Hello
You can reset and "restore" your iPhone to default settings:
Turn off iPhone – Hold down the Sleep/Wake button for a few seconds until the red slider appears, then slide the red slider. Ignore this step if you iphone is already off.
Press and hold down the Home button for about 10 seconds until a yellow triangle with a text which says Please Connect to iTunes appears.
Plug the iPhone into Mac or a PC. Release the button if you haven’t.
Run and open iTunes if it’s not already opened yet.
iTunes will prompt a message that says iTunes has detected an iPhone in recovery mode. Click OK.
You will be taken to the iPhone pane. Then, click on Restore.
Wait for the full restoration process to complete, and the iPhone will be back to the original settings state as when it left the manufacturing factory, typically a working phone again if you face any problem, unless it’s hardware related."
AWESOME #4 :) thanks so much!! I have not synced my phone to my new laptop and did NOT want to restore. I cannot believe the tap with three fingers worked :) was in a panic! already missed calls and texts!
I've encountered the same problem. I've tried the first solution, but somehow the yellow triangle didn't appear. Then, I tried the second solution, it works!!!
i keep getting message when sending mail - the server rejected some or all of the email addresses....
(More)
i keep getting message when sending mail - the server rejected some or all of the email addresses. This will happen sometimes - and when it does for upto 3 hrs and then just send them ! next mail to go will wizz thru! help!
