Question about Grilling
Cadac eazi chef flame burns yellow and makes a lot of soot.This happened after i tried to light it and there was some kind of blow back and some smoke but no visible flame. I have striped it down as far as i can and nothing seems to be blocked. There is a plastic part in the metal pipe between the jet and the burner pan that looks a bit melted, do you think this is the problem and can it be replaced? Thank you for any help in resolving this problem.
Yellow flame = not enough air. (Remember using Bunsen burners in school science lab? Air hole closed = yellow flame). Have you twisted the main metal tube (whilst trying to remove the burner assembly)? Remove the gas tube and metal plate (6 small cross headed screws). Draw out the gas valve. Look into the metal tube. You should see 3 slotted holes - the air holes. On mine they had twisted and were blocked by the plastic of the leg assembly. Using a good pair of pipe grips, rotate the metal tube until the air holes are clear. Then re-assemble. My Cadac Eazy Chef now works like new.
Posted on Aug 23, 2009
The problem is definately the plastic baffle that has melted in the chromium plated tube. I don't know why this happens, but it melts and constricts the hole and so causes the flame to burn yellow and create a load of soot no matter how much air it gets.
If you remove the chrome tube from the plastic knuckle base, then using a long screwdriver or similar push baffle out from the bottom all will be revealed.
Replacements can be purchased from Busy Outdoors in Aberdeen for £3.95 plus £1.95 P&P. Black one is pre 2006 models (slide in legs), Blue one post 2006 models (hinged leg).
http://www.busyoutdoors.com/shop/outdoor-cooking/cadac-extras/cadac-eazi-chef-baffle/prod_389.html
When replacing, ensure the long part of the baffle stem goes to the top and the bottom of it is approx 5mm above the air holes. Insert the chrome stem back in the plastic knuckle also ensuring the airholes are clear above the gas nozzle in the knuckle, probably best to remove gas valve (4 screws - 2 mins) to ensure this is okay.
Assemble all back together with Cadac grill etc and voila sorted - happy Cadac - ing!
I found this out the hard way after months of taking the valve apart and putting it back together scratching my head and not being able to understand what the problem was as all looked okay. I even emailed Cadac direct several times but got no reply. In desperation, I put a screw driver down the chrome stem and pushed the baffle, found it moved and not even knowing it comes out as it looks like part of the stem, I then found out it was made out of plastic and had all melted.
A metal one would be a better idea, but then I guess it is down to cost.
Posted on Mar 04, 2010
  • 2 more comments
  • Geerhard Lode
    Geerhard Lode Jul 01, 2011
    Apply a collar of acrylic sealant around the support pipe where it mates with the underside of the socket in the blue burner pan after assembling the unit. Smear it off professionally.
    This deals with the issue 'false draft' around the venturi-nozzle system, which prevents the gas-hungry burner to **** up the correct amount of combustible mixture for maintaining a perfect flame.
    No wonder the venturi melts and the lightest amount of wind stops the flame and mountains of soot.
    This text assumes all other conditions OK'ed.
  • Geerhard Lode
    Geerhard Lode Jul 20, 2011
    Correction by Gerhard Lod:
    The words 'false draft' should be read as 'false draught' as commonly used in description of chimney problems.
  • Chris Cooper Jul 23, 2013
    Please note, we don't have any Baffles and haven't had any for the past 3/4 years. Regards, Busy Outdoors
  • Big Al X5 Aug 13, 2013
    These baffles can be obtained at Towler Staines in Bradfordhttp://www.towler-staines.co.uk/shop/cad...
Posted on Jul 23, 2013
    These baffles for both new and old Cadac's can be obtained at Towler Staines in Bradfordhttp://www.towler-staines.co.uk/shop/cad...
    Problem Solver:
  • 8 Answers
Sounds like it is getting to much air. Adjust your air flow on the ventura tube.
Posted on Aug 05, 2009
My cadac is burning black smoke
Check the venturi tube just behind the control knob and before the burner tube. You will probably find it full of spiders nests. You need to introduce air to the gas and that is where it is regulated.
Jun 04, 2016 | CADAC Safari Chef 6531 Grill
Why does my Cadac now burn with yellow flame ?
Blocked or dirty burner or orifice both need cleaning
Aug 26, 2014 | CADAC Grilling
Why does Heat exchanger soots up?
check gas pressure if too low it soots up and overheats
Jun 09, 2014 | Jandy Legacy Lrz325mp Millivolt Ignition...
SOOT PROBLEM CAUSED BY YELLOW FLAME
If they burn yellow then they are blocked IE lack of air causing flame to burn floopy yellow hence soot , clean burners and orfices to burners .
Mar 25, 2012 | Grilling
Using a cadac burner with a skottel model extension 8304 , with no 24 Jet ( using a LPG 9kg gas Bottle - no Regulator ) flame is good on full ( good Blue Colour ) however on Low Flame keeps going out...
My experience shows me the old steam engine problems.
No gastight connections where they should be.
So not the specified Kilowatts output.
Think of the old fashioned flanges witht the artificial (synthetic) rubber gasket between them. And the flangebolts which held them together, all with the same torque momentum in kilopounds/meter.
Check with good quality leak detection foam and/or use your imagination.
Alternative: look for YouTube High Definition
video 'The Cadac Legend', as of August 15, 2011.
Dutch: ................... Trek in BBQ.
English: ................. Draught in BBQ.
Talkin' about airtight/gastight connections.
Oct 08, 2010 | CADAC Safari Chef Portable Grill
My pitco 35 c the flame is burning yellow and not going inside the very wall i thought it might be the regulator pressure on the fryer on the back side
Low gas pressure will produce low flame quality (yellow flame).
Check and remove any dirt or soot on burner holes, and orifice
Burner flame not going inside the fire tube could be due to soot or carbon build up inside the fire tube blocking the flame path, check the inside of the fire tube, if considerable amount of soot is seen, better have them removed.
Yellow flame will cause a lot of problem on fryers if not corrected as soon as possible.
If you have doubt on your gas regulator, better have a qualified service technician to check it.
Sep 02, 2010 | Pitco Frialator 35CS Deep Fryer
I need an instruction booklet in order to sell a Cadac Carri Chef
go to there homepage and find files and download it disc usually it s an adobe file and burn from there
Aug 10, 2009 | CADAC Grilling
Require instruction manual
http://www.cadac.co.za/index.php?page=usermanuals TRY HERE FOR MANUALS
I have just bought this product and have got the manuals with it!!! They arent clear
May 27, 2009 | CADAC Grilling
Cannot get the cadac to light
the blue tube is the air baffle, it should be in there but the people at cadac told me it will work safely without it. this baffle has been known to melt on occasions, i phoned cadac and they sent me out a new one free of charge. dont know why yours wont light though. mine produces a yellow flame instead of a blue flame?
Apr 12, 2009 | Grilling
Grilling Logo
2,106 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Marvin
Marvin
Are you a Grilling Expert? Answer questions, earn points and help others
