Question about Sony KP-51HW40 51" Rear Projection Television
Red and green lines across the screen
There are red and green lines across the screen. How do I fix this?
  • 1,694 Answers
Re: Red and green lines across the screen
Classy cuban,
Probable convergence issue....replace convergence IC's
In front of set behind access panel,locate RGB focus and screen
adjust block.....turn red screen control ccw a bit........
m888, Your monitor has a bad CRT.........................T.
Posted on Dec 04, 2007
  • 1030 Answers
SOURCE: Red,Blue,Green Image
YOu have convergence issues. Ok first question. IN your setup menu do you have the convergence option/ if you DO not then it can be a specail fusable link. fl231 if you do. next question do the picture bow in at the middle. if you do then it possibly a convergence power supply issue. next if you go into setup convergence does the crosshairs adjust up or down left to right on both blue and red. I if so then theres is a chance that it can be a convergence adjusment or a amplifer problem AS always THIS SET CAN GENERATE LEATHAL 380 VOLTS EVEN WITH SET UPLUGED SO BE CAREFULL.
Posted on Jun 21, 2008
0 characters
3 Points
PANASONICV that now has a "blurred" screen. We can see the channels but it looks like it's has a shadow around the images. The screen in in a red hue with green blur. TX-51P100H 51"...
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from and do the repair yourself. Its a fairly easy DIY fix.
Jul 29, 2011 | JVC AV-56WP74 56" Rear Projection...
Hello, I've got red wavy lines across screen
There are two common problems with these sets.
Problem #1) Convergence
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
Oct 22, 2009 | Samsung HCM5525W 55" Rear Projection...
Thin red line, green line and yellow line going across the screen
the problem is vertical collapse,i am not so sure you can trouble shoot this on your own but you can send the board to eithor pts electronics or tristate module for repair
to get a price get the number off the sticker--left hand board(looking from the back) it will start CTC195---- write down entire number before you call them
Sep 02, 2009 | RCA P52926 52" Rear Projection Television
Red lines across screen
had tv that did the same thing after three years but they were green cost me 300 bucks to get it fixed and the guy said every 3 to 5 expect it
Jul 03, 2009 | Sony KP-51WS500 51" Rear Projection...
Red and green wavy lines
If the distortion that you see can be described as somewhat of a 3-D picture, the problem is teh convergence circuit and this can be fixed easily. Also, if you can solder, you can fix this yourself. If you wish to do this, please update this and I'll provide you with some instructions.
Sep 12, 2008 | Akai PT5492S 54" Rear Projection...
Green cruve line
Good Day;
Suspect Convergence IC's STK4274, part Number 2003191. Replace all three IK04(red), IK05(green), IK06(blue).
Good Luck, big IRISH.
Aug 30, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
Sony 65 inch screen tv
The lines you saw, i;m sure they are the ones called retrace lines but know the failure could be located on the red CRT board. Most likely the video amplifier is defective and not necessarily the CRT.
What is the model number of your TV?
Jun 17, 2008 | Projection Televisions
LG Rear projection tv help... Red, Blue and Green horizntal line through screen.
The complaint may be dry solderig or yoke ,horizontal or vertical oscilator
Dec 29, 2007 | Projection Televisions
I have 47 inch with double color in picture, reds and green
convergence amp ic bad
Oct 14, 2007 | Samsung HCL552W 55" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
957 people viewed this question
Top Sony Projection Televisions Experts
Steve Sweetleaf
Steve Sweetleaf
Jason Harris
Jason Harris
Are you a Sony Projection Television Expert? Answer questions, earn points and help others
