Question about Sony Handycam DCR-TRV280 Digital Camcorder
Unable to load tape
I have a sony Handycam SCR-HC26. I can't load a tape in. Giving re-attach power source message with an error code C:32:11
I tried what was suggested, take out the battery turn off the camera, power back on and then hit reset. I tried this a few times, but it still won't load. I'm right in the middle of editing can someone help please
  • Sony Master
  • 586 Answers
according to the symptom you don't need reset, This problem is related to the loading tape path which is mechanically unstable, that's why problem arise, For your convenience please see the given below pic of SELF DIAGNOSTIC SYSTEM to understand better.
Your camera needs just mechanical adjustment by any expert, contact any expert nearby or from Sony for mechanical adjustment, this will solv the problem.
Thanks for using fixya.
Posted on Jul 02, 2009
Door not open
Before doing anything the numbers on this code tell you to clean camera and heads.
After it should all be fine.
Jul 02, 2010 | Sony Handycam DCR-TRV280 Digital Camcorder
I have replaced a Windows XP PC with a new PC running Windows 7 Home Premium and I have not been able to connect my DCR-HC26 Sony Handycam digital tape camera to the new PC. I'm using an I-link (firewire)...
Mostly with these cameras you do not need driver (unless you use a USB cable) but like me you have firewire okay? so you should unplug your camera, turn your PC off for a min or two, plug camera in THEN yes THEN put your PC on, and the Win 7 will see your camera and loads setting it needs auto ok.
May 29, 2010 | Sony DCR-HC26 Mini DV Digital Camcorder
My Sony Handycam DCR-HC26 started giving me C:31:23 error ''Reinsert the cassette'' when I try to record on a new Sony tape. I am however able play back a previously recorded Sony tape.
the error c:31:23 error pertains to one of the reel (part that turns the tape) is malfunctioning. although you can play back videos, you would definitely have issue w/ recording, rewinding or fast forwarding the tape.what you can do is to turn the camcorder off.remove the battery and ac adapter for at least a minute.insert the battery or reconnect the adapter.you can also try pressing the reset button (located near the top of the speaker, on the panel where lcd screen goes to).make sure cam is on when you do that.if still your getting this problem, service would be needed for your cam.hope this helps :)
Mar 18, 2010 | Sony Video Cameras
My sony dcr-hc28 developed a problem where the tape will not reinsert and i get a message "re-attach power source". i re-attach, nothing changes. i remove battery, power source, re-attach, nothing...
apply a DC voltage of 5v to the tape motor at the bottom of the camcorder. you'll find two little semi-hemispheres on top of motor. trial and error to figure out which is positive.
Dec 17, 2009 | Sony Handycam DCR-HC28 Mini DV Digital...
My sony handycam dcr-hc26 door won't close. error C:32:11
Remove battery/ power source from camcorder for minute, reattach battery/ power source and close the tape door.
If that does not solve problem then I'm afraid, tape mechanism got defective and will be replaced.
Let me know if you need tape mechanism part number info.
Thanks.
Dec 09, 2009 | Sony DCR-HC26 Mini DV Digital Camcorder
I have a sony handycam dcr-hc26 that wont close the type door can you please help me ??
I have a sony handycam DCR-HC26. After loading in the DV cassette tape and the tape cannot get loaded in and therefore I can't close the tape door. Please help.
Thanks
Nov 22, 2009 | Sony DCR-HC26 Mini DV Digital Camcorder
ERROR C:32:11
GO TO REPAIRING INTERNAL PROBLEM
Sep 09, 2009 | Sony Handycam DCR-TRV140E Digital...
"Re-attach the power source" but tape is stuck, door open
I had the same problem. First, depress the reset button, located on the camera body (where the LCD screen closes over it). It is hard to see at first. It is important that the camera be set to the OFF position. When the camera is whirring after the reset, then hit the EJECT button so the tape comes out. Take the tape out and insert it back. That's it. My camcorder worked fine and let me record or plaback once I followed those steps.
Vic
Aug 22, 2007 | Sony Handycam DCR-TRV280 Digital Camcorder
Re-attach the power source followed by Reinsert Cassette
Hai Problem in mechanism. If the tape does not loaded completely, the message will show "Reattach the power source" Please check mechanism. Raghavendra, M/s.prathiksha Electronics
Jan 25, 2007 | Sony Handycam DCR-HC90 Mini DV Digital...
Sony Handycam DCR-TRV280 Digital Camcorder Logo
409 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
