Question about HP Pavilion dv5-1000us Notebook PC
Screen is black. Hear computer trying to boot up.
Put ''to sleep'' yesterday. Last night heard the
fan on, tried to get the screen to come up - nothing.
Computer was hot. Shut down. Have tried 4 times to turn
on - heard the normal sounds but screen is black.
    Sergeant:
    Champion:
  • 233 Answers
The issue could be with battery, adapter or hard disk
I recommend you to follow the steps in the below link:
http://notebook-solutions.blogspot.com/2009/05/notebook-solutions-notebook-solutions.html
Follow the steps from No Boot or no Power in laptops
Posted on Jul 01, 2009
  • 1,800 Answers
Cpu fan failure try to put a big fan where the comp vents and air flows! and see if its not shutting down!
MSI L1600 netbook seems to be stuck in sleep mode. The power also cannot be turned off - even removing the battery and replacing it.
try to boot the computer, if you hear the start up sound then mobo is not bad. this issue could be caused due to boot sector viruses as well. see if the back light turns on ..
check the settings in bios and try to run a recovery. if neither helps
call 1-877-805-1027 for expert help
Jul 30, 2015 | MSI Computers & Internet
M15x gaming laptop screen wont come on after sleep mode or reboot. What can I do?
Looking at your last comment, it looks like you got it working??? Just an heads up, in the future, you might not want to put your laptop into sleep/standy mode while performing an update. If you lose power or have to do a hard shutdown you could corrupt the update and your PC might not boot back up.
Jan 09, 2013 | Dell Alienware M15x Gaming Notebook
Have a Toshiba Qosmio F45-AV411 and downloaded windows 7 last night. worked fine then I put comp in to sleep mode when I tried to turn on today looks like it is booting up and then goes to a black screen...
Try to boot up the computer using safe mode first. Keep on tapping the F8 key the moment you turn on the computer. If your computer wont boot to safe mode then you need to re-install windows 7.
Jun 13, 2010 | Sony Toshiba Qosmio F45-AV411 Notebook
When I booted my Macbook Pro today, I could hear the hard drive being accessed, but the screen remained black. Have you heard of this problem before? Last night, it was fine and showed no symptons
yes this happens. you can try doing this: power down then power up whilst holding down command, option P and R all at the same time. press these after you hear the chime. hold until you hear the chime a second time.
May 05, 2010 | Apple MacBook Pro Notebook
I am unable to get the netbook to boot up. It turns on, I hear the Hard drive humming, but it only goes to a black screen with a cursor that won't work either. All I did is leave it on at night (which I...
Try draining the flea power first
1. Remove the battery and ac adapter
2. Press and hold the power button for at least 10sec.
3. Put back the battery and ac adapter
4. Turn on the computer
check if it will boot to windows, if not, there is a problem with your windows OS, try using startup repair. Hope this helps
Dec 11, 2009 | Acer Aspire One AOA150-1570 Notebook PC
Put my laptop on sleep last nite.... went to start it this morning.... nothing.... it powers up and i can hear the fan but screen is black
usaully on a laptop there is a function key that controls video output. this key normally has three positions. Video to laptop screen only, Video to laptop and vga output (IE. lcd projector2.gif), and the last one is "Video to vga output only". The last setting will keep your laptop2.gif screen blank. It is worth a try. GOOD LUCK!!
Oct 14, 2009 | HP Compaq Presario CQ50-210US Notebook
Screen not responding
can you hear any boot sounds?
(fan noise, harddisk rattling)
do the LEDs work (battery and charger , Hdd, CD/DVD-ROM-drive,WLAN)?
this would indicate it still boots up, but screen might be broke.
u lucky?
- remove battery pack! retry booting
if not, hook it up to another external monitor
(use vga-jack in the back of it)
reboot, wait for signal
- check if the the fan is jammed
(due to sand???)
this might cause overheat problem -
use compressed air to blow/clean the fan inlet
still no luck? it simply may be broke...
Aug 04, 2009 | Computers & Internet
Black Screen on Startup.
Did you try " Last known good configuration at start up. If after boot you press the F8 key where you said you went into safe mode, did you try to load the good known config. It sounds like you have a corrupted registry.
Jul 14, 2009 | Acer Computers & Internet
I have an HPa6700y I purchased about three months ago.  At the time of purchase I installed a high-end graphics card myself (ASUS EAH4870 DK/1G Radeon HD) and it had been running beautifully until...
usually there are 2 problems: 1. a vga card overheat when running 3 games the vga card heats up. try using an case fan or adn a vga fan. 2. the game uses a high refresh rate in this case tri to set a default refresh rate from the vga driver. hope this helps
Jun 14, 2009 | Computers & Internet
Monitor falls asleep during/after startup
control panel
click power settings
set the monitor to never sleep or dim
same on all windows.
the monitor is totally programmable
why not tell OS?
windows 10?
or google
why does my windows 10 monitor go to sleep
10,000,000 hits
endless.
the defaults under windows, are always wrong,
it's to keep the FEDs happy with there Energy Star bs.
im on laptop now far far from USA
set it all to not use sleep etccetra.
Feb 28, 2017 | HP Computers & Internet
HP Pavilion dv5-1000us Notebook PC Logo
224 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
