Question about Frigidaire FTF530FS Front Load Washer
I use the washer almost every day, now it has an odor-like old wet laundry-we had some work done cisterns and the paint left a white film in the water. could this be the cause of the odor?
Do you use liquid detergent? If so...stop...I had the same problem...and tried to eliminate all the posibilities. Then from forums...I realized that it was my detergent. I changed to Gain HE..instant change in smell of clothes...Hope this helps..
You could also check your lint filter. Depending on what type of washer you have...depends on where it is located. :)
Posted on Jul 02, 2009
I have a wet\moldy odor coming from our Whirlpool Duet Front Load Washer, Model WFW9400S. I opened the washer cabinet up and don't see anything like pooling water or a dead animal. I did notice the hose...
with all the environmental changes made to laundry detergents, consumers should use only 1/2 the amount of detergent they previously used. The detergent build up causes a moldy odor in the washer.
Sep 16, 2010 | Whirlpool Washing Machines
Our washer smells like mildew or mold whats up?
is it fully draining? old water will start to cause this. wash ur clothes and immediately dry them. dont leave wet clothes in the washer over a days period. hope i helped
Mar 12, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Smelly clothes and washer
Washer smells foul...this is often a build up of soap, water, too many chemicals and this has left a residue, and the mildew moves right in and it stinks. This builds up is often on the inside of the outer tank.
Many times that this happens is when people use to much soap and then they only do laundry once a week.
One good solution to help your odor problem...it works well...in a top loader I recommend 2 cups of cascade and 2 cups of bleach, fill your machine with hot water and let it agitate. At the end of the agitation/wash cycle, let the machine sit and soak for about 10-15 minutes to work on your scum, then close the lid and let it complete. Next load run whites to be safe all bleach is out. This should help.
On some really bad odor problems, you may have to remove the inner basket to scrap off the build up from the inside of the outer tank. You may will need special tools to remove the inner basket.
Fabric softener is also nasty for building up inside and under the agitator.
It is recommended to use half to a quarter of the detergent that the package recommends.
Other things that may help, leave the washer lid open between laundry days. Never cover your washing machine with those plastic covers.
Nov 11, 2009 | Frigidaire ATF6000ES Front Load Washer
I have a strange odor
It is normal for all models of washing machines to have a gallon or two of water left inside the bottom of the washer and in the drain pump. This is not the cause of odor. The smell is being caused by residue left on the inside of the plastic outer tub.
The best way to clean a stinky washer is to use a washer cleaner that is able to be used with clothing in the washer. The added bulk of the laundry will raise the water level to include the splash area 3-5 inches above the normal waterline. This splash area always has the worst buildup.
After the odor is gone you'll need to change washing habits to keep it away.
Oct 19, 2009 | Washing Machines
Water remains in the bottom of my front load Maytag washer after a wash cycle is completed. It is causing mold on rubber gasket and a bad smell in clothes.
You need to make sure your washer is properly leveled so it can drain as much water as possible at the end of the wash/rinse/drain cycle.
You want the washer level from the front to back edges and from side to side. You'll need at least a torpedo level, or better yet, a 4 foot long level to get the best possible results.
The washer feet at the front and back that can be adjusted to bring the washer to the proper, level on all corners.
As a side note, I also find that leaving the door slightly open after you're done doing laundry, will help eliminate water getting stagnant and causing the strong odors you're experiencing.
Here's more info, I've provided in another one of my solutions for you to read through so you can better control the problem you're having and get rid of the smells.
This can happen with any front loading washer, regardless of the manufacturer.
One of the first things to do is make sure you're using the He (High efficiency) laundry detergent and only use a small amount, about 3 tablespoons or less. The trick is to not use so much detergent that you start getting a buildup in your machine. Also, if you have heavily soiled clothes, pre-treat them instead of adding more detergent to your wash cycle. This alone will result in better results.
Also, be certain the washer is properly leveled in all directions and to make some slight changes in your wash day schedule.
By making sure the washer is properly leveled, it will operate better and help minimize odors, as the spin cycle will get more water out, etc.
