Question about HP LaserJet 3015 All-In-One Printer
Print page is streaking in the center of page
Open the printer up , try cleaning the rollers with some alcohol. Possible some ink got stuck on the rollers at one point and when they heat up it streaks the page, other option is check your ink cartiridge that could be defective as well
Posted on Jul 01, 2009
    Brigadier General:
  • 8,619 Answers
Hi!
First of all please check if the scanner glass is dirty. If so, clean the ADF and flatbed glass.
Another problem might be with the scanner assembly which is required to be replaced.
If still the problem persists then the toner drum in the print cartridge is damaged and print cartridge needs replacement.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
3 Suggested Answers
POCBM
  • 121 Answers
SOURCE: Streak down the center of the page
The streak is most likely the toner or the fuser
This is the test to determine toner or fuser issue.
Print a test page
When you hear the paper feed into the machine open the top or front to stop the machine
Remove the toner cart.
You should be able to see the page with printing on it. (This is before the page hits the fuser)
If you can see the defect on the page the problem is most likely the toner cartridge but NOT the fuser.
If the page is clean the problem is most likely the fuser.
Hope this helps
Posted on Mar 25, 2009
omeshmaddy
  • 33 Answers
SOURCE: My HP Laserjet 1022 prints a black streak down the
change toner drum
Posted on Jun 06, 2010
When the paper prints, the color is missing in areas. It looks like a streak mark down the page. The black ink is full color, they yellow and cyan have a white, non-printed streak down the center, and...
Inspect the rollers for dirty or damaged surfaces. Clean up any loose toner or other debris in the machine. Note: avoid touching any roller with bare skin; especially in the fuser section or the photosensitive drum in the toner section. Skin oil can cause poor print quality or premature degradation of the roller surface.
Jul 06, 2017 | OKI C3200n Led Printer
Vertical streaks but only on first 2-3 pages
replace the image units associated with the color of the streaks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 17, 2017 | Konica Minolta Magicolor 4690MF...
Installed new cartridges but now it prints very lightly or not at all.
Print quality issues could be due to dirty or clogged print cartridge nozzles. Please follow the steps below to fix the problem:
Clean Cartridge Nozzles (Solution Center):
1. Open the Solution Center. Click Start > Programs or All Programs > Lexmark 1300 Series. Select Solution Center.
2. From the Maintenance tab, click Clean to fix horizontal streaks.
3. Click Print. A page prints, forcing ink through the print cartridge nozzles to clean them.
4. Print a document again to verify that the print quality has improved.
Sep 03, 2011 | Lexmark Z1300 InkJet Photo Printer
I have been having trouble printing my red. My letterhead contains a red "A" in it and a few other items have red. Normally, the red items have pink, yellow or white vertical streaks through...
Replace the magenta image unit. Yellow image unit also and for the white streaks have the glass that cover the laser cleaned.
Jul 29, 2011 | Brother HL4040CDN Duplex Unit
What are the steps to cleaning the print heads on the X1150 printer? New at this. Mike
On your computer, open the Lexmark Solution Center (go to Start, Programs, Lexmark 1100 Series, Lexmark Solution Center) > From the Maintenance tab, click Clean to fix horizontal streaks > Click Print. A nozzle page prints, forcing ink through to clean the clogged nozzles.
Source: How to Resolve a Blurry Print Issue Without Replacing the Cartridge
May 07, 2011 | Lexmark X1150 All-In-One InkJet Printer
Color streaks on page
Had a similar problem. Tried lost of things. In my case, the streaks cleared up after I cleaned the toner drum.
Aug 25, 2009 | Brother MFC-9420CN All-In-One Laser...
Print a test page
Hope this helps
Mar 25, 2009 | HP LaserJet 2840 All-In-One Printer
Black line down the center of the page when printing
1,check the scannor unit,which is doccument feed in open the cover look the piece glass is clean.
2, replace drum cartridge.
Dec 16, 2008 | Brother MFC-7220 All-In-One Laser Printer
Color Streaks down length of page
My rep advised that if this problem is occuring when using the feeder, the small glass strip to the left of the glass can have some sort of either high lighter or white out stuck to it. He suggests cleaning this with some alcohol.
Jan 09, 2008 | Ricoh Aficio CL2000N Laser Printer
HP LaserJet 3015 All-In-One Printer Logo
120 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
