Question about Carrier 38CKC042 Air Conditioner
Where is the reverse valve? - Carrier 38CKC042 Air Conditioner
  • 158 Answers
Outside near compressor
Posted on Jul 01, 2009
I have a 1999 comfortmaker heat pump i need to know if the revercing valve is normal in heat or cool
not sure if this helps but is how it works...
Comfort Maker energizes the reversing valve in cool. The reversing valve coil should be wired to "O" from the thermostat. Take the wires off the the reversing valve coil, it should switch to heat. If it does not, and the compressor is running, the reversing valve is bad! Replace it.
Note: that clicking sound you hear was the pilot valve in the reversing valve. Within a couple of seconds of hearing that click, it should have reversed. IF it does not, you have a bad valve.
Electricity switches the pilot valve. The pilot valve switches the Freon pressure. Freon pressure switches the reversing valve.
hope this makes sense.
best to you.
Dec 31, 2017 | Heating & Cooling
Where do I find my reverse valve
Mogamad
A reversing valve a type of valve and is a component in a heat pump, that changes the direction of refrigerant flow. By reversing the flow of refrigerant, the heat pump refrigeration cycle is changed from cooling to heating or vice versa.
make and model would help along with detailed question.
RE POST WITH INFO
Diagnosing the stuck HVAC reversing valve
Jan 29, 2016 | Heating & Cooling
Is there a pin in the transmissio n or transfer case that can come loose to make it not shift into reverse
There's no pin as such. An automatic gearbox does have solenoids for operating valves.
A valve can become stuck.
Reverse gear is first gear - when you select reverse a 'cog' moves onto first gear to reverse the direction of the gearbox output shaft - giving you reverse.
It may well be a stuck valve. Try selecting reverse a few times after the car has been run and the fluid is hot. A stuck valve (in the transmission) may free itself
Jan 22, 2016 | Cars & Trucks
Replace reverse valve ir 2135
Did you ever get the 2135 reversal valve installed?
Jan 24, 2014 | Ingersoll Rand 2135Ti Air Impact Wrench
Cool mode well reverse ob valve to heat
On a Rheem the reversing valve engages on heat. On a Goodman (and most others) the Reversing valve engages on cool. You will want the thermostat to engage the reversing valve on the orange. There may be a switch in the thermostat that allows you to chose either O or B. Select O. If you have a choice of wire on the thermostat of either O or B than choose O. Also check and make sure the thermostat wire goes to the outside unit. Also make sure you have a thermostat that is comparable with your heat pump.
Jul 01, 2010 | Goodman CPLT24-1 13 Air Conditioner
Is there a way to free up a stuck reversing valve
Before you get ahead of yourself, check to ensure that the reversing valve is the problem. You may have an electrical problem that is preventing the reversing valve from moving either by the reversing valve being constantly energized or not energized at all.
But if your reversing valve is sticking...
Since most reversing valve failures are due to a low refrigerant charge and/or lack of proper maintenance, there is not much you can do outside of getting the system serviced and have the refrigerant levels checked.
If the reversing valve has failed, you should take into consideration the age and condition of your current system. It may be more economical to replace the system in that situation.
Jan 07, 2010 | Ruud UBHC Air Conditioner
I have a goodman heat pump and i suspect a bad reversing valve
Sounds like reversing valve is stuck or metering device or check valve is stuck open. If it is a scroll compressor on 3 phase you may need to reverse 2 motor leads. try tapping reversing valve with rubber mallet when running. This may have done in last compressor by sending discharge gas to suction side.
Jun 28, 2009 | Heating & Cooling
Reversing valve issues.
You will need to replace the reversing valve. You cannot replace the coil with a remote sensing bulb on this unit. Usually you know when reversing valves get stuck when you are having low side problems with heat working properly
Jun 01, 2009 | Ruud UPMC036 Air Conditioner
Reversing valve not switching over to air on heat pump. compressor will come on for about 10 minutes, then shut off. Hot air comes out vent.
Look for any refrigerant leaks - no or low refrigerant can cause problems in both modes. The unit may be going off on low suction.
-OR-
The unit may be stuck in the heating mode.
Make sure the system is calling for the correct mode (cooling or heating) - some systems are auto, but if you can, select cooling since that is the requested mode. Check for power at the reversing valve inside the condensing unit. If power exists, then the reversing valve is stuck. It could also be the reversing valve solenoid coil, so make sure that isn't bad. There should be a strong magnetic field at the solenoid coil.
If you can hear the reversing valve clicking (moving), check the T-stat and make sure it will switch modes. Also check the reversing valve relay (those can be located in either the indoor unit or condensing unit).
May 25, 2009 | Ruud Matching Split Air Conditioner
HEATER DOES NOT TURN ON BUT AC WORKS.
- If no voltage output at the thermostat for the supply of heater/reversing valve, then replacement of thermostat is needed (but check the thermostat setting).
- If the voltage output at the thermostat for the supply of heater/reversing valve is present, then then check for heater/reversing valve fuse or overheat protection, and check for defective heater/reversing valve
Jan 03, 2008 | Honeywell Programmable Thermostat Heater
Carrier 38CKC042 Air Conditioner Logo
37 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
