Question about AO Smith 3/4 hp 3450rpm 48Y Frame 115/230 volts Square Flange pool pump replacement motor
AO Smith 3/4 HP pool pump: Turns on, but within 20 seconds shuts off and there's a burning smell. Sounds like the impeller is stopping, but then I don't know what I'm talking about. The sound changes from normal to a quiet hum, then shuts off.
  • 128 Answers
Make sure you are wired correctly. There is different settings if the pump is 110 volt. The motor comes wired for 220 volt
Posted on Aug 23, 2009
New ao smith pool pump motor keeps tripping out under load
check the breaker might be weak possibly from previous pump motor also if it was hooked up incorrectly at first might have done damage to motor windings
Apr 17, 2014 | AO Smith Pool Pump Motor Hayward Swimming...
Booster pumps
Make sure the main pump is running while the booster is and make sure there is no air in the lines. You may have to open the pump to see if any debris has gotten into the impeller.
Aug 05, 2013 | AO Smith Pool & Spa
Replace ao smith century centurion b852
take apart normally impeller screw backwards thread but impeller unscrews normally
Oct 20, 2012 | AO Smith A O Smith Motors A O Smith 3/4hp...
Where I can buy the A.O Smith 3/4 HP pool pump impeller?
You'll need information from the pump that the AOSmith electric motor is attached to in order to get an impeller or any other pump parts. If there is no nameplate for the pump are there numbers on the impeller you need?
John
Mar 03, 2011 | AO Smith A O Smith Motors A O Smith 3/4hp...
Replaced the seal and impellar, now pump is getting hot and turning off? any suggestions
SOUNDS LIKE YOU GOT THE WRONG IMPELLER, THE ONE YOU GOT IS FOR A BIGGER MOTOR.. THESE IMPELLERS CAN BE A PAIN TO ID, OR EVEN FIND .. TRY THE IMPELLER FOR A 1HP. I BET IT WILL WORK JUST FINE .. JAY THE POOL PUMP REPAIR GUY IN LONGWOOD FL ..
Feb 27, 2011 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
I have a ao smith sp 1520 2 hp pool pump. the impeller broke off the shaft. how do i change the broken impeller please
Remove the back of the motor ... you will find there are flats on the shaft. Put your 7/16 or 1/2 open end wrench there and with your other hand, spin off the broken impeller.
Aug 22, 2010 | AO Smith 2 hp Swimming Pool - Jet / Well...
Hayward Self-Priming Pump with AO Smith 1 HP 56J frame motor. Stopped moving inground pool water. Added water to pump basket (low). Turned on pump, return jets sent "bubbles" into pool, stopped, then...
the pump must not have any air leaks in the suction side of it,, or it will just **** air and not water,,, water is very heavy you see, however i think its the impeller in the pump thats the problem,,,you should try to put water in the out let of the pump so you fill the pump with water first if its dryed out it may just wear out the impeller before it starts to **** water up, if this still dont work turn off the stop **** and strip out the pump to look at the impeller any wear on it and it will need a new one fitted
i hope this has help you, good luck
Nov 20, 2009 | AO Smith Pool Pump Motor Hayward Swimming...
Motor has died, how to disconnect from pump. 2
The thru-bolts hold it to the seal plate and the impeller is threaded onto the shaft.
Aug 09, 2009 | AO Smith Pool Pump Motor Hayward 2 Speed...
Swimming pool pump wont drain above ground pool
you are clogging your impeller take a wet vac put hose your using for pump in pool put vac on end of hose to woods and turn on vac long enough to get a water flow and shut of vac it is slower but will save pump
Jul 07, 2009 | AO Smith A.O. Smith Threaded Shaft 1 HP...
AO Smith 3/4 hp 3450rpm 48Y Frame 115/230 volts Square Flange pool pump replacement motor Logo
483 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Steve
Colin Stickland
Colin Stickland
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
