Question about Hunter 23258 The Paramount XP New Bronze Ceiling Fan
Fan appears to be out of balance - Hunter 23258 The Paramount XP New Bronze Ceiling Fan
There should have been a small lead weight kit that came with your fan. First check to make sure all the screws are on tight and clean the blades from any dust buildup. Make sure your blades aren't warped. If they are, you cannot balance your blades and will need to buy new ones. See if that helps. If you don't have the lead kit you may be able to buy one at your hardware store. You can also measure the end of the blades to the ceiling to see if one is warped or heavier than the others. You can also remove the blades to see if it's the actual motor assembly that is out of balance.
Posted on Jul 03, 2009
What causes the Fan motor to shake and not come on
Shaking is usually caused by a bent, cracked or out of balance fan blade, Susan. The out of balance condition could have caused a bearing failure which could cause it to seize and not come on.
An internal overload (motor winding thermostat) opens the electrical circuit inside the motor and keeps it from running even though it appears that electricity is getting to the motor.
Oct 06, 2015 | Heating & Cooling
AOU12RLS outside unit is knocking or ticking? Any idea what it might be? Nothing appears to be in fan after taking cover off to examine.
need to check and make sure the condensing fan ( outdoor unit fan) wires are not hitting the fan blade, it could also be that the fan blade needs to be balanced.
Oct 21, 2013 | Fujitsu "AOU12RLS 12,000 BTU Cool/16,000...
How to fix a wobbly ceilng fan
wobbly cieling fan
1. make sure all mounting screws between the fan and the ceiling are tight. There is probably an electrical box mounted in the cieling that the fan is screwed into. I would turn the fan light on and then keep flipping breakers off, on at a time ,to see which breaker turns off the fan light. leave the fan light breaker off and you can unmount the fan from the cieling electrical box. The electrical box may have several holes in it for mounting screws and prehaps there are some holes left empty in the box that you can put more wood screws into to help keep the electrical box more firmly mounted and that may help lessen the wobble.
Its ok to bend the electrical wiring aside to put more screws in. Just be reasonably gentle with the wiring and then bend it back somewhat to where it was before you started. make sure that wiring does not get pinched between the fan and the electrical box and that all wiring resides inside the box.
#2 This is harder to do. you need to balance the blades for the fan ,similar to how a lawnmower blade is balanced after sharpening and before remounting the lawnmower blade on the mower. also kinda like balancing a car tire. I have a lawnmower blade balancing fixture that i bought at the lawnmower shop, but i dont know if there is a fan blade balancing fixture that you could buy from somewheres. Maybe try google.com,bing.com or ask.com and type into the search box fan blade balancer
or fan blade balancing fixture or fan blade balancing jig.
PLEASE read the directions or SPECIFICATIONS before you buy the fan blade balancer, only to find out that it only fits 9 inch diameter fan blades, and your blade is 2 4or 36 inches long.
The balancer may have to fit a certain diameter hole at the center
of the fan blade. When you finally find out which side of the fan blade is heavy, you have to grind , with an electric grinding wheel, some material off the heavy side of the blade so that it is the same wieght as the light side of the blade.
Try to imagine a cone shaped center[like step drills] like the capital letter V ,only up side down, so that the point is up. ON the underside of the inverted V is a needle tiped post that upside down V can pivot in any direction on. The hole in the middle of a lawnmower blade is centered somewheres on the outside of the inverted V, depending on the diameter of the hole in the lawnmower blade. The heavy side of the mower blade will go down and may touch the level asphault or the table top, depending on where you placed the balancing fixture. THen i would grind off metal until the heavy side can up to be level with the light side of the mower blade and it was considered balanced.
an appliance repair parts store may sell fan balancers, but if the would fit your cieling fan, better ask before you waiste your money on something that wont work for what you want.
Try calling up customer service of the manufacturor of your ceiling fan and ask about repair service for your brand fan.
see what repair service has to say, im sure many others have asked them about wobbling fans.
so they should have all the answers down pat.
Two more thoughts.
1.
.MAKE SURE ALL SCREWS THAT HOLD FAN BLADES ON TO THE HUB ARE THERE AND are TIGHT. one loose fan blade mounting screw or one missing fan blade screw will unbalance the whole thing and cause wobble.
2. the fan motor shaft bearing could be worn out or round or even egg shaped. If this is the cause, the motor must be diaassembled and new fan shaft bearings installed or the fan motor must be replaced.
good luck and have fun!
Sep 22, 2013 | Hampton Bay 24002 Ceiling Fan
What are the symptoms of a failed harmonic balancer on a oldsmobile 03 bravada smart trak 2wd engine vortec 4200. The fan clutch is really wobbly where it connects to the harmonic balancer pulley
The fan clutch is connected to the water pump. The harmonic balancer is the crank pulley. If the fan clutch/pulley the fan clutch is attached to is sloppy than the water pump is bad.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Feb 17, 2011 | 2003 Oldsmobile Bravada
My son has a Hunter fan in his room model 21841. It looks like a catchers mit with baseball bats pictures for blades. The fan wobbles so bad I can't turn it on past the first spin level. The cathcers...
The blades are out of balance. You need to add weight to the lighter weight blades to is turns smoothly with no wobble.
You can go to Home Depot or other home improvement store and buy a fan balancing kit for around $2. It will have instructions.
Dec 24, 2010 | Hunter 21841 The Baseball Fan Ceiling
Air handler fan appears to cause thumping noise
If it's a belt drive check the belt or the pulley could be worn. If it's direct drive check to se if something is in the fan wheel causing it to be out of balance.
Sep 11, 2009 | Heating & Cooling
Replacing the harmonic balancer in ford bronco 1985 how do i replcace it
First remove radiator fan shrould.This will give you access to the fan.Remove fan and fan belts.Remove bolt on harmonic balancer.You will need to rent a balancer remover and installer kit.Most big auto parts chains will rent these kits to you.Next remove four bolts holding pulley to balancer.Next attach balancer puller to balancer with long bolts from kit.Using a 1\2 drive breaker bar,remove balancer from engine.After removing balancer replace front seal.Lubricate hub on new balancer with engine oil.Then use installation tool from kit to install balancer.Never try to beat balancer on with hammer,engine damage could occur.Then work in reverse to replace remaining parts.Hope this will help you.
Aug 03, 2009 | Ford Bronco Cars & Trucks
When front fan or A/C are on, Loud Vibrations
some thing is out of balance,it could be water pump bearings viscousfluid in fan hub fan belts breaking up a/c compressor bearings needs experienced investigator to pin point which one youdoit.com
Jul 25, 2009 | 2003 Saturn ION
Ceiling fan wobbles How do i balance it ??
you go to the hardware store and buy a ceiling fan balancing kit
Jun 18, 2009 | Honeywell HT-800 Table Fan
BAD HARMONIC BALANCER
this site is lame ,i just called a dealership and got the answers i needed,i got no help here
Nov 25, 2008 | 1998 Nissan Pathfinder
Hunter 23258 The Paramount XP New Bronze Ceiling Fan Logo
97 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
