Question about Philips Televison & Video
Philips LCD TV 19FPL5522D flashing green light
    President:
  • Philips Master
  • 1,779 Answers
Most likely, bulged capacitors in the power supply.........
Posted on Jul 01, 2009
Philips 37PF5521D green light flashes 1 long then 9 short
The fault code is '19'. Counting the flashes to philips TVs are given in detail by the link given below. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/ You can get details about the fault codes, blinking codes etc:
Nov 14, 2013 | Philips 37PF5521D 37 in. HD-Ready LCD...
I have a 37" Philips (37PF9431D/37) flat panel tv. It won't power on. When you plug it in you can hear a click the green light stays on for a few seconds then goes out. I've checked the power board for bad...
i am having the same problem. My Phillips 37" 37PF9431D/37I LCD High Definition TV won;t turn on. When I press the power button i hear a click and the green light comes on for a couple of seconds and then the red light appears. I can;t figure it out. Did you find a solution?
May 20, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips magnavox 37' lcd want come on, green light just flashes
The number of flashes indicate an error code,you should call the customer help line that is in your owners manual and relay the number of flashes to the operator and they will assist you in a solution.
Nov 22, 2009 | Philips Magnavox 27MS343S 27" TV
Philips 20PF4121 LCD tv no picture but flashing error codes
I had exactly the same problem When the TV was switched on all I could see was a flashing green light. After cheching the TV internals and not seeing a problem including the power supply unit which looked and checked normal. Here is what I did to get M TV working again.
Disconnect it from the power supply. Hold down all the buttons simultaneously i.e. the on/off, the volume, the programme, menu buttons, all of them simultaneously and Plug it into the power supply again.
Lo and behold My TV jumped back into life after an absence of about 4 weeks.
Try it yourself exactly as above.
Best of luck.
Irishfreethinker
Jul 09, 2009 | Philips 20PF5120 20 in. EDTV-Ready LCD...
Phillips 42 inch LCD 42PF9730A Redlight flashing
Common short the cover cap over the video & sound boards short out if you remove it the cap only (shield metal) it usually will fix this
Jun 16, 2009 | Philips 42PF9631D 42 in. Plasma Television
TV will not turn
Please unplug the tv for 30 min and then plug it back to power supply and see if the lights are blinking again...
Good luck......
Jul 16, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Blinking red lights
If your TV is less then a year old, i would suggest to call the vendor or manufacturer to have the LCD repair under warranty. Most electronics devices carry one year warranty.
The failure of your LCD is not related to any fuse since you're still getting some lights from it.
Good Luck.
Jul 09, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
TV not turning on.
Mine was doing that and I ordered a replacement power supply board for it and now it work. It's fairly easy to replace.
http://www.partstore.com/GetModel.aspx?MfgName=Royal+Philips+Electronics&BrandName=Philips&ModelNumber=37PF7320A37&page=16
Mar 14, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Red light flashing on tv
My 37" TV Will not yurn on . The green light goes on for 2 seconds then goes off and red light starts flashing. What Repair/Part is needed.
Aug 31, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Televison & Video Logo
205 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
