Question about Car Audio & Video
My DVD player is portable and does not recognize the DVD. I have taken a Q-tip and lens cleaner, let it dry and it still does not work.
  • dghollowellm Jul 01, 2009
    My player is a 2005 version. It has not been played a lot. It seems to not be recognizing the video. It is also makes a little bit of noise.
    I am playing original DVD's. I have tried several originals.
    Debbie
  • 15,935 Answers
The laser is out of alignment.
Alignment and cleaning will be under $50
Thanks for using FixYa!!
Posted on Jul 02, 2009
    Brigadier General:
  • 3,917 Answers
HI,
Are u playing original dvds or burned????if ur having probelms with originals then how old is ur dvd player??and hopefully its under warranty because sounds like its just messed up.....if the screen is showing and everything else is working then its not wires....I hooked my screen up in my truck a few months ago and i can tell u to chek the wires but that doesnt seem to be the problem.. Thanks for contacting Fixya
Posted on Jul 01, 2009
Why does my philips portable dvd player not work
It is attempting to read the disc. Try another KNOWN GOOD disc. If you get the same error, try cleaning the lens using a lens cleaner disc or a dry q-tip. If no go, sorry, she's a gonner :(
Jul 20, 2014 | Philips PD7012 7" Widescreen Portable DVD...
Problems reading dvds
Have you tried cleaning the lens of the portable player? You can purchase a DVD cleaning disc, this disc has microfiber brushes which clean the laser len assembly of the player as the disc spins.
Hope this helps
Jul 06, 2008 | Televison & Video
My handheld dvd player isn't reading the disc-they just spin really fast
Spray an small drop of safe window cleaner onto a Q-tip. Clean the laser lens carefully and then use the other end of the Q-tip to dry it. Use compressed air on and around the laser lens (do not blow on it). Clean your DVD disc and try again. If it fails again, try using a CD, if it will play a CD and not a DVD your optical pickup assembly is defective. If the CD wont play at all, your optical sled or spindle motor and/or drive is defective.
Most cases if cleaning doesn't fix it, it's cheaper to replace the entire DVD player. All portable DVD players are junk, regardless of brand.
Jul 18, 2011 | Video Game Consoles & Games
WHY CAN'T MY PLAYER READ CDs ANYMORE?
Solved the problem by cleaning lens with plain water on a cue tip. Wasn't sure if a special solution was needed, but water did the trick.
Jan 30, 2010 | Durabrand PDV-705 Portable DVD Player
Will not read dvds
clean the lens with a dvd/cd lens cleaner (walmart, radio shack, etc.). or if you're feeling adventurous, remove the top, remove the dvd shuttle cover, and clean the lens with a q-tip dipped in rubbing alcohol. wip it off gently ad blow it dry with your mouth (as opposed to a hair dryer). the alcohol will evaporate. put it together and try it out. if it still doesn't read, you may need to replace the optical pickup (lens and motor).
Jan 06, 2010 | NexxTech DP3222 DVD Player
Dvd won't play
lens could be the last option to check, most common problem with portables is, the drive motor, try to change it then play it, still problem continues, then change the lens, it should solve your problem
Oct 25, 2009 | Audiovox ADV12 Portable DVD Player
It Loads but doesnt spin and said "no disc."
Try cleaning the lens with a DVD Disc Cleaner or Methylated Spirit and a Q-tip, rub the lens slowly in a clockwise motion, leave to dry and put in a DVD, if it doesnt work try a CD but make sure they dont have any scratches or dust on them, if a CD works ( or not ) then your lens is knackered.
jon
Aug 12, 2009 | Polaroid Portable DVD Player PDM-0822BD
It sais no disc when there is
PORTABLE DVD PLAYER NOT SPINNING DISCS AND SAYING NO DISC
When it is region lock it will say it on the display, if the player is not reading any disk, it is more likely a lens problem, see below:
Try first using a lens cleaner disk, like the ones here.
If that does not work, the unit must be disassembled, and lense cleaned with q tips and isopropyl alcohol or cleaning solution. See below:
How to Clean the Laser Pickup Lens on your DVD Player
How to safely clean a DVD lens?
Clean DVD lens, or replace player?
Clean CD or DVD ROM lens with a brush?
Cleaning your DVD drive
How to clean a DVD player
How do I clean my DVD player optical lens isoproponol alcohol
Feb 10, 2009 | Televison & Video
No disc
Hi TBS1,
You can open the lid and take a Q-tip lightly dampened with Glass Cleaner and swab the lens. Use the dry end of the Q-tip to dry the lens. If that does not work, you might try getting a can of Air from Radio Shack or someplace, as long as it is Dry Air, and carefull blow out the Laser. Write another comment in this thread if this does not help, and I will try to help you more. Good luck.
Nov 28, 2007 | Eddie Bauer PE702 Portable DVD Player
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
