Question about Toro Lawn Mower With Toro Power Tools
I need to replace my drive assembly on my Toro model 20071. How do I go about it?
WHere is a toro dealer that does warranty repair work in Jacksonville, FL?
Posted on Nov 28, 2009
Toro model 74373 - runs fine for an hr then right side Hydo drive assembly heats up and then toro engines stops running
sounds like two different issues. engine could be vapor locking. now the trans pump issue. pump is getting bad. it's probably cavitating. assy would need replaced.
Jul 04, 2017 | Toro Garden
Belt diagram for toro 74805
Go to Partstree,com type in the Model number, then look in the diagrams. If you are looking at the PTO/Hydro Drive assembly then go here:
http://www.partstree.com/parts/?lc=toro_commercial&mn=74805%2C+Z355+Z+Master%2C+w%2F48%22+Mower+and+Bag%2C+2001+%28SN+210000001-210999999%29&dn=3326-242-_2420014-00012
May 02, 2014 | Toro Garden
Toro recyler model 20071 wont start. has new plug getting gas. tech worked on it said he lined something up and it staqrted. what did he line up?
Have you removed the float bowl on the carburetor? If so, then it must be properly re-installed or "Lined Up" or your mower won't run. The float bowl has a bevel on it which needs to be pointed toward the hinge on the float so that the float can move up and down thru its full range of motion in the "deep" part of the bowl. Also these carbs have a very very tiny hole that gets clogged up easily on the brass bolt or main jet that unscrews from the bottom of the carb (1/2" wrench). The hole is a pin hole at the very top of the threads on that bolt that you can barely see. You need to clean it with a needle or very very thin piece of wire that can go all the way thru it and spray it out with carb cleaner. Of course you could have a number of problems, but I certainly hope this helps. Best of luck.
James
Sep 01, 2011 | Toro Power Lawn Mower
Install belt on toro mower model 70041
For removing/replacing the deck belt, the general method is:
  1. turn off engine, remove key and set parking brake
  2. disengage blade by putting blade engage lever into off (disengaged) position
  3. lower the cutting deck to the lowest position (closest to the ground)
  4. relieve the belt tension (depending on the model, use a 3/8 inch ratchet set to tighten in the square hole of the idler bracket)
  5. remove and replace the belt
NOTE: it's not necessary to completely remove the cutting deck.
Useful diagrams for removing the cutting deck, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14794
For deck belt diagrams, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14796
If the transmission drive belt needs to be replaced, several components must be removed and special tools (i.e. air/impact wrench) used in order to change the tractor's transmission drive belt. See an Authorized Toro Service Dealer to have your drive belt replaced.
Sep 09, 2009 | Toro Lawn Mower With Toro Power Tools
Replace the cable traction (part #105-1844)
I just replaced mine and it was a little difficult and took me roughly an hour to do. First, download the walk behind power mover drive systems at https://homeownersolutions.toro.com/portal/server.pt?space=CommunityPage&cached=true&parentname=CommunityPage&parentid=1&in_hi_userid=30166&control=SetCommunity&CommunityID=225&PageID=30031#manualsResultPage
While they do not specifically address replacing the cable, you can find out how they do it when replacing the drive belt. As I said, it took me about an hour and I just about had to remove the transmission and rear drive assembly in order to unhook the original cable. Good luck!
Aug 14, 2009 | Toro Lawn Mower With Toro Power Tools
Need linkage hookup diagram for Toro Super
Go to TORO.com and view parts for your model.
May 19, 2009 | Garden
No drive
Hello orlywooldrid:
>>You can View a Breakdown/IPL of the Mower at this Site Addy, https://lookup3.toro.com/partdex/default.cfm and Select Start Parts Viewer. Now Enter the Model Numbers (20622) and Click Search. Now Select View Assembly Drawings for your Year Model.
Everything you Asked is at the Above Site Addy.
Parts can Also be Purchased from this Site Addy;
http://www.outdoordistributors.com/
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 08, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
380 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
