Question about Poulan Garden
GHT-22 Hedge Trimmer Fuel Line Replaced and Still Won't Crank
I have a Poulan Weedeater GHT-22 Hedge Trimmer and the Fuel Lines Have Been Replaced, But I Still Have Problems Cranking It. How Do I Repair This Problem? Also, Once it Does Crank It has to be Cranked Again Within 5 Minutes, Sometimes Less Time Goes By Before I Have To Try and ReCrank It.
Any Help Will Be Greatly Appreciated
Thank you,
Wendy
  • Jack McNutt
    Jack McNutt May 11, 2010
    Sorry, I can't solve your problem, but you could solve mine. How did you get your fuel and vent lines into the tank and connected properly?
    Master:
  • 285 Answers
To solve your problem i am sure you can solve your problem just visit at the link given http://toolsnyou.com/
Posted on Aug 09, 2017
Nic61
  • 1073 Answers
SOURCE: does anyone know where I can dwonload a users
Hi!
Yepp, i can help you! There are 5 diferent ones of that GT225
I dont know witch one you have so i'l give all five here:
HEDGETRIMMERWEEDEATER --> GHT225 ( 952711803 )
Manual: View
Parts Manual: View
HEDGETRIMMERWEEDEATER --> GHT225 LE ( 952711803 )
Manual: View
Parts Manual: View
Manual: View
Parts Manual: View
Manual: NO MANUAL AVALIBLE
PArt Manual: View
Manual: View
Parts Manual: View
Or you can go to this site and type GT225 in the search window:
http://www.poulanpro.com/poulanpro/manualSearchPrepare.do
Good luck
Nic
Posted on Apr 22, 2009
  • 279 Answers
SOURCE: Describe your Black & Decker Hedge Hog
You may have a piece of metal between the moving blade and the stationary one. Also the motor may have been at the top of the stroke when it stopped. You may be able to "force" the blade to move a little. This may free it enough to work.
Posted on Jul 14, 2009
lemmingleejn
  • 173 Answers
SOURCE: Weedeater hedge trimmer will not stay running.
Firstly, make sure that the fuel mixture is good, as old or incorrectly mixed fuel, is a possibility.
Then as long as the air filter, and spark plug are ok, check that fuel is entering the carb. If so, you can adjust the timing, by expanding or reducing the gap between contact, and the magneto/coil.
You can also adjust the timing, by changing the gap on the plug too.
There ya go,
FixedYa!
Don't forget to rate, thanks ;)
Posted on Aug 01, 2009
  • 10865 Answers
SOURCE: carburater fuel mixture settings
your best bet is to buy one small bottle of poulan oil, which will be added to one gallon of gas.
Posted on Sep 12, 2009
SOURCE: sharpen hedge trimmer blade??
My trick is to make sure that I always lube the blades after each session with a 3/4 engine oil + 1/4 kerosene mix - making sure that every tooth gets a drops or 2, then run it for a seconds to spread the oil & leave the blades overlapping. Doing this allows the blades to self sharpen I've found. 2 stroke oil , unmixed is about the perfect viscosity aswell.
Posted on Feb 18, 2010
Carberator adjustment on weedeater ght-22 h screw anf L screw
Turn the "L" screw in until lightly seated, then turn out 1 1/2 turns then lightly seat the "H" screw and then turn it our 2 turns.
Apr 16, 2011 | Weedeater Excalibur Gas Hedge 22" Trimmer...
I just put new fuel line on my trimmer now i cant start it not getting fuel the line never fills with fuel but i can **** fuel out so i know it not pinched it a weedeater brand ght-17
Make sure the little valve under the tank if you have one is fully turned clockwise. Make sure there is nothing clogging the tiny screen inside the fuel tank. Check or test your primer bulb it may be leaky. If carb or intake is leaking, you won't get gas either. If you have a filter on this model, try changing it.
Sep 10, 2010 | Poulan WeedEater Hedge Trimmer 25cc Engine
Not getting spark because i loosened the adgustment screws
GAP ON THE COIL ? USE A MATCH BOOK COVER. SPARK PLUG FOLD THE MATCH BOOK
May 25, 2010 | Poulan WeedEater Hedge Trimmer 25cc Engine
How to get new plastic fuel lines in fuel tank in my weed-eater hedge trimmer. the line is larger than the hole in the tank.
Oftentimes it helps to use scissors to trim back a portion of the new line. Start at the bottom and cut upwards at an angle. Put some lubricant (WD40, perhaps) on the line and slide the sharp point into the fuel tank. Using needle nose pliers, grab the line and pull it through. This will only work if you have the correct size line. If the new line you are using is too large, you probably can't pull it through.
Apr 20, 2010 | Poulan WeedEater Hedge Trimmer 25cc Engine
Should there be two lines going into the fuel inside the tan k
Yes one is the pick up line and should have a filter on it, The other is a return line which usually comes from the primer.
Jul 18, 2009 | Poulan WeedEater Hedge Trimmer 25cc Engine
Poulan GHT-22 Hedge Trimmer The Primer Button Will Not Inflate
When changing the fuel lines did you get them back in the correct location? This would prevent the bulb from working. Also, if the bulb is old and brittle or leaking, would also cause hard start or leaks around the handle.
Jun 18, 2017 | Poulan Garden
Poulan Weedeater GHT-22 Hedge Trimmer Leaks Fuel Near Handle
Either the fuel lines that were replaced are a poor fit in the tank ( wrong diameter pipe ) or the pipes have been connected incorrectly to the fuel primer bulb.
Dec 13, 2017 | Poulan Garden
Ght225 Weedeater hedge trimmer
try sanding the fly wheel and the coil to get the rust off
Jun 17, 2009 | Poulan Ght225 25cc Gas Hedge Trimmer
Garden Logo
5,304 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
