Question about Maytag MAH6700AWW Neptune Front-Load Washer
Maytag Neptune door lock stuck!!!
My Maytag Neptune washer (2002 model) has a problem with the door lock. The door lock is stuck and I have wet clothes in there! I tried unplugging it but it is still locked! It displays a "door open" error message
    Problem Solver:
  • 5 Answers
Try these steps:
1.) Take the washer outside. 2.) Loosen the two screws on the back panel and remove the back panel. The pump sits on the left-side of the opening. There's a black water hose with a metal clamp; 3.) squeeze the metal clamp with your fingers until it's loose enough to slide away from the pump. 4.) Separate the hose from pump and the trapped water will pour out and the door will then open; and 5.) clear any blockage from the drain hose and the pump.
Posted on Jul 10, 2009
  • 1 more comment
  • jimvaliere Jan 29, 2011
    I'm going to try this. I really appreciate you sharing your knowledge and saving us money. Thank you!
  • marymckay85
    marymckay85 Mar 09, 2013
    i have the same prob w/my washer now.. did this help u?
  • petunia Aug 12, 2013
    Thanks! I had the same problem, only the error message is "no drain." A little rock had somehow gotten wedged inside the pump. You saved me a service call!
Maytag neptune washer clothes staying wet after cycle
Is your door lock light on when machine is in use? I am having the same issue as you and I believe it is because my door is not locking during use.
Apr 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Washer, Model: MAH5500
The problem is with your door lock set.You may need to
replace it.If your lock is faulty the washer wont begin its
cycle.
Apr 08, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer
check to make sure the door is locking when it should. If the door isn't locking or sensing that its locked the washer will not go into high speed spin.
Mar 31, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
Won't drain all the way and door lock won't light up
Clean out the drain pump and check the pump motor while it is dis-assembled.
Mar 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Front Loader Washer
Sounds like the door lock unit isn't locking and may be bad. It is also a possiblity but not likely that there could be a problem with the computer board but start with the door lock unit first
Dec 29, 2008 | Maytag Neptune Washer
Door Lock
on your model all wax motor door latch's have to be replaced,go to repair clinic .com and you can order the part or go to ebay,and put in maytag neptune mah5500bww wax motor and it will come up and the guy selling the motors has pictures on how to install,let me know-mike
Jun 25, 2008 | Maytag Neptune MAH5500B Front Load Washer
My neptune does not extract.  My clothes come out dripping wet.
I am having the same problem, and have found that the door lock light is not on, and that the door lock does not seem to be working. This would keep the machine from spinning.
Is your door lock light on?
Jun 14, 2008 | Maytag Neptune MAH7500WH Front Load Washer
Maytag MAH6700AWW Neptune Front-Load Washer Logo
2,093 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
