Question about Breville BBL600XL. 5-Speed Blender
Blender will not run. the power button is lite but
Breville
blender will not run. the power button is lite but blinking? any ideas???
  • mike787 Mar 10, 2017
    there are 3 screws under the label. Peel off the label . remove the 3 screw. remove the fan cover.
    to remove the fan . hold on to the blender jar mounting drive and unscrew the fan. a small square nut is what holds the fan on. remove the rubber feet an the 4 star screws under the rubber feet.
    you can then remove the base.
    Most likely the fuse is OK. However I've found ( in repairing mine) the big yellow capacitor 1uf 275vac is at fault. over time and power surges it breaks down and cannot pass enough "power:" for the power supply to call the relay to turn on the motor. You van get a new capacitor from Jaycar ( aus or NZ ) for about $6.00 . unsolder the capacitor and solder a new one in. reassembly is reverse. Just be careful not to trap the micro swicth wires ( black) under the motor surround.
There is a 10 Amp thermal fuse (SF129E) that is supposed to create an open circuit when the motor windings exceed 133 C degrees. Although this fuse should close again when the motor cools down it can become perminantly damaged. Locate the fuse by following the black leads from the coltrol board to the motor brushes. It's inside a cloth insulating sheath secured against the windings with a metal strap and two ty-raps. I bypassed the fuse with a wire instead of replacing it. It would probably just blow again sooner or later. p.s. you need a T10 Torx screw driver to disassemble (screws under rubber feet) $3 at ACE hardware.
Posted on Jul 22, 2010
  • marc_miron
    marc_miron Nov 19, 2010
    Wire that is bypassing fuse - just attach a wire from both fuse terminals?
Does anybody want to sell the jar from a breville bbl600xl? email me kayhanay@hotmail.com
Posted on Aug 11, 2009
I have a Breville 800BLXL/B blender that won't power on. When plugged in, the power button will not illuminate.
Most likely its the large yellow capacitor on the main circuit board. I've had this fail on my Breville coffee machine and blender.The coffee machine was a 1.5uf capicitor nd the blender 1.0uf.rated at 275vac. what happens is over the years of power spikes and surges etc the capacitor breaks down to a lesser value than its original "capacity. ie 1uf down to 0.3uf it provides enough power to drive the display electronics But not enough to power the relay to turn the motor on.
. there are 3 screws under the label. Peel off the label . remove the 3 screw. remove the fan cover.
Jan 21, 2017 | Breville Blenders
I think I overloaded the blender. Seems like it over heated. now the light on controls goes on but blender does not run when I push buttons. I checked the fuse and its good. What else should I check?
If fuse is good and light is on, then you are getting power. Most likely and very very commonly the motor is fried. I have done it myself with 3 of these things.
Dec 31, 2010 | Breville BBL600XL. 5-Speed Blender
I need to acquire a glass jug for a breville BLR-3 Blender. Any suggestions would be appreciated !! Thanks
Hello. The best route to go is to work directly with the manufacturer. here is their contact info
  • AskUs@BrevilleUSA.com
  • 1.866.BREVILLE (1.866.273.8455)
  • 8a to 5p Pacific Time
  • Mar 22, 2010 | Breville CBL10 BlendMaster Classic Work...
    Grease build up around blade and where it attaches to base
    Grease can only creep into the blender vase if the oil seal has worn out, or the blenders blade shaft is worn and wobbling. Try cleaning all parts in alcohol to soften the seals. Rebuild kits and replacement blades can be found here (http://www.brevilleusa.com/breville-parts/blending.html)
    Mar 09, 2010 | Breville BBL600XL. 5-Speed Blender
    Breville Blender
    I need the blend jar for Breville Blender electronic Model BL3. I did not notice that a stainless steel spoon was in the blender. When I switched it on the crossed blade broke off.
    Oct 15, 2009 | Breville ikon Hemisphere Blender - Silver
    Any idea where we can get a new jug for a breville blender?
    This happened to me recently. Go to this site and order it directly from Breville. They were very fast and customer service very helpful.
    http://www.brevilleusa.com/home.do
    Jan 11, 2009 | Blenders
    Breville hand blender doesn't blend continuously
    I have the same problem. Mine used to work, has only seen light use, and now it runs for about 1 second before it shuts off. Expensive POS. There don't seem to be any solutions either.
    Nov 18, 2008 | Breville Cordless Hand Blender - Silver
    Breville BBL600XL. 5-Speed Blender Logo
    1,978 people viewed this question
    Top Breville Blenders Experts
    Mike
    Craig Butler
    Craig Butler
    Joseph Hoffmann
    Are you a Breville Blender Expert? Answer questions, earn points and help others
