Question about Saniflo Sanibest macerator with multiple connections
Pumps for a few seconds then stops & pumps again for another few seconds & so on
The toilet will flush normally and shut down. Then imediately after it has shut down, as it should, it will start up again and keep going through the flush cycle until I unplug the power going to the pump. After about ten minutes, I can plug it back in and it then will not start up again until I press the flush button.
Posted on Jul 04, 2009
Hi my beka 1400 wont wash water comes in for a few second and then stops its rinsing ok
beko take water in for few seconds then switch to test pump.....if alls well....then it restarts again...if yours doesnt........check the pump first... if it fills with water then stops.......check motor brushes .........
cheers
Nov 22, 2016 | Washing Machines
The pump will operate for 5 to 10 seconds and stop. 2 or 3 minutes later it will pump again for a few seconds. It takes a long time to drain the machine.
Drain the machine. Then turn power is off at the wall socket. Then tip machine back against the wall as far as you can. Get down under front right of machine & remove the wires going to the drain pump. Next remove the drain pump by turning it 90 deg clockwise. There is a white clip near the top edge of pump on R.H. side - hold that out while you turn it. Once it is out check pump & up in the pump outlet hole for obstructions. Put pump back with wiring plug facing R.H.side of cabinet then rotate 90 deg anti clockwise. Re attach wires and stand machine up.
Jan 04, 2016 | Fisher and Paykel GWL11 Top Load Washer
My aqua drive 1100 auto reset pool pump runs warm and stops after a few seconds after i switch it on then goes on after a few minutes And this continues. Why
Thermal Overload Switch: Something is creating an overload on the pump. Once it is overworked, the motor will overheat. This will be sensed by the T.O. switch. Once the switch senses that the motor has cooled, it will start again.
Reasons for overload:
  • Bearings no longer spinning freely & without restriction
  • Foreign debris in the volute, jamming against the impeller
  • Failing T.O. switch
Good Luck
Mar 11, 2015 | Aqua Pool & Spa
Why does my aqua drive 1100 auto reset pool pump work in intervals of a few seconds.it goes on for a few seconds then stops and after a few minutes it goes on again
Check for restrictions causing the pump motor to be overworked.
Motor is overheating, the the Thermal Overload Switch senses that and will trip. Once the motor cools, it will restart.
Intermittent Draining and Burning Smell
The water will not run in the machine.It will for a few second then stops. What could be the problem?
Aug 15, 2012 | Fisher and Paykel GWL11 Top Load Washer
I have a 2003 Nissan Pulsar Q series. I have recently replaced the fuel filter and pump. After turning on the ignition, the fuel pump will prime for a few seconds then stop. Any ideas as to what could be...
That's the way it works.
You put the key on , pump goes few seconds and stop(building up the pressure).When you crank the engine it start going again.
Jun 18, 2010 | Nissan Pulsar Cars & Trucks
1986 sei 1200 goldwing It will start from ignition on,fuel pump runs for a few seconds,fuel light goes out,every thing normal-no LED diagnostic lights.When it starts it will run for about 3-5 seconds &...
check the fuel filter it sounds like it's pluged and causing too much back presure this is causing an over load in the fuel pump causing it to stop working or to presure lock
Aug 03, 2009 | 1986 Honda GL 1200 Aspencade Gold Wing
Fuwl pump runs for three seconds and stops
The relay is supposed to run for a few seconds to bring the fuel pressure up to specifications,,then shuts off again,,this is normal behavior in most cars with electric fuel pumps.
When you start the vehicle, the pump will cycle on again and shut it'self down when it needs to.
Jan 19, 2009 | 1997 Jeep Tj
Saniflo Sanibest macerator with multiple connections Logo
482 people viewed this question
Top Saniflo Plumbing Experts
jasbo
jasbo
Gil Shultz
Vernon Taylor
Are you a Saniflo Plumbing Expert? Answer questions, earn points and help others
