Question about Spark Plugs BR4HS Plug 10/BX #3322
Torch a7rtc spark plug what is a match - Spark Plugs BR4HS Plug 10/BX #3322
CR7HSA (NGK)
Posted on Aug 20, 2009
What size/type socket do I need to remove spark plug on my Ryobi 2300 generator. I've tried 1/2 thru 13/16 and none fit.
i cross referenced the spark plug (LD A7RTC)
and got the NGK equivalent:
SKU: #CR7HS
ITEM : # NGK7223
BRAND : NGK
Then got the specs off the NGK site
NGK 7223 CR7HS Nickel Spark Plug
It should be a 5/8" (16mm) spark plug socket.
Apr 08, 2018 | Cars & Trucks
What is the equivalent to a 5r6a ?
If you type this question into google you will get several equivalents. You may find questions like this are more quickly answered using google rather than waiting for Fixya answers
Dec 09, 2017 | Cars & Trucks
My 1977pe250 Suzuki won't start and is flooding is it the float or what
Could well be. Take the carburettor off and remove the float bowl in the bottom Carefully remove the float by sliding the fixing pin out. Check the fuel inlet jet for particles. Reassemble. Take your plug out, check the gap, and warm it up with a gas torch to clean it of petrol and oil. Brush with a wire brush. Screw it back in warm and start the engine with no choke.
http://images.cmsnl.com/img/partslists/suzuki-pe250-1977-1979-usa-carburetor-pe250n_bigsuusa90687_092c.gif
May 30, 2016 | Suzuki Motorcycles
What spark plug is used in an unidentified trimmer/edger?
Ryobi 4-Cycle Spark Plug-AC00164A - The Home Depot
www.homedepot.com/p/...4...Spark-Plug.../203222932
The Home Depot
Rating: 4.3 - ‎3 reviews - ‎$4.97
6 days ago - Keep your engine running smoothly with the Ryobi 4-Cycle Spark Plug forTrimmers. ... Use the replacement spark plug with any of Ryobi 4-Cycle engines. ... Replaces champion RY4C and torch CMR7A.
2-Cycle OEM Spark Plug (RDJ8J) - Sears Outlet
www.searsoutlet.com/2-Cycle...Spark-Plug.../product_details.jsp?pid...
Shop for a 2-Cycle OEM Spark Plug (RDJ8J) (49M0311P953) at Sears Outlet today! We offer low prices and great service.
Nov 28, 2015 | Garden
I get spark but not a lot and only every couple pulls what could it be?
Cars and "pulls?" This sounds like a small engine such as on a chain saw or lawn mower. Also, you are using the word "spark" when I suspect you mean that you mean detonation. If you get any spark, it is almost certainly happening every time you pull. You can verify this by pulling the spark plug and with it connected to its wire and the threaded part well grounded, pull on the starter IN THE DARK. That way you can see the spark. If you can verify this, then put it back in and make sure you have the choke set adequately for the engine temperature. If it has been a long time since the engine has run, it may take a while. I'm known people to take a torch such as a propane torch to the outside of an engine block in the area of the head (where the spark plug goes in) and use it to pre-heat the engine. Make sure that spark plug is in before doing this, and don't put a torch on a painted surface, or you will burn the paint off. If all else fails, your auto parts store may have a spray can of something roughly equivalent to ether, which you can spray into the cylinder through the spark plug hole, reseat the plug and then try. Ether has a lower flashpoint than gasoline.
Feb 03, 2015 | Cars & Trucks
1983 Bronco... turns over no problem.. but wont start up
Check for fuel and spark.If you have fuel but no spark chances are that you may of gas fouled the plugs.Pull one plug out and make sure it's not wet with gas.(If they are replace plugs or if you have a small propane torch you can torch the carbon off the tip).Attach plug(thats out of the engine) to plug wire,lay on fender and turn over engine.Watch to see if there is a spark at the tip.For fuel check look down carb w/vehicle off and pump the throttle by hand to see if gas is squirting into the carb
Sep 22, 2009 | 1983 Ford Bronco
Geely Runner JL50QT-44 Parts
Hi, Aylott you have an obscure motorcycle that has little to zero information out there in cyberland. For this reason, my answer may not be very helpful and I apologize for that.
For any more information about your question and possibly valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
JL50QT 5 Fighter Jinlun Scooter Parts Racing Planet USA
2010 Jinlun Jl50qt 4 No Spark No Power On CDI
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
Jinlun JL50QT 5 Fighter Scooter
Geely JL50QT 21 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Oct 22, 2017 | Motorcycles
Reddy heater TB100 propane
Well it sound like you have all the components working. Try lighting it with a torch or long match or something. If it lights, then you may need to adjust the spark-er. You also may need to adjust the pilot. It may be too much pressure, which will blow out the flame, or its not enough gas. Make sure the pilot orifice is clear.
Mar 01, 2008 | Reddy Heater-30-55,000 BTU Variable
Spark Plugs BR4HS  Plug 10/BX #3322 Logo
3,277 people viewed this question
Top Ngk Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Ngk Vehicle Part and Accessory Expert? Answer questions, earn points and help others
