Question about GE PDS22SBRLSS Bottom Freezer Refrigerator
GE refrigerator model TFX24RF runs all the time.
Runs all the time. Nothings shuts off. Freezer and refrigerator get cold.
SOURCE: ge refrigerator
This happened to me with my side by side. The repair man came to my house, said that GE have cheap refrigerators because they are not meant to last very long. The mother board that controlled the temperature went out. A component in my freezer would get frosted up, but the heater would not kick in to reduce the freezing. Everything starts to warm up in the refrigerator as a result. A new motherboard would get the refrigerator back in timing.
Posted on Aug 21, 2007
SOURCE: Refrigerator warm, freezer too cold
I had this same problem. You need to totally empty the fridge and freezer and allow it to defrost for 24 hours. Then put it back on and it will work. This happens if someone leaves the freezer door open and then it gets closed. The defrosted water freezes in the pipes and doesn't allow the cold air to move up into the fridge so the freezer gets even colder. This has happened to me twice!
Posted on Aug 16, 2008
rpbuice
  • 161 Answers
SOURCE: GE Profile Stainless Steel Top Freezer Refrigerator
Check the compressor.
Unplug for 15-20 min. plug it back in and listen for the compressor to start. You will have to be behind the ref to listen and make sure you hear the compressor start and not just a fan running. If you hear a clicking noise then the compressor relay is bad.
Posted on Dec 17, 2008
Maanita
  • 1142 Answers
SOURCE: fan runs constantly, freezer ice melting, bottom drawer in refrig
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
  • Posted on Mar 24, 2009
    hiltonjug
    • 612 Answers
    SOURCE: GE Refrigerator-Freezer side works fine/Refrigerator side not ok
    You most likely have a defrost problem. Check the inside back panel of the freezer. See if there is ice built up. If so, you have a problem with the defrost. 85% of the time, it's caused by a bad heater. It could be the termination thermostat, timer or fan. If the ice is built up. Take the panel out and defrost with hair dryer. If you want, you can now check the heater and termination thermostat. It's a closed switch that opens on the rise. If you fix it your self or not, To save your food. You can replace the panel and turn the fridge back on, it will operate correctly for 3 or 4 days. This will give you time to either get the part and fix it or for someone to get out and repair.
    Please rate solution and make it worth the while to summit solutions. Thanks
    Posted on Aug 28, 2009
    Ge profile bottom freezer model # PGSS5NFXA SS. Got up this morning and freezer thawing both fridge and freezer same
    Not sure if the compressor is running. If not, you'll need a repair man. Since fans are running, most likely the thermistor. Also, if you haven't unplug from the wall, wait 10 seconds then plug back in; this may reset the control board. The link below may help. GE Refrigerator Not Cold Enough
    Feb 03, 2015 | GE Refrigerators
    My GE refrig. Model dss25srdss runs but does not get cold at all I opened the back panel the compessor runs and so does the fan but the fan seams like its runing slow.
    Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
    If your refrigerator is running but warm, then...
    Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
    Refrigerator Condenser Coil Cleaning Refrigerator Repair
    Refrigerator Troubleshooting Refrigerator Compressor
    Refrigerator Compressor Start Capacitor and Start Relay
    Refrigerator or Freezer not Cooling or Getting Cold
    heatman101
    May 24, 2011 | Refrigerators
    Freezer works good but food side doesnt get cold and fan in freezer runs all the time
    Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
    Refrigerator not Cooling or Fridge not Cooling
    How to Defrost Refrigerator Defrost Timer Problem
    Water Running in refrigerator from Freezer
    heatman101
    Jan 27, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
    Hi! I have a GE Freezer Model FUF14DTARWH that runs but the coils are not getting cold enough to freeze???
    Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
    If you are hearing a clicking or buzzing then check out the last two tips.
    Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
    heatman101
    Nov 15, 2010 | GE 13.7 cu. ft. General Electric Upright...
    Freezer not freezing properly
    You have a manual defrost freezer . Ice build up of over 1/2" can act like insulation on wires . If you have no frost build up , and runs constantly , then compressor or refrigerant leak is the problem . Advise to replace freezer . Only 2 parts on manual defrost freezer...compressor and cold control . Compressor will not run if bad cold control . If you have a leak , very expensive to have repaired .
    Jul 10, 2009 | Whirlpool GD2SHGX Refrigerator
    Compressor runs less frequently freezer warms between cycles
    if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
    any further question let me know.
    thanks,,
    Mar 29, 2009 | GE Refrigerators
    GE fridge runs continuousely
    Simple! The replacement fan ran the wrong way forcing air circulation the wrong way. Fortunately it was possible to reverse the moter shaft.
    Dec 11, 2008 | GE GBS22HCR Bottom Freezer Refrigerator
    GE SIde By Side - No cold air on the freezer side.
    Do you hear fan running in freezer? Should be on when you hear that external fan. If not, you may need an evaporator fan motor. Also check board in back for burned resistor. May need to replace both.
    If that fan IS running, remove lower rear wall of freezer and inspect the defrost heater. It's at bottom of coils. It has a wire leading to both sides. Remove with 2 screws and check for continuity. If open replace defrost heater. This is a common failure on these.
    Nov 18, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
    Ge refrigerator
    Aug 02, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
    GE PDS22SBRLSS Bottom Freezer Refrigerator Logo
    465 people viewed this question
    Top Refrigerators Experts
    Sal De
    Charles T Nevin
    Charles T Nevin
    Randy Justice
