Question about Canon FaxPhone L75 Plain Paper Laser
No print on rec'd or sent faxes
I have just installed a new toner cartridge for this particular fax/phone machine & still have problems printing on anything rec'd or sent. No error messages are present.
  • heather124 Jul 07, 2009
    And that is exactly what I mean. Not receiving or sending with any toner on the paper. And yes, all of the pckg. seal has been removed. Will look into a faulty cartridge (hopeing it's not faulty as it's brand new). Any other suggestions?
  • 149 Answers
Surely you don't have blank copies rec'd and sent as these are two different parts of the machine entirely. I'll assume you mean rec'd and copied. Sounds like you've left a packaging seal on the cartridge to me - or it's a faulty cartridge. Remove the cartridge and check that all packaging has been removed - especially plastic strip that prevents toner from dropping into the cartridge.
Posted on Jul 06, 2009
How do I change a Drum Cartridge in a Konica Minolta Fax 2900 / Fax 3900?
toner and drum are separate the toner attaches to the drum unit.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 20, 2014 | Konica Minolta Minolta FAX3900 Digital...
Having a clicking noise problem when installing a new toner cartridge into the fax machine. Reusing the old cartridge makes the noise go away. There is nothing wrong with the new toner (we have 2 and both...
You state that you have 2 new toners and both make a noise, but the old one does not. If both the two new toners came from the same source then it is possible that the vendor has a quality control problem and manufactured several defective cartridges. It does happen. If these are not genuine Muratec toners, that makes it all the more likely because often they are remanufactured and attention was not paid to details. Is the old cartridge from the same vendor and does it bear the same brand name if it is not a genuine Muratec item? 15 years in this business tells me that if the old one is quiet and the new ones are noisy, something is wrong with the cartridges, not your machine.
May 05, 2011 | Muratec F320 Plain Paper LED Fax
Toner Life has ended
Did you pull the plastic tape on the cartridge?
Feb 11, 2010 | Brother IntelliFax-2820 Laser Fax
Hp 1040 ran out of paper/after restocking now prints blank pages
Even though the toner was shown at 1/2, I had the fax machine operator install a new cartridge. Problem solved!
Aug 24, 2009 | HP Office Equipment & Supplies
White space in middle of faxes sent or received
Printing irregularites on sent faxes are due to spots or a dirty scanner.
Spaces on received faxes are due to a dirty drum, corona wire, or a failing or improperly installed toner cartridge. A new cartridge should be gently shaken back and forth sideways prior to installation.
Jun 23, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Panasonic kx-fl511 has blank vertical lines on fax when printing.
It's important to gently move the toner cartridge from side to side to distribute the toner evenly through the cartridge. This could be causing your blank lines. Also, clean the Corona wire when installing a new toner cartridge. Best of luck.
Greg
Jun 10, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Sent faxes not printing clear
Per Brother's User manual,
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_IntelliFax_4100_4750e_5750e_EN_98.PDF
Clean the machine’s interior and the primary
corona wire of the toner cartridge This is a common cause for your printing/copying problem. This should solve your issue. Best of luck.
Greg
May 20, 2009 | Brother IntelliFAX 4100 Laser Fax
D C LIFE MESSAGE COMES ON
Which cartridge there are two one is toner the other is the drum which is where the toner cartridge is installed.
Feb 17, 2009 | Konica Minolta Minolta FAX3900 Digital...
Problem with printing
CRU Fuse Error The toner cartridge is
not installed correctly.
Install the toner cartridge
correctly. See “Replacing the
Toner Cartridge” on page 8.4.
www.zinetic.o.uk
Sep 04, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Screen faxes ?
Fax on this model have no connection to computer. So faxes sent on this machine or for that matter on any fax machine cannot be viewed on computer. it is only possible if you have a fax modem attached with your PC. If you want to save on toner get the cartridge refilled.
Jun 06, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Canon FaxPhone L75 Plain Paper Laser Logo
70 people viewed this question
old marine
old marine
