Question about Interactive Toy Concepts Polaris Sportsman 800 Remote-Control ATV
Cooling fan polaris 500
I just replaced a cooling fan in a 2005 polaris atv 500. When the battery terminals were connected, the cooling fan comes on without the key on. There was a burning smell and a crack. I disconnected and reconnected again and the fan still comes on. It still works even though something was burning. What would cause the fan to come on?
    Problem Solver:
  • 8 Answers
Thermostat switch has been by-passed, when machine gets up to temp, the switch sends power to the fan, when the switch goes bad the machine will overheat due to the fan not kicking on. make sure the switch has not been by-passed and wired direct.
Posted on Sep 25, 2009
When my cooling fan kicks on it runs intermittently.
The fan will only run when it needs to. It's on a sensor. The only time mine comes on is if I'm hauling something
Sep 09, 2015 | Polaris 2013 Sportsman 500 HO
I HAVE A 2005 POLARIS ATP 500 I HAVE NO ELETRICAL
check for clean battery connections no corrosion do you have 12 volts at the battery
Nov 11, 2013 | Polaris 2005 All-Terrain Pickup 330
I have a 93 polaris 350l 4x4 revved engine and lights blew also th cooling fan stopped working around the same time
I have a 2001 polaris scrambler 500 4x4 and it wouldn't charge the battery and my lights wouldn't work and the fan wouldn't come on so it overheated and it was the voltage regulator that was broke and that makes the fan and lights work it might not be a stator hopes this helps
Jan 24, 2013 | Polaris ATV
I have 97 Polaris Express 400 I haven't ridden in a while. Put new battery in it, new fuel, cranks, runs great but overheats. I checked the radiator reservoir and it is full. Any suggestions? How can I...
U should have two sensors for the cooling system one is nerr the thermostat housing for temp light / gauge ,one on the cooler at the bottem left side should have two wires on it need to pull them off connect the two togather. That should make the fan come on, if not, look for a popped fuse should invest in a handheld inferred thermometer ,there really cheap .get them on eBay for between 11 to 20 bucks brand new use it to test temp on coolant hoses to see temp on top and bottom .if fan does come replace cooling fan temp sensor.
Mar 03, 2018 | Polaris ATV
Engine'' hot'' light came on, i stopped and the fan was not on, by-passed the fan switch ,connected it to acc power so fan would remain on when key was in on position. engine cooled down and off i went. 5...
I cant solve your problem, but I have a problem with my "hot" light coming on. I left my lights on for 3 weeks, so my battery was junked. When I replaced the battery my fan kicks on with just the turn of the key, and the hot light flashes even though the engine has'nt been running. Polaris 08
Mar 07, 2010 | Polaris ATV
2006 polaris sportman 500 HO overheating problem HELP!!!!!!
Check that the electric fan motor comes on ,and check the radiator for mud and debris u may also need new oil and filter change,All of these things could make it run hot 1 more thing roll it in neutral 2 make sure breaks arent hanging up.
Dec 18, 2009 | Polaris ATV
ATV will not start. no power to lights, starter.
make sure that your battery terminals are clean and are making good connection, sometimes when alot of mud builds up on my bikes battery it wont start also try to start it by the recoil is it has one or the kick start cuz when the battery is dead and you stuck in the trails you can start it by this and it should start
if this doesnt work let me no
Mar 06, 2009 | Polaris ATV
Interactive Toy Concepts Polaris Sportsman 800 Remote-Control ATV Logo
489 people viewed this question
Top Interactive Toy Concepts Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you an Interactive Toy Concepts Toy Expert? Answer questions, earn points and help others
