Question about Ricoh Aficio 1515MF All-In-One Laser Printer
I'm trying to print on a Ricoh 1035 from a Mac. Is this possible if it's on a network?
  • jwilson787 Jul 02, 2009
    Thanks for your help. It appears that is exactly the problem.
    New Friend:
  • 63 Answers
Its possable to print to a networked ricoh 1035 from a Mac... You need the Postscript option...
Posted on Jul 02, 2009
  • 31 Answers
I believe you'll need the post script card installed also, it looks like a stick of laptop memory but plugs into a socket on the controler unit.
Posted on Jul 12, 2009
  • Ricoh Expert
  • 398 Answers
Yes, but apple talk must be enabled at the machine. -Carl
Posted on Jul 01, 2009
Can't print color or use finisher on our network ricoh from Mac
Sounds like you may not have the correct driver installed and also not configured right for devices
Dec 29, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Do i need any driver if i connect Aficio 1035 to my pc. n wat do i need for it to be connected to my pc. tq
Does your machine have the Printer Option installed? Or the Print / Scan Option installed? If so, there would be a NIC input on the left hand side of machine towards the back....and print and scan buttons on the left side on your control panel. Type 1045 Printer option is what needs to be installed for the machine to be able to print. Drivers can be downloaded from this link to Ricoh.
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/x1035_45/x1035_45en.htm
Just choose your operating system.
Oct 22, 2009 | Ricoh Aficio 1035 Copier
Trying to get my Ricoh Aficio 1035 networkable
This is all you need to upgrade your copier to a network printer/scanner and fax.
Good Luck.
32MB Memory Unit Type B 400516
Postscript 3 kit type 1045 410713
64MB Memory Unit Type B 400517
Fax Function Upgrade Type 185 410284
Print Unit Type 1045 410706
Printer/Scanner Unit Type 1045 410699
Network Interface Board Type 1045 410714
Fax Option Type 1045 410680
Fax Stamp Marker Type 30 334049
Jul 08, 2009 | Ricoh Aficio 1035 Copier
Can not print to network printer
Do you mean you can ping it? If you can't, then disregard, my instructions below
You downloaded the latest "Vista" driver? then you went to"add Printer", Selected "Local Printer", then "create new port", select "standard TCP/IP port" typed in the proper Ip address of the printer? The wizard should find it and show it as using "Ricoh type C adapter" or similar, (if it moves on to the "select generic adapter" something is wrong) select have disk, and browse to the location of the unzipped printer driver, and install
Feb 26, 2009 | Ricoh Aficio 1035 Copier
My Ricoh Aficio 1035 is not seeing the network
You will need to assign a new appropriate IP address for the machine under "user tools" system settings", "Interface settings", "Ip address".
Then create a new tcp/ip port for the printer, and point the old driver to this. Scanning may require additional work -perhaps a tech, to reconfigure the scanner. Your probably using the "scanrouter" software?
Jan 22, 2009 | Ricoh Aficio 1035 Copier
Networking at Ricoh 1035
does your 1035 have either a printer or printer /scanner option. If it does just hook s line up to the network connector on the back of the controller. hit user tools, system settings, interface settings, network settings and then select auto obtain. now exit from the user tools to the regular screen. wait about ten seconds to let the settings take effect. Now hit user tools , printer features, lists and hit configuration page. Take this page to the computers with you. Go to start, add a printer add a local printer, deselect auto detect, hit next. Now hit add port select tcp/ip from drop down button. in location where is it says printer name or ip address enter the printer name located on the bottom right section of the configuration page you printed. now go to ricohs website www.ricoh.com, americas, then at the top you will see downloads. then a screen will apper that says drivers and manuals. select black and white, 1035 and windows vista. create a folder on your desktop called printer. once in the folder, open it double click and unzip it into the same folder.now back to page after you have typed in the printer name and hit next. go to have disc, browse to the folder on the desktop and follow the prompts form set up, drivers, vista, pcl 5, english and the select if this is your default printer, do not select sharing and ask it to print a test page. once this has printed go to the properties tab on the drive itself and select accessories. and add whatever options your copier has ie. sorter, duplex or extra paper drawers. Now do this to all your copiers on the network. doing this allows you to print from any computer regardless if any other computer goes down
Dec 11, 2008 | Ricoh Aficio 1035 Copier
How to connect ricoh 1035
First, check on the left side of the machine to see if it has either a USB or RJ-45 receptical to plug your computer into. If not, the machine lacks the hardware needed to print from your computer. A Ricoh technician must install it at extra cost. If you DO have either of these recepticals, go to:www.ricoh-usa.com/downloads, to download the manual and drivers you need.
Sep 02, 2008 | Ricoh Aficio 1035 Copier
Does not print from Mac OX 10.5 Leopard
from a mac, you need to have a post script print option installed, the system only came with pcl
http://www.websitetoolbox.com/mb/copierquestions
Apr 04, 2008 | Ricoh Aficio 3025 All-In-One Laser Printer
Ricoh 1035 - Tray 4
There is a wire harness that connects the two bottom trays to the main machine. The connector might be loose or have a break in the harness. The main machine is not seeing the bottom two trays. Let me know if this helps.
Sep 15, 2007 | Office Equipment & Supplies
Ricoh 1035 scanning set up
plase install the scanner board and software
Sep 13, 2007 | Office Equipment & Supplies
Ricoh Aficio 1515MF All-In-One Laser Printer Logo
252 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