The other tip, that has really helped in our house, is to do all the hot water (whites) as the last load. Since we do use bleach when we wash our whites, along with hot water, the washer's last load will have had the best sanitizing cycle run through it before being left for the next load another day.
With the bleach and hot water, the washer gets a nice clean disinfecting wash which helps eliminate odors, germs, excessive soap, etc. and leaves the washer fresher. By doing this, we don't have to purchase other (more costs and expense) additives to run through the washer to attack the odor causing germs and gunk.
What good is a more energy efficient washer if I have to always run a special tablet/liquid cleaner in it each week without any laundry in that wash load? Seems wasteful to me to be doing an "extra" wash just to wash the washer. So I'm not a proponent of having to always use another product every week or month to have a washer work like it should.
However, if you've got an existing (smelly/moldy) washer presently, I would recommend that you use a produce called Whirl-Out, which will help dissolve the buildup that your machine currently has and get it clean again. Then you can follow the steps above to keep it from causing you issues in the future.
Hope you find this Very Helpful and best regards!
Sep 21, 2009 | Maytag Neptune MAH5500B Front Load Washer
Smelly clothes, nasty towels. Temporary solution.
I hope you find this Very Helpful and best regards!
Sep 20, 2009 | LG WM2688HWM TROMM SteamWasher
WATER IS COLLECTING AND STAYING IN THE GASGET AND HAS AN ODOR, HELP, Please
Betty, this is problematic of all front loading washers. I have some helpful suggestions, which have helped us with our own front loading washer.
First, whenever you're done doing a load of laundry, don't close the door all the way shut. Leave it open a couple of inches for a day to let it air dry out, which will prevent the nasty smelling odor you're getting.
I also take a small rag/washcloth to wipe out the door seal/gasket after we're done washing, that way, there's less water to contribute to foul odors, etc.
The other thing we discovered is to make our last load of wash the hot water wash, whenever we're doing whites, or the stain cycle. This helps get rid of any gunk that might hang around between wash days.
Now we don't always have a hot water wash everytime we do laundry, but by just wiping out the gasket and leaving the door open, we eliminated the odor issues completely.
Frankly, the gasket shouldn't have to be wiped out when you're done washing, but that's a design issue that we've overcome with a simple washcloth. So just do these simple steps and you'll save yourself some frustration.
We really like how clean our laundry gets with the front load washer and how little water is needed to do a load, so we've decided it's worth taking the time to wipe the gasket once we're done for the day, and to leave the door open to prevent any nasty odors.
Aug 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
MY FRONT LOAD WASHER STINKS! THERE IS A MUSTY ODOR COMING FROM INSIDE.
what kind of washer?
all front load washers get this issue
the way to get rid of the smell is by doing an acid wash to your machine
set the washer to the highest temp setting (sanitize would be best)
mix in 1/2 to 2/3 cup of javex or white vinigar, either one will do it
run your washer through the longest cycle possible with no clothes in it
may need to be done more than once. and up to once a month
the smell is caused by leftover detergent and leftover fabric softner gathering on the interior shell and in the rubber boot at the door.
front load washers do not require much detergent at all, and even less fabric softner.
be careful on how much of these you are using, more is not better
this will help prevent the odor from comming back
as well when laundry is not being done, the front door should be left open a bit to allow air movement in the washer.
hope this helps
May 26, 2009 | Frigidaire ATF6000ES Front Load Washer
Musty smell
Hey
try following tips:
  1. Check that the drain line is clear
  2. Check the drain hose for kinks or blockages
  3. Check pump for blockages
  4. Check for build up of soap in the outer tub
  5. Check for article of clothing stuck in the outer tub
please rate my suggestion...
May 21, 2009 | GE WBSR3140DW Top Load Washer
Whites going gray improper water level?
I cant say nothing with out a visual check, but gona give you a tip, in the past one client complain the same to me, and was a leaky transmission getting grase in the tube, check that point..good luck
Aug 06, 2006 | Kenmore 43142 Front Load Washer
Frigidaire FTF530FS Front Load Washer Logo
83 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
