SOURCE: interior dome light stays on when driving.
Sounds like the dome light has been turned on using the switch on the dash. Most of the time the dash dimmer switch is set up so that if the dimmer is in the maximum position, the dome light can be turned on. If the dome light has been turned on like this, it still will turn off after some time to save your battery. Then when you unlock the door with the remote, it goes back to the same state it was when it was left in - "ON". Check for this switch on the dash, and roll it to get it off of the "ON" position.
