOSE AND SLIPPING.. MOTOR COULD BE GETTING HOT DUE TO TOO SMALL OF CORD OR SMALL GAUGE DROPCORD. INTANK CHECK VALVE COULD BE GETTING CLOGGED NOT ALLOWING AIR TO PASS THRU IT. UNHOOK DISCHARGE LINE FROM HEAD TO THE TANK, THIS WILL ALLOW PUMP TO RUN UNDER NO STRESS AND SEE WHAT HAPPENS.
Apr 03, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Campbell Hausfeld 20 - Gallon  Air Compressor Logo
176 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
