Question about Meiko FV 40.2 Dishwasher
I have an err 205 on my meiko fv-40 dishwasher and the manual has only up to 202 what can be my problem or what does this 205 error means?
3 Suggested Answers
Kitcheneer
  • 11 Answers
SOURCE: dishwasher fix
111
Floor pan Leakage
Leak inside machine activating ground float switch
302
At pumping out during rinse cycle level does not fall below level 1
Drain pump faulty, blocked, aqua stop not closing completely, no signal from circuit board (connection number 6 on XA1 connection plug)
Posted on May 10, 2008
  • 7 Answers
SOURCE: Err Code 210
What you need to do is check the resistance of the booster tank temperature probe. The error 210 means a short circuit in the booster temp probe. At room temperature, the resistence should read about 1k Ohms. If you are reading significantly lower than that, then you will need to replace your booster temperature sensor. You also want to check the 4 pin square molex connector on the I/O board on top. Make sure all connections are tight, secure, and that there are no "bridges" across the connections for the temp sensors.
Posted on Feb 20, 2009
Meiko dishwasher DVD 80.2 showing error 202
202 Level not reached in booster tank during filling.
Level switch defective/disconnected, water turned off, inlet hose kinked, inlet strainer clogged.
Start with these basics.
Mar 17, 2017 | Meiko Dishwashers
Error codes 206
206 Increase in wash time Booster not ready for rinsing at right time. See error code 205.
205 Temperature increase not reached Booster heater not working, heat elements are open, defective temp sensor.
Per the service manual
Jan 06, 2014 | Meiko DV 80.2 Dishwasher
What does error code 205 mean on the Meiko FV40.2
This error code means your booster heater is not getting up to the proper temperature. You can check your amp draw across your booster heating element to verify it is in fact heating and not blown. Also, check your temp sensor for resistance. At room temperature, you should read about 1000 Ohms. At 180 degrees, you will read about 1500 Ohms.
Mar 15, 2010 | Meiko FV 40.2 Dishwasher
Keep getting error 202 just replaced the booster rinse motor and the heating elements meiko dishwasher
it's inlet water not sufficient. 1)check inlet water is entering in to machine. 2)may be inlet water solenoid defective. 3)check the rinse water pump is working.
Jun 24, 2009 | Meiko FV 40.2 Dishwasher
Err Code 210
Feb 19, 2009 | Meiko FV 40.2 Dishwasher
ERROR 203 on MEIKO MODEL D 120.2
error 203 means , no change detected by the level switch when draining . possible cause
1, booster pump faulty
2, booster pump plug connector loose
3, start capacitor faulty
4, plug connector loose
5, boiler level switch faulty
6, no boost pump signal to- i/o pcb
7, no "boiler full" signal from i/o pcb check booster pump/ s2with manuel control
the most lightly or most common is the level switch in boiler tank will need changing
Jan 21, 2009 | Meiko FV 130.2 Dishwasher
Meiko FV40.2 Error codes
212
Boiler temperature too high
Contactor faulty, probe faulty, check connection on XA5
The code 312 is the same as a code 212 as stated above.
There are dozens of error codes and you should be able to get them from your local meiko dealer, hope this helps, colin
Mar 10, 2008 | Meiko FV 40.2 Dishwasher
Dishwasher fix
111
Floor pan Leakage
302
Feb 28, 2008 | Meiko FV 40.2 Dishwasher
Error Message coming up
Hi, i work on these machines on a regular basis and until very recently i was a Meiko service engineer- the code ERR203 means that there was no change detected at the boiler level switch during emptying- be it on the fill or rinse cycle. This fault is mostly caused by the booster pump failing to pull water but could also be caused by blocked rinse jets or a faulty boiler level switch. Hope this info is of use to you , Kitcheneer
Aug 31, 2006 | Meiko FV 40.2 Dishwasher
Dishwashers Logo
140 people viewed this question
Top Meiko Dishwashers Experts
jdthefixer
Trevor Turner
Are you a Meiko Dishwasher Expert? Answer questions, earn points and help others
