The SC361 error code on a Ricoh Aficio MP C2551 is typically caused by a problem with the fusing unit. The fusing unit is responsible for heating the toner particles and fusing them to the paper. This error code can be caused by a variety of issues, such as a malfunctioning fusing unit, a problem with the thermistor, or an issue with the fusing lamp. Here are a few steps you can try to troubleshoot and resolve the SC361 error code:
Check the fusing unit: Make sure that the fusing unit is securely installed and that there are no visible signs of damage.
Check the thermistor: The thermistor is responsible for detecting the temperature of the fusing unit. Make sure that it is connected properly and that it is functioning correctly.
Check the fusing lamp: The fusing lamp is responsible for providing heat to the fusing unit. Make sure that it is functioning properly and that it is not burned out.
Check for jammed paper: If there is jammed paper in the fusing unit, it can cause the SC361 error code to appear. Remove any jammed paper and clear the area.
Check for debris: Make sure that there is no debris or dust buildup in the fusing unit that could be causing the problem.
Performing a reset: Try performing a reset on the printer to clear any temporary error codes.
If the error persists, it's best to contact a Ricoh service technician for further assistance. They will be able to diagnose the problem and repair the printer. It's important to note that attempting to repair the printer on your own may void the warranty and could cause further damage.
Steps to Fix Ricoh Printer Error Code SC899:- Start with unplugging the Ricoh printer network cable. Next, enter the service mode. Press the buttons in order as given after, [Reset] https://www.youtube.com/watch?v=ol2FUcWg08k
Here is the answer from the Ricoh Service Manual...
An SC899 occurs if the MFP is accessed from WIM (Web Image Monitor) after receiving an IP-FAX.
Because a firmware bug in the Network Support firmware is causing this symptom.
Call a Ricoh tech and have them update the Network Support firmware to ver.10.55 or later.
Steps to Fix Ricoh error code sc899:-
Stage 1:- Unplug the Ricoh Printer Network Cable To start with, unplug the printer system link Stage 2:- Turn Off Ricoh Printer Stage 3:- Install New Version of Adobe Acrobat" Add-on/Plug-in
