you plug it in. on windows a little thingy that says "found new hardware" will apear. wait until it says you hardware is installed and ready to be used. go to my computer. click on the drive, which will probably say usb mass storage device, or disk drive. click on it. now open the folder with the data you want to transfer, and drag and drop. are your files dissapearring?? if so side click one of the files click copy, and go oven to the drive and click paste. for the files that are already gone from the folder copy and paste them back.
1. Place the flash drive into your usb port. You might get a autoplay window to open up. You will see Install or run program (Run launchu3.exe). Click on this which will open up the lauch pad. Once the launch pad has opened you can click on the launch pad in the tray and it will open up the removable disk.
2. Right click on your start button. Click explorer this will open up a menu of your drives. Click on the one that shows removable drive. This will open up the drive and you can now start moving files into this drive.
3. Double click on my computer located on your desktop. This will open up a menu of drives. Click the drive marked as removable drive. This will open up the drive and you can now start moving files into the drive.
Vista Machine (3 ways to access your drive)
1. Plug in the flash drive. The autoplay will open up. Click on the launchU3.exe which will open up the launch pad. Once the launch pad you can click on the launchpad in the tray and click on the removable drive.
2. When the autoplay comes up you can click on the Open Folders to view files. This will open up the drive.
3. Click on the start button menu then click on Computer. Then double click on the drive marked as Removable drive.
Hi, had a look online couldn't find a manual for your micro but thereis a lot of info and really good videos on the manufacturers site.Will give you some links for the right parts of the website.
my sanDisk 4GB usb stick just stopped opening and cannot access my stored data-tried in different...
(More)
my sanDisk 4GB usb stick just stopped opening and cannot access my stored data-tried in different computers.Is just not showing any response.Thanks.Lovemore
who can fix my 1 gb cruzer? It has a bent port and my dog chewed it a little. It lights up and...
(More)
who can fix my 1 gb cruzer? It has a bent port and my dog chewed it a little. It lights up and registers but no files or storage use are found.
I can't get access to my usb. I installed win 7 but in xp i can see it very well. what's the...
(More)
I can't get access to my usb. I installed win 7 but in xp i can see it very well. what's the problem???
